[AG-TECH] Venue Management Problem
Michael Miller
mimiller at ncsa.illinois.edu
Mon Mar 28 08:13:20 CDT 2011
Yes, the unknown cert error indicates you do not have a CA cert for tlsv1. Did you get the VenueServer certificate with the Certificate Manager "Request Certificate" button? or did you get it some other way? The issuer on the VenueServer certificate should be:
/O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Access Grid Developers CA
I think you have a cert from ANL that was meant for a different purpose.
You should try contacting the AGTech email list: ag-tech at mcs.anl.gov You can sign up for it here:
http://www.accessgrid.org/community
hope this helps,
Michael Miller
System Engineer
NCSA
217 649 0747
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
----- Original Message -----
To: "Michael Miller" <mimiller at ncsa.illinois.edu>
Sent: Sunday, March 27, 2011 6:31:37 PM
Subject: Re: Venue Management Problem
Yes I did but still problem Did you see this problem "SSLError: tlsv1 alert unknown ca"
Let me know
Thanks
On Sun, Mar 27, 2011 at 7:28 PM, Michael Miller < mimiller at ncsa.illinois.edu > wrote:
Make sure your new VenueServer cert is set as the default cert in CertificateManagement
hope this helps
Michael Miller
System Engineer
NCSA
217 649 0747
To: "Michael Miller" < mimiller at ncsa.illinois.edu >
Sent: Sunday, March 27, 2011 4:46:37 PM
I was able to install the certificate in Certificate Manager from ANL whenever I already submitted the certificate for Venue Server for a few weeks ago. So, I ran the VenueServer3.py in DOS command line and it seems worked through Venue Server ( https://AT-STAFF-aabhas.cats . gwu.edu:8000/Venues/default and also, I tried to open the Venue Management for creating/adding a new venue like "Lobby Room Number 1" but unable to connect the server to such as link https://AT-STAFF-aabhas.cats . gwu.edu:8000/VenueServer as below:
:C:\Program Files\AGTk-3\bin>VenueServer3.py
Server: https://AT-STAFF-aabhas.cats.gwu.edu:8000/VenueServer
Data Port: 8006
Default Venue Url: https://AT-STAFF-aabhas.cats.gwu.edu:8000/Venues/default
Traceback (most recent call last):
File "C:\Python24\lib\site-packages\M2Crypto\SSL\SSLServer.py", line 33, in ha
ndle_request
request, client_address = self.get_request()
File "C:\Python24\lib\SocketServer.py", line 373, in get_request
return self.socket.accept()
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\hosting\ZSI\Service
Container.py", line 156, in M2CryptoConnectionAccept
ret = ssl.accept_ssl()
File "C:\Python24\lib\site-packages\M2Crypto\SSL\Connection.py", line 150, in
accept_ssl
return m2.ssl_accept(self.ssl)
Please let me know if you have an idea
Thanks
Aabhas Garg
On Sun, Mar 27, 2011 at 5:34 PM, Michael Miller < mimiller at ncsa.illinois.edu > wrote:
I'm not sure what the exact problem is. How did you obtain the certificate from ANL? Were you able to install it? If so, view the certificate and see what the CA designation is, then make sure you have a CA certificate listed in the CA certs tab in the Certificate Manager.
Hope this helps,
Michael Miller
System Engineer
NCSA
217 649 0747
To: mimiller at ncsa.uiuc.edu
Sent: Saturday, March 26, 2011 4:20:24 PM
Can you please reply as I intend to set up a new venue for Venue Management on Monday
I cannot solve this problem as below:
Thanks
Aabhas
On Fri, Mar 25, 2011 at 7:51 PM, Aabhas Garg < aabhasgarg at gmail.com > wrote:
Also I got CA Certificate from ANL. I tried to add the venue in Venue Management to such a link :
https://AT-STAFF-aabhas.cats.gwu.edu:8000/VenueServer and got some error as below:
py
Data Port: 8006
ndle_request
accept_ssl
Please let me know
Aabhas
Thanks and Regards,
Aabhas Garg
Thanks and Regards,
Aabhas Garg
Thanks and Regards,
Aabhas Garg
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110328/715bcda9/attachment.htm>
