[cgma-dev] r1439 - cgm/trunk/geom/OCC
janehu at mcs.anl.gov
Wed Dec 5 13:09:43 CST 2007
Author: janehu
Date: 2007-12-05 13:09:43 -0600 (Wed, 05 Dec 2007)
New Revision: 1439
Added:
cgm/trunk/geom/OCC/OCCDrawTool.cpp
cgm/trunk/geom/OCC/OCCDrawTool.hpp
Modified:
cgm/trunk/geom/OCC/Makefile.am
cgm/trunk/geom/OCC/OCCQueryEngine.cpp
cgm/trunk/geom/OCC/OCCShell.cpp
Log:
formatted OCCQueryEngine.cpp, added OCCDrawTool files, added bounding_box for OCCShell.
Modified: cgm/trunk/geom/OCC/Makefile.am
--- cgm/trunk/geom/OCC/Makefile.am 2007-12-04 19:09:23 UTC (rev 1438)
+++ cgm/trunk/geom/OCC/Makefile.am 2007-12-05 19:09:43 UTC (rev 1439)
@@ -39,7 +39,8 @@
OCCPoint.cpp \
OCCQueryEngine.cpp \
OCCShell.cpp \
- OCCSurface.cpp
+ OCCSurface.cpp \
+ OCCDrawTool.cpp
# Headers to be installed. If any file in this list should
# not be installed, move it to the _SOURCES list above.
@@ -57,5 +58,6 @@
OCCPoint.hpp \
OCCQueryEngine.hpp \
OCCShell.hpp \
- OCCSurface.hpp
+ OCCSurface.hpp \
+ OCCDrawTool.hpp
Added: cgm/trunk/geom/OCC/OCCDrawTool.cpp
--- cgm/trunk/geom/OCC/OCCDrawTool.cpp (rev 0)
+++ cgm/trunk/geom/OCC/OCCDrawTool.cpp 2007-12-05 19:09:43 UTC (rev 1439)
@@ -0,0 +1,227 @@
+//- Class: OCCDrawTool
+//- Description: Functions to draw OCC geometry (useful for debugging or
+//- in previewing operations for the user)
+//- Author: Jane Hu
+// ********** BEGIN OCC INCLUDES **********
+#include "config.h"
+#include "gp_Pnt.hxx"
+#include "TopoDS.hxx"
+#include "TopoDS_Face.hxx"
+#include "TopoDS_Shape.hxx"
+#include "TopoDS_Edge.hxx"
+#include "TopoDS_Vertex.hxx"
+#include "TopoDS_CompSolid.hxx"
+#include "TopoDS_Solid.hxx"
+#include "TopoDS_Shell.hxx"
+#include "TopTools_IndexedMapOfShape.hxx"
+#include "TopExp.hxx"
+#include "BRep_Tool.hxx"
+// ********** END OCC INCLUDES **********
+// ********** BEGIN CUBIT INCLUDES **********
+#include "OCCDrawTool.hpp"
+#include "OCCSurface.hpp"
+#include "OCCCurve.hpp"
+#include "Lump.hpp"
+#include "Surface.hpp"
+#include "Curve.hpp"
+#include "Point.hpp"
+#include "OCCQueryEngine.hpp"
+#include "DLIList.hpp"
+#include "GMem.hpp"
+#include "GfxPreview.hpp"
+// ********** END CUBIT INCLUDES **********
+OCCDrawTool* OCCDrawTool::instance_ = 0;
+// Method: instance
+// provides access to the unique model for this execution.
+// sets up this instance on first access
+OCCDrawTool* OCCDrawTool::instance()
+ if (instance_ == 0) {
+ instance_ = new OCCDrawTool();
+ return instance_;
+OCCDrawTool::OCCDrawTool()
+OCCDrawTool::~OCCDrawTool()
+CubitStatus
+OCCDrawTool::draw_TopoDS_Shape( TopoDS_Shape *shape, int color,
+ CubitBoolean tessellate,
+ CubitBoolean flush )
+ if( (TopoDS_CompSolid*)shape ||
+ (TopoDS_Solid*)shape ||
+ (TopoDS_Shell*)shape )
+ DLIList<TopoDS_Face*> Face_list;
+ TopTools_IndexedMapOfShape M;
+ TopExp::MapShapes(*shape, TopAbs_FACE, M);
+ int ii;
+ for (ii=1; ii<=M.Extent(); ii++)
+ TopologyBridge *face = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
+ OCCSurface *occ_face = CAST_TO(occ_face, OCCSurface);
+ Face_list.append_unique(occ_face->get_TopoDS_Face());
+ int i;
+ for( i=Face_list.size(); i--; )
+ draw_FACE( Face_list.get_and_step(), color, tessellate );
+ if( flush )
+ GfxPreview::flush();
+ return CUBIT_SUCCESS;
+ else if ((TopoDS_Face*)shape )
+ return draw_FACE((TopoDS_Face *)shape , color, tessellate, flush );
+ else if( (TopoDS_Wire*)shape)
+ DLIList<TopoDS_Edge*> EDGE_list;
+ TopExp::MapShapes(*shape, TopAbs_EDGE, M);
+ int ii;
+ TopologyBridge *edge = OCCQueryEngine::instance()->occ_to_cgm(M(ii));
+ OCCCurve *occ_curve = CAST_TO(edge, OCCCurve);
+ EDGE_list.append_unique(occ_curve->get_TopoDS_Edge());
+ int i;
+ for( i=EDGE_list.size(); i--; )
+ draw_EDGE( EDGE_list.get_and_step(), color );
+ if( flush )
+ else if ((TopoDS_Edge*)shape )
+ return draw_EDGE( (TopoDS_Edge*)shape, color, flush );
+ else if ((TopoDS_Vertex*)shape )
+ return draw_VERTEX( (TopoDS_Vertex*)shape, color, flush );
+ else
+ PRINT_ERROR( "Unsupported entity type specified - cannot draw\n" );
+ return CUBIT_FAILURE;
+CubitStatus
+OCCDrawTool::draw_EDGE( TopoDS_Edge *EDGE_ptr, int color, CubitBoolean flush )
+ OCCQueryEngine *OQE = OCCQueryEngine::instance();
+ Curve *curve_ptr = OQE->populate_topology_bridge( *EDGE_ptr );
+ CubitStatus stat;
+ stat = draw_curve(curve_ptr, color, flush);
+ OQE->delete_solid_model_entities( curve_ptr );
+ return stat;
+CubitStatus
+OCCDrawTool::draw_surface( Surface *surface, int color, CubitBoolean tessellate ,CubitBoolean flush)
+ if( tessellate )
+ int num_tris, num_pnts, num_facets;
+ GMem g_mem ;
+ OQE->get_graphics( surface, num_tris, num_pnts, num_facets,
+ &g_mem );
+ // Draw the triangles
+ GPoint p[3];
+ GPoint* plist = g_mem.point_list();
+ int* facet_list = g_mem.facet_list();
+ int i, c = 0;
+ for( i=0; i<num_tris; i++ )
+ p[0] = plist[facet_list[++c]];
+ p[2] = plist[facet_list[++c]];
+ p[1] = plist[facet_list[++c]];
+ c++;
+ GfxPreview::draw_tri( p, color );
+ else
+ // Draw curves
+ DLIList<OCCCurve*> curve_list;
+ CAST_TO(surface, OCCSurface)->get_curves(curve_list);
+ int i;
+ for( i=curve_list.size(); i--; )
+ draw_curve( (Curve*)(curve_list.get_and_step()), color, flush );
+ if( flush )
+CubitStatus
+OCCDrawTool::draw_curve( Curve *curve, int color , CubitBoolean flush )
+ GMem g_mem;
+ int num_points;
+ // get the graphics
+ CubitStatus stat;
+ stat = OQE->get_graphics( curve, num_points, &g_mem );
+ if (stat==CUBIT_FAILURE || num_points == 0)
+ PRINT_ERROR("Unable to tessellate a curve for display\n" );
+ else
+ // Draw the polyline
+ GfxPreview::draw_polyline( g_mem.point_list(), g_mem.pointListCount, color );
+ if( flush )
+CubitStatus
+OCCDrawTool::draw_FACE( TopoDS_Face *FACE_ptr, int color,
+ Surface *surf_ptr = OQE->populate_topology_bridge( *FACE_ptr );
+ CubitStatus stat;
+ stat = draw_surface(surf_ptr, color, tessellate, flush);
+ OQE->delete_solid_model_entities( surf_ptr );
+ return stat;
+CubitStatus
+OCCDrawTool::draw_VERTEX( TopoDS_Vertex *VERTEX_ptr, int color, CubitBoolean flush )
+ gp_Pnt pt = BRep_Tool::Pnt(*VERTEX_ptr);
+ GfxPreview::draw_point( pt.X(), pt.Y(), pt.Z(), color );
Property changes on: cgm/trunk/geom/OCC/OCCDrawTool.cpp
___________________________________________________________________
Added: cgm/trunk/geom/OCC/OCCDrawTool.hpp
--- cgm/trunk/geom/OCC/OCCDrawTool.hpp (rev 0)
+++ cgm/trunk/geom/OCC/OCCDrawTool.hpp 2007-12-05 19:09:43 UTC (rev 1439)
@@ -0,0 +1,63 @@
+#ifndef OCC_DRAW_TOOL_HPP
+#define OCC_DRAW_TOOL_HPP
+#include "CubitDefines.h"
+class TopoDS_Shape;
+class TopoDS_Face;
+class TopoDS_Edge;
+class TopoDS_Vertex;
+class Surface;
+class Curve;
+template <class X> class DLIList;
+class OCCDrawTool
+public:
+// ********** BEGIN FRIEND DECLARATIONS **********
+// ********** END FRIEND DECLARATIONS **********
+ ~OCCDrawTool();
+ static OCCDrawTool* instance();
+ //- Gives access to the singleton object of this class
+ //do not remove this function....it is handy for debugging.
