[AG-TECH] Rat Linux Memory Leak
Todd Zimmerman
todd.zimmerman at ubc.ca
Fri Mar 25 12:16:46 CDT 2011
On 03/21/2011 12:57 AM, Douglas Kosovic wrote:
> Hi Todd,
> When you mentioned vic& rat don't start for you with the VenueClient on F14, do they come up if you go to the APAG lobby? i.e. :
> https://vv3.ap-accessgrid.org:8000/Venues/default
Interesting. Yes, you are correct. Vic & Rat do appear when accessing
the APAG lobby.
Any advice on a fix?
> As for testing an older source version of rat (<= svn release 4393) like Chris suggests, download rat-4.4.01-0.1.20080731svn.fc8.src.rpm from:
> http://www.vislab.uq.edu.au/ag3/fedora/8/SRPMS/
> then rebuild with the following:
> rpmbuild --rebuild rat-4.4.01-0.1.20080731svn.fc8.src.rpm
> once built, install by first removing the currently installed version of rat, e.g.:
> rpm -e --nodeps rat
> rpm -i rpmbuild/RPMS/x86_64/rat-4.4.01-0.1.20080731svn.fc14.x86_64.rpm
I'm currently OK with the new version and just ensuring Pulse is
completely removed. How are these older versions different?
Todd
