[AG-TECH] Problem getting a new certificate
"Miguel A. Sáez Llorente"
miguelangel.saez at usc.es
Fri Sep 17 03:54:51 CDT 2010
Hello,
I'm also having problems with requesting a new certificate (anonymous
certificate), i'm not using any proxy and the error i get at the end is
"Certificate request failed".
Here is the log:
/09/17/10 10:48:13 420 Toolkit config.py:685 DEBUG retrieved local IP address 172.16.224.21
09/17/10 10:48:13 420 Toolkit toolkit.py:117 DEBUG Initializing AG Toolkit version 3.2
09/17/10 10:48:13 420 Toolkit toolkit.py:118 INFO Command and arguments: ['C:\\Archivos de programa\\AGTk-3\\bin\\CertificateRequestTool3.pyw']
09/17/10 10:48:13 420 VenueClient preferences.py:206 DEBUG Preferences.LoadPreferences: open file
09/17/10 10:48:13 420 Toolkit toolkit.py:167 INFO Logfile Name: CertificateRequestTool.log
09/17/10 10:48:13 420 CertificateManager certificatemanager.py:212 DEBUG Opened repository C:\Documents and Settings\Administrador\Datos de programa\AccessGrid3\Config\certRepo
09/17/10 10:48:13 420 Toolkit toolkit.py:473 INFO Initialized certificate manager.
09/17/10 10:48:13 420 CertificateManager certificatemanager.py:575 DEBUG Configuring standard environment
09/17/10 10:48:13 420 CertificateManager certificatemanager.py:782 WARNING No identity certs found
09/17/10 10:48:13 420 CertificateManager certificatemanager.py:790 WARNING No default identity certificate found
09/17/10 10:48:13 420 CertificateManager certificatemanager.py:627 DEBUG No default identity found
09/17/10 10:48:13 420 CertificateRequestTool certificaterequesttool.py:74 DEBUG __init__:Start Certificate Request Wizard
09/17/10 10:48:14 420 CertificateRequestTool certificaterequesttool.py:88 DEBUG __init__:Set the initial order of the pages
09/17/10 10:48:14 420 CertificateRequestTool certificaterequesttool.py:104 DEBUG __init__:Handle arguments for certificate type
09/17/10 10:48:14 420 CertificateRequestTool certificaterequesttool.py:129 DEBUG __init__:Create the pages
09/17/10 10:48:14 420 CertificateRequestTool certificaterequesttool.py:134 DEBUG __init__:Run the wizard
09/17/10 10:48:15 420 CertificateRequestTool certificaterequesttool.py:157 DEBUG ChangingPage: From<class 'AccessGrid.Security.wxgui.CertificateRequestTool.IntroWindow'> to<class 'AccessGrid.Security.wxgui.CertificateRequestTool.SelectCertWindow'>
09/17/10 10:48:15 420 CertificateRequestTool certificaterequesttool.py:164 DEBUG ChangingPage:Values are correct
09/17/10 10:48:17 420 CertificateRequestTool certificaterequesttool.py:157 DEBUG ChangingPage: From<class 'AccessGrid.Security.wxgui.CertificateRequestTool.SelectCertWindow'> to<class 'AccessGrid.Security.wxgui.CertificateRequestTool.AnonCertWindow'>
09/17/10 10:48:17 420 CertificateRequestTool certificaterequesttool.py:164 DEBUG ChangingPage:Values are correct
09/17/10 10:48:17 420 CertificateRequestTool certificaterequesttool.py:157 DEBUG ChangingPage: From<class 'AccessGrid.Security.wxgui.CertificateRequestTool.AnonCertWindow'> to<class 'AccessGrid.Security.wxgui.CertificateRequestTool.SubmitReqWindow'>
09/17/10 10:48:20 420 CertificateRequestTool certificaterequesttool.py:157 DEBUG ChangingPage: From<class 'AccessGrid.Security.wxgui.CertificateRequestTool.SubmitReqWindow'> to<type 'NoneType'>
09/17/10 10:48:20 420 CertificateManager certificatemanager.py:575 DEBUG Configuring standard environment
09/17/10 10:48:20 420 CertificateManager certificatemanager.py:782 WARNING No identity certs found
09/17/10 10:48:20 420 CertificateManager certificatemanager.py:790 WARNING No default identity certificate found
09/17/10 10:48:20 420 CertificateManager certificatemanager.py:627 DEBUG No default identity found
09/17/10 10:48:20 420 Toolkit toolkit.py:647 ERROR Toolkit initialized with no default identity.