+ CubitStatus draw_TopoDS_Shape( TopoDS_Shape *shape, int color,
+ CubitBoolean tessellate = CUBIT_FALSE,
+ CubitBoolean flush = CUBIT_FALSE );
+ //- Draw the given TopoDS_Shape. Handles entities of type CompSolid, Solid, Shell,
+ //- Face, Loop, Edge or Vertex. The tessellate option only applies
+ //- to Faces - if true, the Face is tessellated and each triangle is drawn;
+ //- otherwise, only the outer curves are drawn.
+ CubitStatus draw_surface( Surface *surface, int color, CubitBoolean tessellate, CubitBoolean flush );
+ CubitStatus draw_curve( Curve *curve, int color, CubitBoolean flush );
+ CubitStatus draw_FACE( TopoDS_Face *face, int color,
+ //- Draw the given Face. If tessellate is true, the FACE is tessellated and
+ //- each triangle is drawn; otherwise, only the outer curves are drawn.
+ CubitStatus draw_EDGE( TopoDS_Edge *edge, int color,
+ //- Draw the given EDGE
+ CubitStatus draw_VERTEX( TopoDS_Vertex *vertex, int color,
+ //- Draw the given VERTEX
+protected:
+ OCCDrawTool();
+ //- Class Constructor. (Not callable by user code. Class is constructed
+ //- by the {instance()} member function.
+private:
+ static OCCDrawTool* instance_;
+#endif
Property changes on: cgm/trunk/geom/OCC/OCCDrawTool.hpp
Modified: cgm/trunk/geom/OCC/OCCQueryEngine.cpp
--- cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-12-04 19:09:23 UTC (rev 1438)
+++ cgm/trunk/geom/OCC/OCCQueryEngine.cpp 2007-12-05 19:09:43 UTC (rev 1439)
@@ -128,8 +128,8 @@
OCCQueryEngine* OCCQueryEngine::instance()
if (instance_ == NULL ) {
- instance_ = new OCCQueryEngine;
+ instance_ = new OCCQueryEngine;
return instance_;
@@ -187,7 +187,7 @@
const type_info& OCCQueryEngine::entity_type_info() const
- return typeid(OCCQueryEngine);
+ return typeid(OCCQueryEngine);
@@ -200,10 +200,10 @@
OCCBody *body = CAST_TO(bodysm, OCCBody);
if (!body)
- PRINT_ERROR("Attempt to reflect OCC-based geometry Body. This body is not OCCBody.");
- return CUBIT_FAILURE;
+ PRINT_ERROR("Attempt to reflect OCC-based geometry Body. This body is not OCCBody.");
body->reflect( axis.x(), axis.y(), axis.z() );
@@ -229,15 +229,15 @@
double distance_tolerance,
double max_edge_length) const
- // Because this may be unnecessarily called twice,
- // say there is one triangle.
+ // Because this may be unnecessarily called twice,
+ // say there is one triangle.
if (!g_mem)
- number_triangles = 1;
- number_points = 3;
- number_facets = 4;
- return CUBIT_SUCCESS;
+ number_triangles = 1;
+ number_points = 3;
+ number_facets = 4;
OCCSurface *occ_surface_ptr = CAST_TO(surface_ptr, OCCSurface);
TopoDS_Face * Topo_Face = occ_surface_ptr->get_TopoDS_Face();
@@ -263,32 +263,32 @@
//It's possible also that N's starting from 1.
int minN = 0;
for (int i = 0; i < triangles.Length(); i++)
- Poly_Triangle triangle = triangles.Value( i );
- int N1, N2, N3;
- triangle.Get(N1, N2, N3);
- facetList[4 * i] = 3;
- facetList[4 * i + 1] = N1;
- minN = (minN < N1 ? minN : N1);
- facetList[4 * i + 2] = N2;
- minN = (minN < N2 ? minN : N2);
- facetList[4 * i + 3] = N3;
- minN = (minN < N3 ? minN : N3);
+ Poly_Triangle triangle = triangles.Value( i );
+ int N1, N2, N3;
+ triangle.Get(N1, N2, N3);
+ facetList[4 * i] = 3;
+ facetList[4 * i + 1] = N1;
+ minN = (minN < N1 ? minN : N1);
+ facetList[4 * i + 2] = N2;
+ minN = (minN < N2 ? minN : N2);
+ facetList[4 * i + 3] = N3;
+ minN = (minN < N3 ? minN : N3);
g_mem->replace_facet_list( facetList, number_facets, number_facets);
TColgp_Array1OfPnt points(minN, minN + number_points-1);
points.Assign(facets->Nodes());
GPoint *gPnts= new GPoint[number_points + minN];
for (int i = minN; i < number_points + minN; i ++)
- gp_Pnt gp_pnt = points.Value(i);
- GPoint gPnt;
- gPnt.x = gp_pnt.X();
- gPnt.y = gp_pnt.Y();
- gPnt.z = gp_pnt.Z();
- gPnts[i] = gPnt;
+ gp_Pnt gp_pnt = points.Value(i);
+ GPoint gPnt;
+ gPnt.x = gp_pnt.X();
+ gPnt.y = gp_pnt.Y();
+ gPnt.z = gp_pnt.Z();
+ gPnts[i] = gPnt;
g_mem->replace_point_list( gPnts, number_points, number_points + minN);
@@ -327,14 +327,14 @@
//! triangle the function NbNodes returns 4.
GPoint *gPnts= new GPoint[num_points];
for (int i = 0; i < num_points ; i ++)
- GPoint gPnt;
- gPnts[i] = gPnt;
+ GPoint gPnt;
+ gPnts[i] = gPnt;
gMem->replace_point_list( gPnts, num_points, num_points );
@@ -354,10 +354,10 @@
TopoDS_Face* Tops_face = occ_surface->get_TopoDS_Face();
TopoDS_Face the_face;
if (Tops_face == NULL)
- PRINT_ERROR("This surface is not OCCSurface.");
+ PRINT_ERROR("This surface is not OCCSurface.");
the_face = *Tops_face;
Handle_Geom_Surface HGeom_surface = BRep_Tool::Surface(the_face);
@@ -371,19 +371,19 @@
g_mem = new GMem[nu];
//nu and nv must be given to calculate the points.
