[AG-TECH] How to share multiple JPEG or TIFF images
Thomas Uram
turam at mcs.anl.gov
Fri May 14 15:04:01 CDT 2010
Knowing that it'd only take a short time, I modified the SharedImageViewer to watch a given directory for new files and share them in the application session. This is a step closer to what you'd want, but it still has some simple problems.
- Sometimes it uploads the files in the directory initially, but not always
- The images stretch to the window size
- It only loads the image thumbnails as they come in, not the whole image, leaving selection up to the users.
These are easy to fix. Let me know if you try it out. I overwrote the zip file at the original URL:
> http://www.mcs.anl.gov/~turam/AG/SharedImageViewer.zip
Tom
On May 14, 2010, at 1:32 PM, west suhanic wrote:
> Hi Thomas:
> Thank you for your quick reply.
> Thomas my goal is share images of live malaria parasites.
> I would like these images to be as high resolution as possible as
> the parasites are micrometers in size and right at the edge of what you
> can see using light microscopy. So while both vpcscreen and
> ScreenStreamer are great, I really want to share the images in all
> their high resolution beauty. So what do I have to do to your
> SharedImageViewer to let interested viewers see the images as
> they come off of the camera?
> regards,
> west suhanic
> On Fri, May 14, 2010 at 2:24 PM, Thomas Uram <turam at mcs.anl.gov> wrote:
> West:
> A couple options that you might consider are:
> http://www.memetic-vre.net/software/ScreenStreamer
> http://accessgrid.org/project/vpcscreen
> Either of these are probably good options, though you said you didn't want a streaming solution.
> Sometime back I wrote a simple SharedImageViewer demo application in Python that allows users to select local images to share with collaborators.
> If this is more of what you have in mind, it could easily be extended to meet your needs. I'd be willing to discuss that further with you.
> Tom
> On May 14, 2010, at 11:05 AM, west suhanic wrote:
> > Hello All:
> > I wish to share a series of JPEG or TIFF images.
> > Images will be captured anywhere from one every 5 seconds
> > to one every minute. I do not want to use a streaming format
> > as I want the images to be the highest resolution possible.
> > So is there any shared image viewer available that users logged into
> > a venue can use to see the images as they become available?
> > Any and all suggestions are welcomed and appreciated.
> > regards,
> > west suhanic
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100514/ee775b18/attachment.htm>
