[AG-USERS] import agversion - No module named agversion
Thomas D. Uram
turam at mcs.anl.gov
Thu Jul 31 10:07:57 CDT 2008
Do you have multiple versions of Python installed? It could be that a
Python other than the 2.4 version is being invoked when you run agpm3.py
on the command line. You can check this like so on the command line:
ftype Python.File
and see if it references Python 2.4.
You can work around this by using the correct python on the command line:
c:\python24\python agpm3.py
Or by changing the association for .py files. See the ftype command for
this.
Tom
On 7/31/08 2:32 AM, Garry Keltie wrote:
> Hi List,
> I am on WinXP and AG3.1 and trying to run a VenueVNC Server as per:
> http://www.accessgrid.org/node/1031
> VenueVNC reports to be installed but when attempting to run it I get
> the following. I realise the error is a bit generic but am having
> trouble finding why its stopping me.
> C:\Program Files\AGTk-3\bin>agpm3.py
> Traceback (most recent call last):
> File "C:\Program Files\AGTk-3\bin\agpm3.py", line 25, in ?
> import agversion
> ImportError: No module named agversion
> The closest I can get is:
> http://www-unix.mcs.anl.gov/web-mail-archive/lists/ag-tech/2006/11/msg00070.html
> But I read that this is only an issue on OSX? (at least the shell env
> fix for it anyway)
> agversion is sitting there in C:\Python\Python24\Lib\site-packages and
> python can deal with double clicking on .py files.
> Any help appreciated.
> Cheers
> Garry
More information about the ag-users
