[AG-TECH] Vanishing Bridges
Thomas Uram
turam at mcs.anl.gov
Wed Oct 13 11:13:53 CDT 2010
Last week I set up a test registry, registered a bridge with it, and successively queried bridges from the registry all day with no trouble. Granted, these were all local, but if the problem appears as reliably as I've heard, I would have expected to see a problem even in this case. We clearly need to narrow down the cause of the problem some more. What details do we have about the failure cases?
Tom
On Oct 13, 2010, at 2:27 AM, Philippe d'Anfray wrote:
> Bonjour,
> I was not there yesterday and it's probably too late to "purge the cache" (there's just a Lucid test by now)
> By the time we decided to switch to debian because we have a seminar that will be transmitted
> tomorrow and really need the bridge to work (in fact to be visible to new users and there it is).
> If it works also with "maverick" it is a good news for other users in France (but in the first test we made the
> bridge disappears too...)
> Merci pour tout!!
> Philippe d'Anfray
> Le 12/10/2010 12:56, Christoph Willing a écrit :
>>>> We're still stuck with this bridge problem, we tried with Ubuntu 10.10 this afternoon but it is still the same. If you can confirm us that it works fine with Debian, I'll reconfigure our server and install a Debian.
>>> I'm just about to leave for a short holiday so I can't reconfirm that Debian still works correctly until late next week.
>> I'm now running a test bridge with Debian "lenny". It has been running nearly 5 hours without any problem so far. I'm also running another test bridge using the new Ubuntu "maverick", which and been running for over 4.5 hours - also no problem yet. I will let them both run overnight here (your day time) and you can check whether they're still running OK if you purge your bridge cache (assuming you have www.ap-accessgrid.org as one of your bridge registries) and look for the bridges named DebTest (Debian lenny 64bit) and MaverickTest (Ubuntu maverick 32bit).
> <Philippe_d-Anfray.vcf>
