[AG-TECH] HD devices within an Access Grid setup
Griebel, Keith
Keith.Griebel at sdstate.edu
Thu Jun 17 16:45:57 CDT 2010
Our workaround for this was to purchase some pretty inexpensive component to composite adapters/downconverters, since the Sony EVI-HD1 cameras do simultaneously output HD component and HDSDI. You will also need a pretty readily available HD15(VGA) to BNC or RCA breakout cable to plug into the cameras as they are not included... The only thing to be wary of is to make sure the converters you purchase handle the HD resolution and frame rate you have the cameras set to. The ones we purchased are the Lenkeng LKV7611's, around $50 USD each. There are probably better ones out there, as these do not support all of the resolutions the EVI-HD1's output and don't really have any scaling options, but I believe they will do the trick for us anyway.
Hope that helps!
Keith
Keith Griebel
Communications Technician
Classroom Technology Services
South Dakota State University
Pugsley Center 205A, Box 2218A
Brookings, SD 57007
Phone: 605.688.6111
Email: keith.griebel at sdstate.edu
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Christoph Willing
Sent: Thursday, June 17, 2010 3:32 PM
To: Brian Corrie
Cc: Ben Joseph; ag-tech at mcs.anl.gov; Vine, Derek A
Subject: Re: [AG-TECH] HD devices within an Access Grid setup
On 18/06/2010, at 2:46 AM, Brian Corrie wrote:
> Hi Derek,
> That sound like a nice solution... It drives me crazy that with the
> Sony HD-1 you need to flip a dip switch on the camera to switch
> between a live SDI out and a composite out. This basically means you
> can't multipurpose the camera between HD and SD video. I need a
> ladder and a screw driver to make the switch between the two 8-)
Yes thats a real shortcoming of the Sony camera.
To work around that, I had been thinking about using one of the more
sophisticated blackmagic cards, say Decklink Studio or Extreme which
takes in HD in whatever format (SDI, HDMI, DVI, YUV) and at the same
time provides a downconverted version at its output. If you then run
that output into a normal capture card, you should be able to stream
HD and PAL/NTSC simultaneously. I haven't actually tried it but seems
good in theory ...
chris
> The Vaddio sounds promising. I talked to Sony at InfoComm about the
> HD-1 and it didn't sound like this was going to change any time
> soon, so another option is good to know about. Unfortunately I
> walked through the Vaddio booth but didn't talk to them about their
> camera specifically.
> Brian
> Vine, Derek A wrote:
>> We will be using the Vaddio WallVIEW HD-18 DVI/HDMI in our new HD
>> room later this summer. It features a quick-connect box and ez-
>> cabling over cat5. On the quick connect there are DVI and
>> component outputs, and a composite output is available on the
>> camera. Unlike the Sony HD1, all outputs from the HD-18 are live
>> all the time.
>> The DVI/HDMI option was just announced at InfoComm last week, I
>> have been told that the camera will begin shipping by July.
>> Derek Vine
>> Communication Network Specialist
>> DDN Site Coordinator
>> The University of South Dakota
>> Office - 605-677-5042
>> Cell - 605-677-8215
>> dvine at usd.edu
>> ] On Behalf Of Jason Bell
>> Sent: Thursday, June 17, 2010 12:32 AM
>> To: ag-tech at mcs.anl.gov
>> Cc: Ben Joseph
>> Subject: [AG-TECH] HD devices within an Access Grid setup
>> G'day All
>> Quick question. I have a colleague interested in using HD devices
>> within an Access Grid setup.
>> Obviously they are looking to use the "Blackmagic Design Intensity
>> Pro" capture cards, but I was wondering if anyone had any advice
>> with HD cameras that have HDMI output? Does anyone have any
>> particular setup that they are currently using? Obviously there
>> are many "handy cam" cameras, but having P/T/Z capability would be
>> a huge benefit.
>> Thanks in advance,
>> Jason.
>> Jason Bell, B.I.T. (Honours)
>> Video Collaboration Team Leader
>> Australian Research Collaboration Service http://www.arcs.org.au/
>> Research Systems Support Officer
>> Information Technology Division
>> CQ University Australia
>> E-mail : j.bell at cqu.edu.au
>> jason.bell at arcs.org.au
>> Work : +61 7 4930 9229
>> Mobile : 0409 630897
>> Postal : Building 19
>> Central Queensland University
>> Bruce Highway
>> Rockhampton, Queensland, Australia, 4702
>> Patience is a virtue.
>> But if I wanted Patience,
>> I would have become a Doctor.
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