for (int i = 0; i < nu; i++)
- Handle_Geom_Curve HGeom_curve = HGeom_surface->UIso(u1 + i * interval1);
- g_mem[i].allocate_polylines(nv-1);
- for (int j = 0; j < nv; j++)
- gp_Pnt pnt = HGeom_curve->Value(v1 + j * interval2);
- g_mem[i].point_list()[j].x = pnt.X();
- g_mem[i].point_list()[j].y = pnt.Y();
- g_mem[i].point_list()[j].z = pnt.Z();
- g_mem[i].pointListCount = nv;
+ Handle_Geom_Curve HGeom_curve = HGeom_surface->UIso(u1 + i * interval1);
+ g_mem[i].allocate_polylines(nv-1);
+ for (int j = 0; j < nv; j++)
+ gp_Pnt pnt = HGeom_curve->Value(v1 + j * interval2);
+ g_mem[i].point_list()[j].x = pnt.X();
+ g_mem[i].point_list()[j].y = pnt.Y();
+ g_mem[i].point_list()[j].z = pnt.Z();
+ g_mem[i].pointListCount = nv;
@@ -395,10 +395,10 @@
@@ -414,15 +414,15 @@
g_mem = new GMem;
g_mem->allocate_polylines(n-1);
for (int j = 0; j < n; j++)
gp_Pnt pnt = HGeom_curve->Value(u1 + j * interval);
g_mem->point_list()[j].x = pnt.X();
g_mem->point_list()[j].y = pnt.Y();
g_mem->point_list()[j].z = pnt.Z();
- g_mem->pointListCount = n;
+ g_mem->pointListCount = n;
CubitStatus OCCQueryEngine::get_v_isoparametric_points(Surface* surface,
@@ -433,10 +433,10 @@
@@ -452,15 +452,15 @@
g_mem = new GMem;
gp_Pnt pnt = HGeom_curve->Value(v1 + j * interval);
@@ -493,20 +493,20 @@
OCCCurve *occ_curve = CAST_TO(curve, OCCCurve);
if (occ_curve == NULL)
- PRINT_ERROR("Option not supported for non-occ based geometry.\n");
+ PRINT_ERROR("Option not supported for non-occ based geometry.\n");
OCCPoint *pt1 = new OCCPoint(point1);
OCCPoint *pt2 = new OCCPoint(point2);
Curve *curve2 =
- OCCModifyEngine::instance()->make_Curve(pt1, pt2);
+ OCCModifyEngine::instance()->make_Curve(pt1, pt2);
if (curve2 == NULL)
- PRINT_ERROR( "Unable to create OCC EDGE from points\n" );
+ PRINT_ERROR( "Unable to create OCC EDGE from points\n" );
OCCCurve *occ_curve2 = CAST_TO(curve2, OCCCurve);
return get_intersections(occ_curve, occ_curve2, intscts, bounded, closest);
@@ -520,17 +520,17 @@
OCCCurve *occ_curve1 = CAST_TO(curve1, OCCCurve);
if (occ_curve1 == NULL)
if (occ_curve2 == NULL)
//currently, there's no effect on 'closest' argument or bounded.
BRepExtrema_DistShapeShape distShapeShape(
@@ -539,22 +539,22 @@
//distShapeShape.Perform();
if (!distShapeShape.IsDone())
- PRINT_ERROR("Cannot calculate the intersection points for the input curves.\n");
+ PRINT_ERROR("Cannot calculate the intersection points for the input curves.\n");
if (distShapeShape.Value() < get_sme_resabs_tolerance())
- int numPnt = distShapeShape.NbSolution();
- for (int i = 1; i <= numPnt; i++)
- gp_Pnt aPoint = distShapeShape.PointOnShape1(i);
+ int numPnt = distShapeShape.NbSolution();
+ for (int i = 1; i <= numPnt; i++)
+ gp_Pnt aPoint = distShapeShape.PointOnShape1(i);
- CubitVector* cv = new CubitVector(aPoint.X(), aPoint.Y(), aPoint.Z());
- intscts.append(cv);
+ CubitVector* cv = new CubitVector(aPoint.X(), aPoint.Y(), aPoint.Z());
+ intscts.append(cv);
@@ -566,17 +566,17 @@
// There's no effect of bounded = false.
OCCSurface *occ_surface = CAST_TO(surface, OCCSurface);
if (occ_surface == NULL)
BRepExtrema_DistShapeShape distShapeShape(*(occ_curve->get_TopoDS_Edge()),
@@ -584,22 +584,22 @@
- PRINT_ERROR("Cannot calculate the intersection points for the input curve and surface.\n");
+ PRINT_ERROR("Cannot calculate the intersection points for the input curve and surface.\n");
@@ -611,11 +611,11 @@
CubitStatus
OCCQueryEngine::entity_extrema( DLIList<GeometryEntity*> &ref_entity_list,
- const CubitVector *dir1,
- const CubitVector *dir2,
- const CubitVector *dir3,
- CubitVector &extrema,
- GeometryEntity *&extrema_entity_ptr )
+ const CubitVector *dir1,
+ const CubitVector *dir2,
+ const CubitVector *dir3,
+ CubitVector &extrema,
+ GeometryEntity *&extrema_entity_ptr )
//in Acis, the api_entity_extrema is used to calculate "possible
//self-intersecting sweeping and to align lofting sections"
@@ -637,28 +637,28 @@
TopoDS_Shape * shape1;
TopoDS_Shape * shape2;
if ((shape1 = get_TopoDS_Shape_of_entity(entity1)) == NULL)
- PRINT_ERROR( "problem occured getting OCC entity.\n"
- " Aborting.\n" );
+ PRINT_ERROR( "problem occured getting OCC entity.\n"
+ " Aborting.\n" );
if( (shape2 = get_TopoDS_Shape_of_entity( entity2 )) == NULL )
- " Aborting.\n");
+ " Aborting.\n");
BRepExtrema_DistShapeShape distShapeShape(*shape1, *shape2);
- PRINT_ERROR( "problem occured getting distance between OCC entities.\n"
- " Aborting.\n");
+ PRINT_ERROR( "problem occured getting distance between OCC entities.\n"
+ " Aborting.\n");
distance = distShapeShape.Value();
gp_Pnt pnt1 = distShapeShape.PointOnShape1(1);
@@ -671,63 +671,63 @@
TopoDS_Shape* OCCQueryEngine::get_TopoDS_Shape_of_entity(TopologyBridge *entity_ptr)
if (OCCBody *body_ptr = CAST_TO( entity_ptr, OCCBody))
- TopoDS_CompSolid* theShape = body_ptr->get_TopoDS_Shape();
- if (!theShape)
- PRINT_ERROR("OCCBody without TopoDS_Shape at %s:%d.\n", __FILE__, __LINE__ );
- return NULL;
+ TopoDS_CompSolid* theShape = body_ptr->get_TopoDS_Shape();
+ if (!theShape)
+ PRINT_ERROR("OCCBody without TopoDS_Shape at %s:%d.\n", __FILE__, __LINE__ );
+ return NULL;
+ return theShape;
- return theShape;
else if (OCCLump * lump_ptr = CAST_TO( entity_ptr,OCCLump))
- TopoDS_Solid * theSolid = lump_ptr->get_TopoDS_Solid();
- if(theSolid)
- return (TopoDS_Shape*) theSolid;
- else
- PRINT_ERROR("OCCLump without TopoDS_Solid at %s:%d.\n", __FILE__, __LINE__ );
- return NULL;
+ TopoDS_Solid * theSolid = lump_ptr->get_TopoDS_Solid();
+ if(theSolid)
+ return (TopoDS_Shape*) theSolid;
+ else
+ PRINT_ERROR("OCCLump without TopoDS_Solid at %s:%d.\n", __FILE__, __LINE__ );
+ return NULL;
else if( OCCSurface *surface_ptr = CAST_TO( entity_ptr, OCCSurface))
- TopoDS_Face *theFace = surface_ptr->get_TopoDS_Face();
- if(!theFace)
- PRINT_ERROR("OCCSurface without TopoDS_Face at %s:%d.\n", __FILE__, __LINE__ );
- return NULL;
+ TopoDS_Face *theFace = surface_ptr->get_TopoDS_Face();
+ if(!theFace)
+ PRINT_ERROR("OCCSurface without TopoDS_Face at %s:%d.\n", __FILE__, __LINE__ );
