[AG-TECH] AG3.2 bundle - Native VIC: Disable vic auto-mute
Jason Bell
j.bell at cqu.edu.au
Thu Sep 23 20:48:37 CDT 2010
G'day CJ
I suspect that you are using a VideoProducerService, which is designed to mute the video streams to reduce decoding load. The Video Producer is generally used within a Multi-computer AG node, in which a separate capture machine is used and the decoding of video isn't required.
If you would like to have all the video "unmuted", I suggest you try using the VideoService or VideoServiceHD node services, as by default the video streams are not muted.
Hope this helps.
Cheers,
Jason.
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Choon Jin Ng
Sent: Friday, 24 September 2010 09:49 AM
To: ag-tech at lists.mcs.anl.gov
Subject: [AG-TECH] AG3.2 bundle - Native VIC: Disable vic auto-mute
I noticed the native VIC always starts with the cameras muted. Is it possible to change the default behavior so that it is always unmuted at startup?
Regards
CJ
