[AG-TECH] Multiple Blackmagic Cards - One more Question
Tellekson, Eric G.
eric.tellekson at sdstate.edu
Wed Sep 1 16:59:50 CDT 2010
Chris and John,
Yes, the HD-SDI and HD-Component outputs work at the same time on the Sony EVI-HD1. We are using both at the same time at our site.
Since the Component is HD-Component it outputs at the same time as the HD-SDI in the HD modes. In the SD modes you can use Composite and S-video at the same time.
The camera will output only HD or SD video though so you cannot output HD-SDI and composite at the same time.
The signal formats are switchable but HD-SDI and HD-Component us the same format and there is nowhere to select what port the signal outputs from (i.e. SDI or Component, Composite or S-video).
The switch settings are below:
HD Mode: 1080/59.94i, 1080/50i, 1080/29.97p, 1080/25p, 720/59.94p, 720/50p, 720/29.97p, 720/25p.
SD Mode: NTSC and PAL - Each with options for 16:9 to 4:3(Letter Box, Crop, or Squeeze)
We used a Lenkeng LKV7611 - Component to Composite & S-Video Converter to down convert to SD. (Works well for under $50)
-Eric
Eric Tellekson
Communications Technician
Classroom Technology Services
South Dakota State University
Pugsley Center 212, Box 2218A
Brookings, SD 57007
Phone: 605.688.5747
Email: eric.tellekson at sdstate.edu
-----Original Message-----
From: John I. Quebedeaux, Jr [mailto:johnq at lsu.edu]
Sent: Wednesday, September 01, 2010 4:21 PM
To: Christoph Willing; Tellekson, Eric G.
Cc: AG-TECH list
Subject: Re: [AG-TECH] Multiple Blackmagic Cards - One more Question
I too thought I could only get one out of the camera at a time... Had to
manually switch...
-John Q.
> From: Christoph Willing <c.willing at uq.edu.au>
> Date: Thu, 2 Sep 2010 07:10:49 +1000
> To: "Tellekson, Eric G." <eric.tellekson at sdstate.edu>
> Cc: AG-TECH list <ag-tech at mcs.anl.gov>
> On 02/09/2010, at 5:33 AM, Tellekson, Eric G. wrote:
>> Todd,
>> Here is our combination @ South Dakota State University.
>> - Sony EVI-HD1 @ 3
>> - Blackmagic Decklink SDI cards @ 3
>> We simultaneously use the HD-SDI out of the cameras to the black
>> magic cards as well as the HD-Component out and down convert it to
>> NTSC Composite into a Viewcast Osprey 440.
> Eric,
> Could you confirm that you're deriving both HD-SDI and HD-Component
> from the camera at the same time? I had a loan of a Sony EVI-HDI and
> found that the different output formats were only switchable i.e. only
> one format at a time. Maybe the one I had was an older one ....
> chris
>> From: ag-tech-bounces at lists.mcs.anl.gov
>> [mailto:ag-tech-bounces at lists.mcs.anl.gov
>> ] On Behalf Of Todd Zimmerman
>> Sent: Wednesday, September 01, 2010 1:03 PM
>> Cc: ag-tech at mcs.anl.gov
>> Subject: [AG-TECH] Multiple Blackmagic Cards - One more Question
>> Sorry all - one more question.
>> What combination of camera/Blackmagic card are you all using?
>> Todd
>> Collaboration & Visualization Specialist
>> UBC Okanagan ITServices - http://web.ubc.ca/okanagan/itservices/
>> WestGrid - http://www.westgrid.ca
>> Compute Canada - http://computecanada.org
>> Todd Zimmerman | 250.807.9979 | todd.zimmerman at ubc.ca
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
