[AG-TECH] Black Magic Intensity Pro, Panasonic AG-HMC150 & AGtk 3.2
Douglas Kosovic
doug at uq.edu.au
Sun Jan 30 23:21:50 CST 2011
Hi Jimmy,
This bug has been fixed and is in the new all-in-one installer which
you'll hopefully find on the accessgrid.org website before you read this
email.
Alternatively, the new Windows AG HD node services can be downloaded
http://www.vislab.uq.edu.au/ag3/windows/NodeServices/
Doug
[mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Jimmy Miklavcic
Sent: Monday, 31 January 2011 7:11 AM
To: ag-tech at lists.mcs.anl.gov
Subject: Re: [AG-TECH] Black Magic Intensity Pro,Panasonic AG-HMC150 &
AGtk 3.2
Here's the full error log that I get. I did notice that this error log
immediately replaces another window so I have no record of the first
error that is displayed (that I know of). Any help will be appreciated.
invalid command name ""
while executing
"$cmd [expr round([$qscale get])]"
invoked from within
"$qscale instate {!disabled} {
set cmd [$qscale cget -command]
(procedure "init_grabber" line 59)
invoked from within
"init_grabber $V(grabber)"
invoked from within
"if ![have grabber] {
set DA [$videoDevice attributes]
set DF [attribute_class $DA format]
set DS [attribute_class $DA size]
# first, see if d..."
(procedure "transmit" line 3)
invoked from within
"transmit"
("after" script)
Jimmy
Sent: Saturday, January 29, 2011 6:38 PM
Subject: [AG-TECH] Black Magic Intensity Pro, Panasonic AG-HMC150 & AGtk
3.2
I have a Blackmagic Intensity Pro HDMI Card, in a system with Windows XP
and a Panasonic AGHMC150 camera. I've install Blackmagic drivers 7.94.
When I set the cameras to 720/30p I get black, when I set the camera to
1080/60i I get nothing at all. I have set the service parameters in the
node configuration to match the cameras output but no video.
I have this same configuration on two similar systems. On one, I get the
application error when vic starts up that states - invalid command """".
On the other system I don't see that error.
Does anyone have any insight into what might be going on?
Jimmy
Jimmy Miklavcic
Multimedia Specialist
University of Utah CHPC
155 S 1452 E RM 405
Salt Lake City, UT 84112
801-585-9335
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20110131/87184e43/attachment.htm>