09/17/10 10:48:20 420 CertificateManagerWXGUI certificatemanagerwxgui.py:507 DEBUG RequestCertificate: Create a certificate request
09/17/10 10:48:20 420 CertificateManagerWXGUI certificatemanagerwxgui.py:508 DEBUG Proxy enabled: False value: :
09/17/10 10:48:20 420 CertificateManagerWXGUI certificatemanagerwxgui.py:522 DEBUG Requesting certificate for dn [('O', 'Access Grid'), ('OU', 'agdev-ca.mcs.anl.gov'), ('CN', 'Anonymous')]
09/17/10 10:48:20 420 CertificateManagerWXGUI certificatemanagerwxgui.py:523 DEBUG reqinfo isident: False info: Cert request: type=anonymous name=Anonymous email= domain=None host=None
09/17/10 10:48:20 420 CertificateRepository certificaterepository.py:908 INFO _ImportPrivateKey importing pkey to C:\Documents and Settings\Administrador\Datos de programa\AccessGrid3\Config\certRepo\privatekeys\277b4731458b19f597e935ad591aa21d.pem
09/17/10 10:48:20 420 CertificateRepository certificaterepository.py:874 INFO _ImportCertificateRequest writing to C:\Documents and Settings\Administrador\Datos de programa\AccessGrid3\Config\certRepo\requests\277b4731458b19f597e935ad591aa21d.pem
09/17/10 10:48:20 420 CertificateManagerWXGUI certificatemanagerwxgui.py:535 DEBUG SubmitRequest:Validate: ExportPEM returns -----BEGIN CERTIFICATE REQUEST-----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-----END CERTIFICATE REQUEST-----/
/09/17/10 10:48:20 420 CertificateManagerWXGUI certificatemanagerwxgui.py:537 DEBUG SubmitRequest:Validate: subj is /O=Access Grid/OU=agdev-ca.mcs.anl.gov/CN=Anonymous
09/17/10 10:48:20 420 CertificateManagerWXGUI certificatemanagerwxgui.py:539 DEBUG SubmitRequest:Validate: mod is C24C27EC4B0CB76E62071D135C2E8CC03261DE7425107FD426FA8FF26404FB748C53D19712644B41AA99E57290D1C642B676E60020F02247A8CE1FD0216ADB44DA72CC657724A7DF550D609315E35577E724422FC98F84F61EF616A14843D4397B65C413DE1B70CE9B34B8C8D299EB209B661F3722C18F7390C1FC99D7978BDF
09/17/10 10:48:20 420 CertificateManagerWXGUI certificatemanagerwxgui.py:541 DEBUG SubmitRequest:Validate:modhash is 277b4731458b19f597e935ad591aa21d
09/17/10 10:48:20 420 CRSClient crsclient.py:28 DEBUG create client
09/17/10 10:48:20 420 CRSClient crsclient.py:61 DEBUG request certificate
09/17/10 10:48:21 420 CertificateManagerWXGUI certificatemanagerwxgui.py:582 ERROR Unexpected error in cert request
Traceback (most recent call last):
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\Security\wxgui\CertificateManagerWXGUI.py", line 549, in RequestCertificate
requestId = certificateClient.RequestCertificate(reqInfo.GetEmail(), pem)
File "C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\Security\CRSClient.py", line 63, in RequestCertificate
token = self.proxy.RequestCertificate(emailAddress, certReq)
File "C:\Python24\lib\xmlrpclib.py", line 1096, in __call__
return self.__send(self.__name, args)
File "C:\Python24\lib\xmlrpclib.py", line 1383, in __request
verbose=self.__verbose
File "C:\Python24\lib\xmlrpclib.py", line 1137, in request
headers
ProtocolError:<ProtocolError for www-unix.mcs.anl.gov/fl/research/accessgrid/ca/anonymous/anonReqServer.cgi: 302 Found>
09/17/10 10:48:22 420 CertificateRequestTool certificaterequesttool.py:161 DEBUG ChangingPage:Values are not correct, do not change page/
This is with a Windows XP ServicePack 3 and the latest version of AG (3.2).
Soporte tareas multimedia - ATIC
Univ. Santiago de Compostela (USC)
Rúa de José María Suárez Núñez (Campus Sur) - Pavellón de Servicios
15705 Santiago de Compostela - SPAIN
E-mail: miguelangel.saez at usc.es
Tel: +34 881811000 (ext. 13035) / Directo 881813035
Tel AG: +34 981563100 (ext. 16273) / Directo 881970144
Fax: +34 981547070
Web: http://www.usc.es/atic
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100917/c812ffde/attachment.htm>
