[AG-TECH] Fwd: Accessgrid Error Certificate
ada1 at uma.es
ada1 at uma.es
Tue Mar 29 01:36:07 CDT 2011
Greetings from Malaga University
last few days we can not access to "venue management tool" to the
configuration of multicast. Running "Venue Server" in debug mode shows
the
error "SSLError: TLSv1 alert unknow ca".
We have requested a new certificate type "service", we've installed it
and
the error is the same (NOTE: we have requested the certificate as
"service" type, but once is installed changes to "identity" type. Is it
normal?)
Do you think we have to try deleting all certificates and re-requesting
an "identity" (not "service" type this time) certificate instead of? In
any case we have requested a identity certificate for probing it. If no
is a problem we'll contact you again for help if the error exists
How many certificates are recomendable to have installed? With one is
sufficient? Is a problem to have installed two or more valid
certificates?
Screen capture attached.
Thanks for your dedication with us.
Type: image/bmp
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110329/96d31997/attachment-0001.bin>