+ return NULL;
+ return (TopoDS_Shape*) theFace;
- return (TopoDS_Shape*) theFace;
else if( OCCCurve *curve_ptr = CAST_TO( entity_ptr, OCCCurve))
- TopoDS_Edge *theEdge = curve_ptr->get_TopoDS_Edge();
- if (!theEdge)
- PRINT_ERROR("OCCCurve without TopoDS_Edge at %s:%d.\n", __FILE__, __LINE__ );
- return NULL;
+ TopoDS_Edge *theEdge = curve_ptr->get_TopoDS_Edge();
+ if (!theEdge)
+ PRINT_ERROR("OCCCurve without TopoDS_Edge at %s:%d.\n", __FILE__, __LINE__ );
+ return NULL;
+ return (TopoDS_Shape*) theEdge;
- return (TopoDS_Shape*) theEdge;
else if( OCCPoint *point_ptr = CAST_TO( entity_ptr, OCCPoint))
- TopoDS_Vertex *thePoint = point_ptr->get_TopoDS_Vertex();
- if (!thePoint)
- PRINT_ERROR("OCCPoint without TopoDS_Point at %s:%d.\n", __FILE__, __LINE__ );
- return NULL;
+ TopoDS_Vertex *thePoint = point_ptr->get_TopoDS_Vertex();
+ if (!thePoint)
+ PRINT_ERROR("OCCPoint without TopoDS_Point at %s:%d.\n", __FILE__, __LINE__ );
+ return NULL;
+ return (TopoDS_Shape*) thePoint;
- return (TopoDS_Shape*) thePoint;
PRINT_ERROR("Non-OCC TopologyBridge at %s:%d.\n", __FILE__, __LINE__ );
return NULL;
@@ -744,10 +744,10 @@
CubitStatus OCCQueryEngine::save_temp_geom_file( DLIList<TopologyBridge*>& ref_entity_list,
- const char *file_name,
- const CubitString &cubit_version,
- CubitString &created_file,
- CubitString &created_file_type)
+ const char *file_name,
+ const CubitString &cubit_version,
+ CubitString &created_file,
+ CubitString &created_file_type)
int size_before = ref_entity_list.size();
CubitString temp_filename(file_name);
@@ -755,18 +755,18 @@
if( export_solid_model( ref_entity_list, temp_filename.c_str(), "OCC",
cubit_version ) == CUBIT_FAILURE )
- PRINT_ERROR( "Error occured while trying to save temporary OCC_BASED_GEOMETRY file\n");
+ PRINT_ERROR( "Error occured while trying to save temporary OCC_BASED_GEOMETRY file\n");
int size_after = ref_entity_list.size();
if( size_before > size_after )
- created_file += temp_filename;
- created_file_type += "OCC";
+ created_file += temp_filename;
+ created_file_type += "OCC";
@@ -779,16 +779,16 @@
CubitStatus OCCQueryEngine::export_solid_model( DLIList<TopologyBridge*>& ref_entity_list,
- const char* file_name,
- const char* file_type,
- const CubitString &,
- const char*)
+ const char* file_name,
+ const char* file_type,
+ const CubitString &,
+ const char*)
if( strcmp( file_type, "OCC" ) != 0 )
- //PRINT_ERROR("The specified file type, %s, is not supported!\n", filetype );
+ //PRINT_ERROR("The specified file type, %s, is not supported!\n", filetype );
DLIList<OCCBody*> OCC_bodies;
DLIList<OCCSurface*> OCC_surfaces;
@@ -801,38 +801,38 @@
//Collect all free entities (bodies, curves, vertices )
ref_entity_list.reset();
for(i=ref_entity_list.size(); i>0; i--)
- TopologyBridge* ref_entity_ptr = ref_entity_list.get();
- CubitBoolean handled = CUBIT_TRUE;
+ TopologyBridge* ref_entity_ptr = ref_entity_list.get();
+ CubitBoolean handled = CUBIT_TRUE;
- //if it is a Vertex
- if( OCCPoint* pt = CAST_TO( ref_entity_ptr, OCCPoint) )
- OCC_points.append( pt );
+ //if it is a Vertex
+ if( OCCPoint* pt = CAST_TO( ref_entity_ptr, OCCPoint) )
+ OCC_points.append( pt );
- //if it is a Curve
- else if( OCCCurve* curve = CAST_TO( ref_entity_ptr, OCCCurve) )
- OCC_curves.append( curve );
+ //if it is a Curve
+ else if( OCCCurve* curve = CAST_TO( ref_entity_ptr, OCCCurve) )
+ OCC_curves.append( curve );
- //if it is a surface
- else if( OCCSurface* surf = CAST_TO( ref_entity_ptr, OCCSurface) )
- OCC_surfaces.append( surf );
+ //if it is a surface
+ else if( OCCSurface* surf = CAST_TO( ref_entity_ptr, OCCSurface) )
+ OCC_surfaces.append( surf );
- //if it is a Body
- else if( OCCBody* body = CAST_TO( ref_entity_ptr, OCCBody ) )
- OCC_bodies.append( body );
+ //if it is a Body
+ else if( OCCBody* body = CAST_TO( ref_entity_ptr, OCCBody ) )
+ OCC_bodies.append( body );
- else
- handled = CUBIT_FALSE;
+ else
+ handled = CUBIT_FALSE;
- if( handled == CUBIT_TRUE )
- ref_entities_handled.append( ref_entity_ptr );
- ref_entity_list.change_to(NULL);
+ if( handled == CUBIT_TRUE )
+ ref_entities_handled.append( ref_entity_ptr );
+ ref_entity_list.change_to(NULL);
+ ref_entity_list.step();
- ref_entity_list.step();
ref_entity_list.remove_all_with_value(NULL);
int free_body_count = OCC_bodies.size();
@@ -856,51 +856,51 @@
if( free_body_count || free_surface_count ||
free_curve_count || free_point_count )
- PRINT_INFO( "\nExported:" );
+ PRINT_INFO( "\nExported:" );
- int flg = 0;
+ int flg = 0;
- if( free_body_count )
+ if( free_body_count )
if( flg )PRINT_INFO( " " );else flg=1;
if( DEBUG_FLAG( 153 ) )
- if( free_body_count == 1 )
- PRINT_INFO( "%4d OCC Body\n", free_body_count );
- else
- PRINT_INFO( "%4d OCC Bodies\n", free_body_count );
+ if( free_body_count == 1 )
+ PRINT_INFO( "%4d OCC Body\n", free_body_count );
+ else
+ PRINT_INFO( "%4d OCC Bodies\n", free_body_count );
- if( free_surface_count )
+ if( free_surface_count )
if( free_surface_count == 1 )
- PRINT_INFO( "%4d OCC Surface\n", free_surface_count );
+ PRINT_INFO( "%4d OCC Surface\n", free_surface_count );
else
- if( free_curve_count )
+ if( free_curve_count )
if( free_curve_count == 1 )
- PRINT_INFO( "%4d OCC Curve\n", free_curve_count );
+ PRINT_INFO( "%4d OCC Curve\n", free_curve_count );
else
- PRINT_INFO( "%4d OCC Curves\n", free_curve_count );
+ PRINT_INFO( "%4d OCC Curves\n", free_curve_count );
- if( free_point_count )
+ if( free_point_count )
if( free_point_count == 1 )
- PRINT_INFO( "%4d OCC Point\n", free_point_count );
+ PRINT_INFO( "%4d OCC Point\n", free_point_count );
else
- PRINT_INFO( "%4d OCC Points\n", free_point_count );
- PRINT_INFO( "\n" );
+ PRINT_INFO( "%4d OCC Points\n", free_point_count );
+ PRINT_INFO( "\n" );
CubitStatus
@@ -919,44 +919,44 @@
//Add every shape to the compound
for (i = 0; i < OCC_bodies.size(); i++)
- OCCBody* body = OCC_bodies.get_and_step();
- TopoDS_CompSolid *shape = body->get_TopoDS_Shape();
