[AG-TECH] Multiple problems
Thomas Uram
turam at mcs.anl.gov
Fri Sep 24 11:36:46 CDT 2010
Darin:
I will look into the certificate request problem as soon as possible and get back to you.
Log files are written in c:\documents and settings\username\Application Data\AccessGrid3\Logs. If you see anything awry in these files, send them along so we can have a look. When you say "nothing happens" when you try to enter these tools, that clearly indicates a different problem from the certificate request failure, so there might be worthwhile debugging info in the logfiles.
If you have any questions in the meantime, let me know.
Tom
On Sep 24, 2010, at 4:05 AM, Oman, Darin wrote:
> Greetings,
> I’m still trying to set up a venues server, but am running into various problems.
> First, on Win XP, I installed AG 3.1. When I try to request a certificate, I get “certificate request failed”. The machine has been set up to bypass the proxy server. Is there some other port or something that needs to be opened up to reach the certificate server?
> So… I decided to try 3.2 (again). I completely removed all 3.1 bits I could find, including python, etc. I installed 3.2 and, when I try to open Request a Certificate, Manage Certificates or the Venue Management tool, nothing happens.
> I tried the same thing (3.2) on my laptop with Win7 while connected to our guest network (firewall, no proxy). The request tool works, but, again, I get “certificate request failed”.
> I assume log files would show up in AGTK-3/Logs? The directory remains empty.
> People are starting to think that this cool Access Grid thing I keep talking about is a myth. Please help.
> Darin
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100924/8da8553d/attachment-0001.htm>
