[AG-USERS] transmitting video in AGTk-2.3 vic...
Jennifer Parham
jparham at cs.clemson.edu
Mon Jun 6 12:26:57 CDT 2005
Thank you John and Andrew. I definitely had the video services configured
wrong! Dumb, dumb:)
Now when I transmit, I get two pictures on my end. Is this normal? Do the
other sites see both pictures or just one?
Thanks again,
Jennifer
-----Original Message-----
From: John I Quebedeaux Jr [mailto:johnq at lsu.edu]
Sent: Friday, June 03, 2005 5:13 PM
To: Parham Jennifer R
Cc: ag-users at mcs.anl.gov
Subject: Re: [AG-USERS] transmitting video in AGTk-2.3 vic...
I *think* that sounds like that's the "consumer" vic. You need to configure
your "producers" in the node manager for your node. It's been quite some
time so I don't recall if that was a change going from AG 2.0? 2.1? to 2.1.2
or greater. But the consumer vic does not give you the transmit option.
I'm assuming that this is a single machine node from what you're saying?
-John Q.
John I. Quebedeaux, Jr.
Louisiana State University
Computer Manager / LBRN & CCT / 131 Life Sciences Bldg. & 339 Johnston Hall
e-mail: johnq at lsu.edu or johnq at cct.lsu.edu / web: http://lbrn.lsu.edu &
http://cct.lsu.edu
phone: 225-578-0062 / fax: 225-578-2597
On Jun 3, 2005, at 2:40 PM, Parham Jennifer R wrote:
Hi-
I have installed and set up the AGTk-2.3. When I go into
a venue, I can see all the videos of the people transmitting,
but when I go to the menu option in the vic, I can't select
the transmit button. I have made sure in the node configuration
that the video and audio services are available, but the
transmit button is continually grey.
I have an older version of the Access Grid on my laptop, and I
don't remember doing anything special to transmit using vic.
Also, my camera doesn't have to be connected to have the transmit
option available in vic, using the Access Grid Toolkit 2. Even
when I attach the camera in AGTk-2.3, the transmit button is still
grey, so I am at a loss.
Help???:):)
Jennifer
Jennifer Parham, Clemson University Computer Science Dept.
------- End of Forwarded Message -------
URL: <http://lists.mcs.anl.gov/pipermail/ag-users/attachments/20050606/b6091909/attachment.htm>
More information about the ag-users
