[AG-TECH] trouble with multi-node setup.
Nicolas Rossow
N.Rossow at griffith.edu.au
Mon Mar 8 23:43:15 CST 2010
Hi All,
I've just finished installing 3 new pc's for the setup of our AccessGrid
room.
2 x Fedora 12 machines for capture and display
1x Windows machine for presentation.
I am having trouble getting the 2 Fedora machines to talk to each others
ServiceManager.
I can successfully add the Windows Presentation machines ServiceManager to
both Fedora machines. BUT I cannot get the ServiceManager on either Fedora
machines to add to any other machine, Windows or Fedora.
I have done the following.
system-config-firewall-tui and disabled the firewall.
service iptables stop
chkconfig iptables off
reboot
Still not working.
netstat shows that the ServiceManager is running on port 11000
I ran the servicemanager in debug mode on the windows box and have
attached the output below.
Any help / insight you could provide would be much appreciated.
----------------------8<----------------------
03/09/10 15:24:26 2080 NodeService agnodeservice.py:242 INFO
NodeService.AddServiceManager
03/09/10 15:24:26 2080 NodeService agnodeservice.py:243 DEBUG
serviceManagerUrl = http://132.234.16.162:11000/ServiceManager
03/09/10 15:24:26 2080 NodeService agnodeservice.py:250 INFO try to
reach service amnager
03/09/10 15:24:26 2080 NodeService agnodeservice.py:253 INFO get sm
description
03/09/10 15:24:27 2080 NodeService agnodeservice.py:259 ERROR Failed
to add service manager http://132.234.16.162:11000/ServiceManager
Traceback (most recent call last):
File
"C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\AGNodeService.py",
line 254, in AddServiceManager
serviceManagerDescription = AGServiceManagerIW( serviceManagerUrl
).GetDescription()
File
"C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\interfaces\AGServiceManager_client.py",
line 71, in GetDescription
self.binding.Send(None, None, request, soapaction="urn:#GetDescription",
**kw)
File "C:\Python24\lib\site-packages\ZSI\client.py", line 266, in Send
self.h.connect()
File "C:\Python24\lib\httplib.py", line 630, in connect
raise socket.error, msg
error: (10061, 'Connection refused')
03/09/10 15:24:27 2080 NodeManagementUIClasses
nodemanagementuiclasses.py:855 ERROR Exception in AddHost
File
"C:\Python24\lib\site-packages\AccessGrid3\AccessGrid\NodeManagementUIClasses.py",
line 853, in AddHost
self.nodeServiceHandle.AddServiceManager( url )
File
).GetDescription()
File
**kw)
self.h.connect()
03/09/10 15:24:30 2080 NodeService agnodeservice.py:298 INFO
NodeService.GetServiceManagers
03/09/10 15:24:30 2080 ServiceManager agservicemanager.py:225 INFO
AGServiceManager.GetServices
--------------------------->8-----------------------------------
Nick Rossow
Senior Systems Administrator
Information Services (Scholarly Information and Research)
Griffith University
Nathan Campus, Queensland 4411
n.rossow at griffith.edu.au
www.griffith.edu.au
Phone: +61 (0)7 373 54353
Mobile: 0438 147 728
Fax +61 (0)7 373 56650
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100309/ef1ad64a/attachment-0001.htm>