+ OCCBody* body = OCC_bodies.get_and_step();
+ TopoDS_CompSolid *shape = body->get_TopoDS_Shape();
- //check if this body is build backwards from lump. if so,
- //the body and its CompSolid doesn't have bounded relationship
- //established. In this case, each individual lump of the body
- // will be exported as TopoDS_Solid without a CompSolid
- if(OCCMap->IsBound(*shape))
- B.Add(Co, *shape);
- else
- DLIList<Lump*> lumps = body->lumps();
- for(int i = 0; i < lumps.size(); i++)
- OCCLump *occ_lump = (OCCLump *) lumps.get_and_step();
- B.Add(Co, *(occ_lump->get_TopoDS_Solid()));
+ //check if this body is build backwards from lump. if so,
+ //the body and its CompSolid doesn't have bounded relationship
+ //established. In this case, each individual lump of the body
+ // will be exported as TopoDS_Solid without a CompSolid
+ if(OCCMap->IsBound(*shape))
+ B.Add(Co, *shape);
+ else
+ DLIList<Lump*> lumps = body->lumps();
+ for(int i = 0; i < lumps.size(); i++)
+ OCCLump *occ_lump = (OCCLump *) lumps.get_and_step();
+ B.Add(Co, *(occ_lump->get_TopoDS_Solid()));
for (i = 0; i < OCC_surfaces.size(); i++)
- TopoDS_Face *face = OCC_surfaces.get_and_step()->get_TopoDS_Face();
- B.Add(Co, *face);
+ TopoDS_Face *face = OCC_surfaces.get_and_step()->get_TopoDS_Face();
+ B.Add(Co, *face);
for (i = 0; i < OCC_curves.size(); i++)
- TopoDS_Edge *edge = OCC_curves.get_and_step()->get_TopoDS_Edge();
- B.Add(Co, *edge);
+ TopoDS_Edge *edge = OCC_curves.get_and_step()->get_TopoDS_Edge();
+ B.Add(Co, *edge);
for (i = 0; i < OCC_points.size(); i++)
- TopoDS_Vertex *vertex = OCC_points.get_and_step()->get_TopoDS_Vertex();
- B.Add(Co, *vertex);
+ TopoDS_Vertex *vertex = OCC_points.get_and_step()->get_TopoDS_Vertex();
+ B.Add(Co, *vertex);
char* file = new char[sizeof(file_name)];
strcpy(file, file_name);
@@ -982,17 +982,17 @@
CubitStatus OCCQueryEngine::import_solid_model(
- const char* file_name ,
- DLIList<TopologyBridge*> &imported_entities,
- CubitBoolean print_results,
- const char* logfile_name,
- CubitBoolean heal_step,
- CubitBoolean import_bodies,
- CubitBoolean import_surfaces,
- CubitBoolean import_curves,
- CubitBoolean import_vertices,
- CubitBoolean free_surfaces)
+ const char* file_name ,
+ DLIList<TopologyBridge*> &imported_entities,
+ CubitBoolean print_results,
+ const char* logfile_name,
+ CubitBoolean heal_step,
+ CubitBoolean import_bodies,
+ CubitBoolean import_surfaces,
+ CubitBoolean import_curves,
+ CubitBoolean import_vertices,
+ CubitBoolean free_surfaces)
TopoDS_Shape *aShape = new TopoDS_Shape;
BRep_Builder aBuilder;
@@ -1006,253 +1006,253 @@
DLIList<TopologyBridge*> OCCQueryEngine::populate_topology_bridge(TopoDS_Shape aShape)
- DLIList<TopologyBridge*> tblist;
- // suitable to popolate for a TopoDS_CompSolid or TopoDS_Compound shape.
- TopExp_Explorer Ex;
- for (Ex.Init(aShape, TopAbs_COMPSOLID); Ex.More(); Ex.Next())
- tblist.append(populate_topology_bridge(TopoDS::CompSolid(Ex.Current())));
+ DLIList<TopologyBridge*> tblist;
+ // suitable to popolate for a TopoDS_CompSolid or TopoDS_Compound shape.
+ TopExp_Explorer Ex;
+ for (Ex.Init(aShape, TopAbs_COMPSOLID); Ex.More(); Ex.Next())
+ tblist.append(populate_topology_bridge(TopoDS::CompSolid(Ex.Current())));
- for (Ex.Init(aShape, TopAbs_SOLID, TopAbs_COMPSOLID); Ex.More(); Ex.Next())
- tblist.append(populate_topology_bridge(TopoDS::Solid(Ex.Current()), CUBIT_TRUE));
+ for (Ex.Init(aShape, TopAbs_SOLID, TopAbs_COMPSOLID); Ex.More(); Ex.Next())
+ tblist.append(populate_topology_bridge(TopoDS::Solid(Ex.Current()), CUBIT_TRUE));
- for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID); Ex.More(); Ex.Next())
- tblist.append(populate_topology_bridge(TopoDS::Shell(Ex.Current())));
+ for (Ex.Init(aShape, TopAbs_SHELL, TopAbs_SOLID); Ex.More(); Ex.Next())
+ tblist.append(populate_topology_bridge(TopoDS::Shell(Ex.Current())));
- for (Ex.Init(aShape, TopAbs_FACE, TopAbs_SHELL); Ex.More(); Ex.Next())
- tblist.append(populate_topology_bridge(TopoDS::Face(Ex.Current())));
+ for (Ex.Init(aShape, TopAbs_FACE, TopAbs_SHELL); Ex.More(); Ex.Next())
+ tblist.append(populate_topology_bridge(TopoDS::Face(Ex.Current())));
- for (Ex.Init(aShape, TopAbs_WIRE, TopAbs_FACE); Ex.More(); Ex.Next())
- tblist.append(populate_topology_bridge(TopoDS::Wire(Ex.Current())));
+ for (Ex.Init(aShape, TopAbs_WIRE, TopAbs_FACE); Ex.More(); Ex.Next())
+ tblist.append(populate_topology_bridge(TopoDS::Wire(Ex.Current())));
- for (Ex.Init(aShape, TopAbs_EDGE, TopAbs_WIRE); Ex.More(); Ex.Next())
- tblist.append(populate_topology_bridge(TopoDS::Edge(Ex.Current())));
+ for (Ex.Init(aShape, TopAbs_EDGE, TopAbs_WIRE); Ex.More(); Ex.Next())
+ tblist.append(populate_topology_bridge(TopoDS::Edge(Ex.Current())));
- for (Ex.Init(aShape, TopAbs_VERTEX, TopAbs_EDGE); Ex.More(); Ex.Next())
- tblist.append(populate_topology_bridge(TopoDS::Vertex(Ex.Current())));
- return tblist;
+ for (Ex.Init(aShape, TopAbs_VERTEX, TopAbs_EDGE); Ex.More(); Ex.Next())
+ tblist.append(populate_topology_bridge(TopoDS::Vertex(Ex.Current())));
+ return tblist;
BodySM* OCCQueryEngine::populate_topology_bridge(TopoDS_CompSolid aShape)
- TopoDS_CompSolid *posolid = new TopoDS_CompSolid;
- *posolid = aShape;
- OCCBody *body;
- if (!OCCMap->IsBound(*posolid))
- if(*PRINT_RESULT)
- PRINT_INFO("Adding Bodies.\n");
- (iTotalTBCreated)++;
- body = new OCCBody(posolid);
- OCCMap->Bind(*posolid, iTotalTBCreated);
- OccToCGM->insert(valType(iTotalTBCreated,
- (TopologyBridge*)body));
- BodyList->append(body);
- else
- int k = OCCMap->Find(*posolid);
- body = (OCCBody*)(OccToCGM->find(k))->second;
- DLIList<Lump*> lumps;
- for (Ex.Init(aShape, TopAbs_SOLID); Ex.More(); Ex.Next())
- Lump* lump = populate_topology_bridge(TopoDS::Solid(Ex.Current()));
- lumps.append(lump);
- CAST_TO(lump, OCCLump)->add_body(body);
- body->lumps(lumps);
- return body;
+ TopoDS_CompSolid *posolid = new TopoDS_CompSolid;
+ *posolid = aShape;
+ OCCBody *body;
+ if (!OCCMap->IsBound(*posolid))
+ if(*PRINT_RESULT)
