[AG-USERS] Passphrase Trouble and Lauching PIG App
James Avery
ja42 at cornell.edu
Wed Oct 27 09:45:47 CDT 2004
Folks,
Having troubles with the field of pass phrase where the screen is "Create
Global proxy"
Create a proxy for O=Access Grid, OU=agdev-ca.mcs.anl.gov, OU=
cornell.edu, CN= Jim Avery
Then it prompts a passphrase blank field:
Since the certificate file can not found anywhere from a previous install,
I am somewhat stuck.
I am able to launch the application and go yo Venue Client but the first
prompt is "Create Global proxy".
What do you do when you can not locate a certficate file and how do you
have one created or recreated?
I have installed successfully the Active Python 2.3, wxPython 2.5 for 2.3
and Access Grid Tool kit 2.3 as followed in the install instructions.
Any help will do so I can get up and running.
Jim Avery
More information about the ag-users
