[AG-TECH] MacOS vic for 3.3 not H264 enabled??
Douglas Kosovic
doug at uq.edu.au
Fri Feb 17 03:44:40 CST 2012
Hi Andrew,
I don't know if anybody has done any current Video Services packages with GPL VIC on MacOS X. There was talk of packaging them up when a new improved RAT for MacOS X was ready for release.
I'm running MacOS X 10.7 (Lion) on both my Macs at home so can't create Video Service packages that will work on earlier versions of MacOS X, ideally is should be built on Leopard so they would work on later releases.
Cheers,
Doug
On 17/02/2012, at 3:12 AM, Andrew Ford wrote:
> Hi Doug,
> Aren't there packages (VideoProducerServiceH264 etc.) available for vic on the mac? Really I don't see why the GPL vic isn't bundled with AG by default already, but besides that, end users shouldn't have to compile it themselves either.
> --Andrew
> On Wed, Feb 15, 2012 at 8:14 PM, Douglas Kosovic <doug at uq.edu.au> wrote:
> Hi Gurcharan,
> > i am running the 3.3 version of AG for MacOS on an iMac and Snow Leopard,
> > and the vic windows are all gray even though bits are flowing.
> > if i run an older version of vic the windows render normally.
> > is H264 not enabled on the 3.3 version?
> The default 3 clause BSD license VIC doesn't have the patent encumbered stuff enabled. The GPL VIC does and can be built on Leopard to Lion with the following on the command-line, you'll also need to install the yasm assembler which is available from ( http://yasm.tortall.net/Download.html ) :
> svn co https://mediatools.cs.ucl.ac.uk/repos/mmedia/common/trunk common
> svn co https://mediatools.cs.ucl.ac.uk/repos/mmedia/vic/branches/mpeg4 vic
> ( cd common; ./configure ; make )
> cd vic
> ./configure --enable-gpl
> make
> The --enable-gpl option downloads and builds x264 and ffmpeg required for H264 and mpeg-4 support.
> Cheers,
> Doug