+ PRINT_INFO("Adding Bodies.\n");
+ (iTotalTBCreated)++;
+ body = new OCCBody(posolid);
+ OCCMap->Bind(*posolid, iTotalTBCreated);
+ OccToCGM->insert(valType(iTotalTBCreated,
+ (TopologyBridge*)body));
+ BodyList->append(body);
+ else
+ int k = OCCMap->Find(*posolid);
+ body = (OCCBody*)(OccToCGM->find(k))->second;
+ DLIList<Lump*> lumps;
+ for (Ex.Init(aShape, TopAbs_SOLID); Ex.More(); Ex.Next())
+ Lump* lump = populate_topology_bridge(TopoDS::Solid(Ex.Current()));
+ lumps.append(lump);
+ CAST_TO(lump, OCCLump)->add_body(body);
+ body->lumps(lumps);
+ return body;
Lump* OCCQueryEngine::populate_topology_bridge(TopoDS_Solid aShape,
CubitBoolean build_body)
- //one OCCBody corresponds one OCCLump
- TopoDS_Solid *posolid = new TopoDS_Solid;
- OCCLump *lump;
- OCCBody *body;
- if(*PRINT_RESULT)
- PRINT_INFO("Adding solids.\n");
- iTotalTBCreated++;
- lump = new OCCLump(posolid);
- if (build_body)
- body = new OCCBody(lumps);
- lump->add_body(body);
- (TopologyBridge*)lump));
- else
+ //one OCCBody corresponds one OCCLump
+ TopoDS_Solid *posolid = new TopoDS_Solid;
+ OCCLump *lump;
+ OCCBody *body;
+ if(*PRINT_RESULT)
+ PRINT_INFO("Adding solids.\n");
+ iTotalTBCreated++;
+ lump = new OCCLump(posolid);
+ if (build_body)
- lump = (OCCLump*)(OccToCGM->find(k))->second;
+ body = new OCCBody(lumps);
+ lump->add_body(body);
- for (Ex.Init(aShape, TopAbs_SHELL); Ex.More(); Ex.Next())
- populate_topology_bridge(TopoDS::Shell(Ex.Current()));
- return lump;
+ (TopologyBridge*)lump));
+ else
+ lump = (OCCLump*)(OccToCGM->find(k))->second;
+ for (Ex.Init(aShape, TopAbs_SHELL); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Shell(Ex.Current()));
+ return lump;
OCCShell* OCCQueryEngine::populate_topology_bridge(TopoDS_Shell aShape)
- TopoDS_Shell *poshell = new TopoDS_Shell;
- *poshell = aShape;
- OCCShell *shell ;
- if (!OCCMap->IsBound(*poshell))
- if(*PRINT_RESULT)
- PRINT_INFO("Adding shells.\n");
- shell = new OCCShell(poshell);
- OCCMap->Bind(*poshell, iTotalTBCreated);
- (TopologyBridge*)shell));
- else
- int k = OCCMap->Find(*poshell);
- shell = (OCCShell*)(OccToCGM->find(k))->second;
+ TopoDS_Shell *poshell = new TopoDS_Shell;
+ *poshell = aShape;
+ OCCShell *shell ;
+ if (!OCCMap->IsBound(*poshell))
+ if(*PRINT_RESULT)
+ PRINT_INFO("Adding shells.\n");
+ shell = new OCCShell(poshell);
+ OCCMap->Bind(*poshell, iTotalTBCreated);
+ (TopologyBridge*)shell));
+ else
+ int k = OCCMap->Find(*poshell);
+ shell = (OCCShell*)(OccToCGM->find(k))->second;
- for (Ex.Init(aShape, TopAbs_FACE); Ex.More(); Ex.Next())
- populate_topology_bridge(TopoDS::Face(Ex.Current()));
- return shell;
+ for (Ex.Init(aShape, TopAbs_FACE); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Face(Ex.Current()));
+ return shell;
Surface* OCCQueryEngine::populate_topology_bridge(TopoDS_Face aShape)
- TopoDS_Face *poface = new TopoDS_Face;
- *poface = aShape;
- OCCSurface *surface;
- if (!OCCMap->IsBound(*poface))
- if(*PRINT_RESULT)
- PRINT_INFO("Adding faces.\n");
- surface = new OCCSurface(poface);
+ TopoDS_Face *poface = new TopoDS_Face;
+ *poface = aShape;
+ OCCSurface *surface;
+ if (!OCCMap->IsBound(*poface))
+ if(*PRINT_RESULT)
+ PRINT_INFO("Adding faces.\n");
+ surface = new OCCSurface(poface);
- OCCMap->Bind(*poface, iTotalTBCreated);
- (TopologyBridge*)surface));
- SurfaceList->append(surface);
- else
- int k = OCCMap->Find(*poface);
- surface = (OCCSurface*)(OccToCGM->find(k))->second;
- for (Ex.Init(aShape, TopAbs_WIRE); Ex.More(); Ex.Next())
- populate_topology_bridge(TopoDS::Wire(Ex.Current()));
+ OCCMap->Bind(*poface, iTotalTBCreated);
+ (TopologyBridge*)surface));
+ SurfaceList->append(surface);
+ else
+ int k = OCCMap->Find(*poface);
+ surface = (OCCSurface*)(OccToCGM->find(k))->second;
+ for (Ex.Init(aShape, TopAbs_WIRE); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Wire(Ex.Current()));
- return surface;
+ return surface;
OCCLoop* OCCQueryEngine::populate_topology_bridge(TopoDS_Wire aShape)
- TopoDS_Wire *powire = new TopoDS_Wire;
- *powire = aShape;
- OCCLoop *loop ;
- if (!OCCMap->IsBound(*powire))
- if(*PRINT_RESULT)
- PRINT_INFO("Adding loops.\n");
- loop = new OCCLoop(powire);
- OCCMap->Bind(*powire, iTotalTBCreated);
- (TopologyBridge*)loop));
- else
- int k = OCCMap->Find(*powire);
- loop = (OCCLoop*)(OccToCGM->find(k))->second;
+ TopoDS_Wire *powire = new TopoDS_Wire;
+ *powire = aShape;
+ OCCLoop *loop ;
+ if (!OCCMap->IsBound(*powire))
+ if(*PRINT_RESULT)
+ PRINT_INFO("Adding loops.\n");
+ loop = new OCCLoop(powire);
+ OCCMap->Bind(*powire, iTotalTBCreated);
+ (TopologyBridge*)loop));
+ else
+ int k = OCCMap->Find(*powire);
+ loop = (OCCLoop*)(OccToCGM->find(k))->second;
- BRepTools_WireExplorer Ex;
- DLIList <OCCCoEdge*> coedges;
- for (Ex.Init(aShape); Ex.More(); Ex.Next())
- Curve* curve = populate_topology_bridge(Ex.Current());
- OCCCurve *occ_curve = CAST_TO(curve, OCCCurve);
- OCCCoEdge * coedge = new OCCCoEdge( curve, loop,
- (Ex.Orientation()== TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED));
- coedges.append(coedge);
- occ_curve->add_loop(loop);
- loop->coedges(coedges);
+ BRepTools_WireExplorer Ex;
+ DLIList <OCCCoEdge*> coedges;
+ for (Ex.Init(aShape); Ex.More(); Ex.Next())
+ Curve* curve = populate_topology_bridge(Ex.Current());
+ OCCCurve *occ_curve = CAST_TO(curve, OCCCurve);
+ OCCCoEdge * coedge = new OCCCoEdge( curve, loop,
+ (Ex.Orientation()== TopAbs_FORWARD ? CUBIT_FORWARD : CUBIT_REVERSED));
+ coedges.append(coedge);
+ occ_curve->add_loop(loop);
+ loop->coedges(coedges);
- return loop;
+ return loop;
Curve* OCCQueryEngine::populate_topology_bridge(TopoDS_Edge aShape)
- Curve *curve;
- TopoDS_Edge *poedge = new TopoDS_Edge;
- *poedge = aShape;
- if (!OCCMap->IsBound(*poedge))
- if(*PRINT_RESULT)
- PRINT_INFO("Adding edges.\n");
- curve = new OCCCurve(poedge);
- OCCMap->Bind(*poedge, iTotalTBCreated);
- (TopologyBridge*)curve));
- CurveList->append((OCCCurve*)curve);
- else
- int i = OCCMap->Find(*poedge);
- curve = (OCCCurve*)(OccToCGM->find(i))->second;
