[AG-TECH] MacOS vic for 3.3 not H264 enabled??
Andrew Ford
andrew.ford at rit.edu
Thu Feb 16 11:12:58 CST 2012
Hi Doug,
Aren't there packages (VideoProducerServiceH264 etc.) available for vic on
the mac? Really I don't see why the GPL vic isn't bundled with AG by
default already, but besides that, end users shouldn't have to compile it
themselves either.
--Andrew
On Wed, Feb 15, 2012 at 8:14 PM, Douglas Kosovic <doug at uq.edu.au> wrote:
> Hi Gurcharan,
> > i am running the 3.3 version of AG for MacOS on an iMac and Snow Leopard,
> > and the vic windows are all gray even though bits are flowing.
> > if i run an older version of vic the windows render normally.
> > is H264 not enabled on the 3.3 version?
> The default 3 clause BSD license VIC doesn't have the patent encumbered
> stuff enabled. The GPL VIC does and can be built on Leopard to Lion with
> the following on the command-line, you'll also need to install the yasm
> assembler which is available from ( http://yasm.tortall.net/Download.html) :
> svn co https://mediatools.cs.ucl.ac.uk/repos/mmedia/common/trunk common
> svn co https://mediatools.cs.ucl.ac.uk/repos/mmedia/vic/branches/mpeg4vic-mpeg4 vic
> ( cd common; ./configure ; make )
> cd vic
> ./configure --enable-gpl
> make
> The --enable-gpl option downloads and builds x264 and ffmpeg required for
> H264 and mpeg-4 support.
> Cheers,
> Doug
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20120216/3416735f/attachment.htm>