+ Curve *curve;
+ TopoDS_Edge *poedge = new TopoDS_Edge;
+ *poedge = aShape;
+ if (!OCCMap->IsBound(*poedge))
+ if(*PRINT_RESULT)
+ PRINT_INFO("Adding edges.\n");
+ curve = new OCCCurve(poedge);
+ OCCMap->Bind(*poedge, iTotalTBCreated);
+ (TopologyBridge*)curve));
+ CurveList->append((OCCCurve*)curve);
+ else
+ int i = OCCMap->Find(*poedge);
+ curve = (OCCCurve*)(OccToCGM->find(i))->second;
- for (Ex.Init(aShape, TopAbs_VERTEX); Ex.More(); Ex.Next())
- populate_topology_bridge(TopoDS::Vertex(Ex.Current()));
- return curve;
+ for (Ex.Init(aShape, TopAbs_VERTEX); Ex.More(); Ex.Next())
+ populate_topology_bridge(TopoDS::Vertex(Ex.Current()));
+ return curve;
Point* OCCQueryEngine::populate_topology_bridge(TopoDS_Vertex aShape)
- OCCPoint *point;
- TopoDS_Vertex *povertex = new TopoDS_Vertex;
- *povertex = aShape;
- if (!OCCMap->IsBound(*povertex))
- if(*PRINT_RESULT)
- PRINT_INFO("Adding vertices.\n");
- point = new OCCPoint(povertex);
- OCCMap->Bind(*povertex, iTotalTBCreated);
- (TopologyBridge*)point));
- else
- int i = OCCMap->Find(*povertex);
- point = (OCCPoint*)(OccToCGM->find(i))->second;
- return point;
+ OCCPoint *point;
+ TopoDS_Vertex *povertex = new TopoDS_Vertex;
+ *povertex = aShape;
+ if (!OCCMap->IsBound(*povertex))
+ if(*PRINT_RESULT)
+ PRINT_INFO("Adding vertices.\n");
+ point = new OCCPoint(povertex);
+ OCCMap->Bind(*povertex, iTotalTBCreated);
+ (TopologyBridge*)point));
+ else
+ int i = OCCMap->Find(*povertex);
+ point = (OCCPoint*)(OccToCGM->find(i))->second;
+ return point;
TopologyBridge* OCCQueryEngine::occ_to_cgm(TopoDS_Shape shape)
- if(!OCCMap->IsBound(shape))
- return (TopologyBridge*) NULL;
+ if(!OCCMap->IsBound(shape))
+ return (TopologyBridge*) NULL;
- int k = OCCMap->Find(shape);
- return (OccToCGM->find(k))->second;
+ int k = OCCMap->Find(shape);
+ return (OccToCGM->find(k))->second;
@@ -1269,10 +1269,10 @@
BodySM* BodyPtr = NULL;
for (int i = 0; i < bodyList.size(); i++ )
- BodyPtr = bodyList.get_and_step();
- this->delete_solid_model_entities(BodyPtr);
+ BodyPtr = bodyList.get_and_step();
+ this->delete_solid_model_entities(BodyPtr);
return;
@@ -1301,28 +1301,28 @@
//remove the entry from the map
int k;
- k = OCCMap->Find(*shape);
+ k = OCCMap->Find(*shape);
- if(!OCCMap->UnBind(*shape))
- PRINT_ERROR("The OccBody and TopoDS_Shape pair is not in the map!");
+ if(!OCCMap->UnBind(*shape))
+ PRINT_ERROR("The OccBody and TopoDS_Shape pair is not in the map!");
- OCCBody* occ_body_find = (OCCBody*)(OccToCGM->find(k))->second;
- BodyList->remove(occ_body_find);
+ OCCBody* occ_body_find = (OCCBody*)(OccToCGM->find(k))->second;
+ BodyList->remove(occ_body_find);
- if(!OccToCGM->erase(k))
+ if(!OccToCGM->erase(k))
else //check for all lumps for deletion, this body was generated
- //by its OCCLumps
- for(int i =0; i < occ_body->lumps().size(); i++)
- Lump* lump = occ_body->lumps().get_and_step();
- delete_solid_model_entities(lump);
+ //by its OCCLumps
+ for(int i =0; i < occ_body->lumps().size(); i++)
+ Lump* lump = occ_body->lumps().get_and_step();
+ delete_solid_model_entities(lump);
// Remove the links between OCC and Cubit
// unhook_ENTITY_from_VGI(shape);
@@ -1352,20 +1352,20 @@
TopoDS_Solid* solid = occ_lump->get_TopoDS_Solid();
if(!solid)
int k;
if(OCCMap->IsBound(*solid))
- k = OCCMap->Find(*solid);
+ k = OCCMap->Find(*solid);
- if(!OCCMap->UnBind(*solid))
- PRINT_ERROR("The OccSurface and TopoDS_Face pair is not in the map!");
+ if(!OCCMap->UnBind(*solid))
+ PRINT_ERROR("The OccSurface and TopoDS_Face pair is not in the map!");
// unhook_ENTITY_from_VGI(face);
@@ -1394,22 +1394,22 @@
TopoDS_Face* face = fsurf->get_TopoDS_Face();
if(!face)
int k;
if(OCCMap->IsBound(*face))
- k = OCCMap->Find(*face);
+ k = OCCMap->Find(*face);
- if(!OCCMap->UnBind(*face))
+ if(!OCCMap->UnBind(*face))
- SurfaceList->remove((OCCSurface*)(OccToCGM->find(k))->second);
+ SurfaceList->remove((OCCSurface*)(OccToCGM->find(k))->second);
@@ -1442,16 +1442,16 @@
int k;
if(OCCMap->IsBound(*edge))
- k = OCCMap->Find(*edge);
+ k = OCCMap->Find(*edge);
- if(!OCCMap->UnBind(*edge))
- PRINT_ERROR("The OccCurve and TopoDS_Edge pair is not in the map!");
+ if(!OCCMap->UnBind(*edge))
+ PRINT_ERROR("The OccCurve and TopoDS_Edge pair is not in the map!");
- CurveList->remove((OCCCurve*)(OccToCGM->find(k))->second);
+ CurveList->remove((OCCCurve*)(OccToCGM->find(k))->second);
//unhook_ENTITY_from_VGI(edge);
@@ -1484,15 +1484,15 @@
int k;
if(OCCMap->IsBound(*vertex))
- k = OCCMap->Find(*vertex);
+ k = OCCMap->Find(*vertex);
- if(!OCCMap->UnBind(*vertex))
- PRINT_ERROR("The OccPoint and TopoDS_Vertex pair is not in the map!");
+ if(!OCCMap->UnBind(*vertex))
+ PRINT_ERROR("The OccPoint and TopoDS_Vertex pair is not in the map!");
//unhook_ENTITY_from_VGI(vertex);
@@ -1506,7 +1506,7 @@
const CubitVector &start,
const CubitVector &unit,
DLIList<double>& ray_parms,
- DLIList<GeometryEntity*> *entity_list) const
+ DLIList<GeometryEntity*> *entity_list) const
CubitStatus status = CUBIT_SUCCESS;
@@ -1520,36 +1520,36 @@
OCCBody *occBody = CAST_TO(body, OCCBody);
if (occBody == NULL)
BRepExtrema_DistShapeShape distShapeShape(edge,
- *(occBody->get_TopoDS_Shape()));
+ *(occBody->get_TopoDS_Shape()));
- PRINT_ERROR("Cannot calculate the intersection points for the input body.\n");
+ PRINT_ERROR("Cannot calculate the intersection points for the input body.\n");
- if (distShapeShape.Value() < get_sme_resabs_tolerance())
- double para;
- distShapeShape.ParOnEdgeS1(i , para);
- ray_parms.append(para);
+ if (distShapeShape.Value() < get_sme_resabs_tolerance())
+ double para;
+ distShapeShape.ParOnEdgeS1(i , para);
+ ray_parms.append(para);
- TopoDS_Shape shape = distShapeShape.SupportOnShape2(i);
- std::map<int,TopologyBridge*>::iterator it = OccToCGM->find(k);
- TopologyBridge* tb = (*it).second;
- entity_list->append((GeometryEntity*)tb);
+ TopoDS_Shape shape = distShapeShape.SupportOnShape2(i);
+ std::map<int,TopologyBridge*>::iterator it = OccToCGM->find(k);
+ TopologyBridge* tb = (*it).second;
+ entity_list->append((GeometryEntity*)tb);
return status;
double OCCQueryEngine::get_sme_resabs_tolerance() const
@@ -1582,7 +1582,7 @@
PRINT_ERROR("OCCQueryEngine::set_str_option not yet implemented.\n");
- //- Set solid modeler options
+//- Set solid modeler options
@@ -1597,20 +1597,20 @@
char line[128]="";
if (fgets(line, 128, fp)==NULL)
- if (strlen(line)==127)
- if (fgets(line, 128, fp)==NULL)
+ if (strlen(line)==127)
+ if (fgets(line, 128, fp)==NULL)
unsigned int dummy_int=0;
@@ -1618,54 +1618,54 @@
while (isspace(line[dummy_int])&& dummy_int<strlen(line)) dummy_int++;
if (strlen(line)-dummy_int>5)
- if (tolower(line[dummy_int++])=='f' &&
- tolower(line[dummy_int++])=='a' &&
- tolower(line[dummy_int++])=='c' &&
- tolower(line[dummy_int++])=='e' &&
- tolower(line[dummy_int])=='t')
- dummy_int=0;
- while (isspace(line[dummy_int])&& dummy_int<strlen(line))
- dummy_int++;
- if (strlen(line)-dummy_int>5)
- if (tolower(line[dummy_int++])=='o' &&
- tolower(line[dummy_int++])=='u' &&
- tolower(line[dummy_int++])=='t' &&
- tolower(line[dummy_int])=='r')
- dummy_int=0;
- while (isspace(line[dummy_int])&& dummy_int<strlen(line)) {
- dummy_int++;
- if (strlen(line)-dummy_int>6)
- if (tolower(line[dummy_int++])=='v' &&
- tolower(line[dummy_int++])=='r' &&
- tolower(line[dummy_int])=='x')
- is_ascii=CUBIT_TRUE;
+ if (tolower(line[dummy_int++])=='f' &&
+ tolower(line[dummy_int++])=='a' &&
+ tolower(line[dummy_int++])=='c' &&
+ tolower(line[dummy_int++])=='e' &&
+ tolower(line[dummy_int])=='t')
+ dummy_int=0;
+ while (isspace(line[dummy_int])&& dummy_int<strlen(line))
+ dummy_int++;
+ if (strlen(line)-dummy_int>5)
+ if (tolower(line[dummy_int++])=='o' &&
+ tolower(line[dummy_int++])=='u' &&
+ tolower(line[dummy_int++])=='t' &&
+ tolower(line[dummy_int])=='r')
+ dummy_int=0;
+ while (isspace(line[dummy_int])&& dummy_int<strlen(line)) {
+ dummy_int++;
+ if (strlen(line)-dummy_int>6)
+ if (tolower(line[dummy_int++])=='v' &&
+ tolower(line[dummy_int++])=='r' &&
+ tolower(line[dummy_int])=='x')
+ is_ascii=CUBIT_TRUE;
@@ -1677,12 +1677,12 @@
//Date: 12/15/03
CubitStatus OCCQueryEngine::create_super_bounding_box(
- DLIList<BodySM*>& body_list,
- CubitBox& super_box )
+ DLIList<BodySM*>& body_list,
+ CubitBox& super_box )
-BodySM *bodySM;
-int i;
-CubitStatus status = CUBIT_SUCCESS;
+ BodySM *bodySM;
+ int i;
+ CubitStatus status = CUBIT_SUCCESS;
body_list.reset();
for ( i = 0; i < body_list.size(); i++ ) {
@@ -1736,11 +1736,11 @@
TopoDS_Shape * shape;
if ((shape = get_TopoDS_Shape_of_entity(entity)) == NULL)
- " Aborting.\n" );
+ " Aborting.\n" );
gp_Vec aVec(v.x(), v.y(),v.z());
gp_Trsf aTrsf;
@@ -1756,11 +1756,11 @@
- " Aborting.\n" );
+ " Aborting.\n" );
gp_Pnt aOrigin(0,0,0);
gp_Dir aDir(v.x(), v.y(), v.z());
@@ -1778,11 +1778,11 @@
- " Aborting.\n" );
+ " Aborting.\n" );
gp_Trsf aTrsf;
aTrsf.SetScaleFactor(f);
@@ -1803,11 +1803,11 @@
- " Aborting.\n" );
+ " Aborting.\n" );
@@ -1832,17 +1832,17 @@
OCCBody *occ_body1 = CAST_TO(body_ptr_1, OCCBody);
if (!occ_body1)
- PRINT_ERROR("Can't calculate intersection of non-OCC bodies.");
- return CUBIT_FALSE;
+ PRINT_ERROR("Can't calculate intersection of non-OCC bodies.");
+ return CUBIT_FALSE;
OCCBody *occ_body2 = CAST_TO(body_ptr_2, OCCBody);
if (!occ_body2)
CubitBox box_1 = occ_body1->get_bounding_box();
CubitBox box_2 = occ_body2->get_bounding_box();
@@ -1855,20 +1855,20 @@
//BRepAlgoAPI_Section calculates intersection between faces only.
TopExp_Explorer Ex1, Ex2;
for (Ex1.Init(*shape1, TopAbs_SOLID); Ex1.More(); Ex1.Next())
- TopoDS_Solid *posolid1 = new TopoDS_Solid;
- *posolid1 = TopoDS::Solid(Ex1.Current());
- OCCLump * lump1 = new OCCLump(posolid1);
- for (Ex2.Init(*shape2, TopAbs_SOLID); Ex2.More(); Ex2.Next())
- TopoDS_Solid *posolid2 = new TopoDS_Solid;
- *posolid2 = TopoDS::Solid(Ex2.Current());
- OCCLump * lump2 = new OCCLump(posolid2);
- CubitBoolean is_overlap = volumes_overlap(lump1, lump2);
- if(is_overlap)
- return CUBIT_TRUE;
+ TopoDS_Solid *posolid1 = new TopoDS_Solid;
+ *posolid1 = TopoDS::Solid(Ex1.Current());
+ OCCLump * lump1 = new OCCLump(posolid1);
+ for (Ex2.Init(*shape2, TopAbs_SOLID); Ex2.More(); Ex2.Next())
+ TopoDS_Solid *posolid2 = new TopoDS_Solid;
+ *posolid2 = TopoDS::Solid(Ex2.Current());
+ OCCLump * lump2 = new OCCLump(posolid2);
+ CubitBoolean is_overlap = volumes_overlap(lump1, lump2);
+ if(is_overlap)
+ return CUBIT_TRUE;
return CUBIT_FALSE;
@@ -1876,17 +1876,17 @@
OCCLump *occ_lump1 = CAST_TO(lump1, OCCLump);
if (!occ_lump1)
- PRINT_ERROR("Can't calculate intersection of non-OCC solids.");
+ PRINT_ERROR("Can't calculate intersection of non-OCC solids.");
OCCLump *occ_lump2 = CAST_TO(lump2, OCCLump);
if (!occ_lump2)
CubitBox box_1 = occ_lump1->bounding_box();
CubitBox box_2 = occ_lump2->bounding_box();
@@ -1899,14 +1899,14 @@
for (Ex1.Init(*shape1, TopAbs_FACE); Ex1.More(); Ex1.Next())
- for (Ex2.Init(*shape2, TopAbs_FACE); Ex2.More(); Ex2.Next())
- BRepAlgoAPI_Section section(Ex1.Current(), Ex2.Current());
- if (section.HasGenerated())
+ for (Ex2.Init(*shape2, TopAbs_FACE); Ex2.More(); Ex2.Next())
+ BRepAlgoAPI_Section section(Ex1.Current(), Ex2.Current());
+ if (section.HasGenerated())
return CUBIT_FALSE;
Modified: cgm/trunk/geom/OCC/OCCShell.cpp
--- cgm/trunk/geom/OCC/OCCShell.cpp 2007-12-04 19:09:23 UTC (rev 1438)
+++ cgm/trunk/geom/OCC/OCCShell.cpp 2007-12-05 19:09:43 UTC (rev 1439)
@@ -67,6 +67,25 @@
+// Purpose : Get the bounding box of the object.
+// Special Notes :
+CubitBox OCCShell::bounding_box() const
+ CubitBox cBox;
+ DLIList<TopologyBridge*> surfs;
+ get_children_virt(surfs);
+ for(int i = 0; i < surfs.size(); i ++)
+ OCCSurface* occ_surf = CAST_TO(surfs.get_and_step(), OCCSurface);
+ cBox |= occ_surf->bounding_box();
+ return cBox;
// Purpose : Get geometry modeling engine: OCCQueryEngine
// Special Notes :
@@ -142,7 +161,6 @@
// ********** END PUBLIC FUNCTIONS **********
// ********** BEGIN PROTECTED FUNCTIONS **********
More information about the cgma-dev
