[AG-TECH] Problems uploading files
    Christoph Willing
    c.willing at uq.edu.au
    Mon Apr 26 19:04:58 CDT 2010
Jesus,
Could you submit a bug report for this problem please? You can do that
via the VenueClient Help menu.
I have now been able to replicate the problem on several systems -
Ubuntu, Slackware, Fedora & Debian. Interestingly older versions
running on these systems seem to work OK i.e. when a venue server runs
on the older systems, the problem is not evident. Unfortunately I
don't have resources to test all Linux systems but so far, the last
known versions to work correctly (a client can upload to a server
running on the same system) are:
Ubuntu Intrepid
Slackware 12.2
Fedora - unknown exactly but the problem is evident in Fedora 11
Debian - Lenny partially works
The Debian case is interesting because a Lenny client will not upload
data to a Lenny server, yet a Jaunty client can upload to a Lenny
server (even though it can't upload to a Jaunty server).
At this stage, I can't determine whether the problem is due to AG
toolkit code or to one of the supporting software packages; particular
versions of zsi and m2crypto have caused most heartburn in the past -
maybe they're implicated again. I think it will take some time to find
and fix
chris
On 26/04/2010, at 12:51 AM, Jesus Cea Oliva wrote:
> Hi Christoph, thanks for your indications :).
> I tried local VenueServers on machine, I mean, if I run Ubuntu, I
> execute in the same machine a local VenueServer, then, I run
> VenueClient and I try upload a file, the same with Windows 7.
> However, due to your mail, I've doing some tests:
> - On my Ubuntu system, I've entered at https://vv3.ap-accessgrid.org:8000/Venues/default
> , the Test Room, and I download files: VenueThermoClient.agpkg3 and
> methanol.obj, and rename it adding X (metahnol.objX). Then I can
> upload the files without problems to the server.
> I create a local network with 2 machines, with Windows 7 and Ubuntu.
> - Firstly I've executed a VenueServer on Ubuntu machine, then I've
> run VenueClients in both machines. I can't upload files in the 2
> machines (well you know, really, I can upload, but the Client
> appears stop, reentering in the Venue I can see the files uploaded).
> I've noticed other problem, when I try delete a file, VenueClient
> don't refresh this command, the system don't delete the file.
> - I've executed a VenueServer on Windows 7 machine, then I've run
> VenueClients in both machines. Here, I can upload files without
> problems, on Windows and Ubuntu systems.
> So, now, I know that I have problems with our VenueServer on Ubuntu
> systems, I don't know if I have to configure something or if there
> are problems about names, like ñ, spaces, etc (user name, path file,
> etc, although my home path is /home/ercea and, there, is the
> VenueServer's Data folder)
> Now I'll try change the system language to US and I'll repeat the
> tests.
> Thanks again and apologize for any inconveniences
> Regards!
> El dia 25 abr 2010 12:11, Christoph Willing <c.willing at uq.edu.au>
> escribió:
> On 23/04/2010, at 6:24 PM, Jesus Cea Oliva wrote:
> Hi Crhistoph, thanks for your response :)
> I try upload files since 1 o 2 K (source codes, txts, etc.) and
> files about 3-6 Mb (PDFs, ppts...) and, all cases I have the same
> problem. The strange of this problem is that ocurrs randomly, and
> sometimes, the same file that before appears not upload, now upload
> (although, the majority cases, don't upload)
> Are you using the same venue server in each test case (Ubuntu &
> Windows VenueClient)?
> Are you using your own server or a "well known" server?
> If these tests are with you own server, could you instead use the
> APAG venue server at https://vv3.ap-accessgrid.org:8000/Venues/
> default and then enter the Test venue. There are several files in
> that venue; could you try to download the simple.py and methanol.obj
> files from that venue and rename them e.g. simple.py -> simple.pyX
> and methanol.obj -> methanol.objX. Now upload te renamed files back
> into the Test venue. Do they both upload as expected?
> FYI, although I thought I had replicated the problem, I now find
> that it actually works correctly. My first hurried tests only
> appeared to replicate your symptoms - because I didn't wait long
> enogh for the upload to complete. However I have now performed the
> tests again and all files upload correctly - and the venue client
> interface shows the new data correctly in all cases.
> I believe the previous test appeared not to update the venue client
> interface because I was performing the tests from home using an ADSL
> connection - therefore the initial download was quite fast. The
> upload was slower because of the much lower upstream bandwidth of my
> ADSL connection. My guess is that the first portion of upload
> _appears_ fast because the venue client is just filling up the local
> TCP system buffer. However that buffer then has to be transferred
> (via slow ADSL uplink) to the venue server - which manifests as a
> fast intitial movement of the progress bar that then appears to
> freeze. The "freeze" is really just a pause while contents of the
> TCP buffer is being transferred across the network.
> In my case the simple.py file, being small, transfers very quickly.
> The methanol.obj file is about 11M - I guess this is just a bit
> larger than my system network buffer size - and takes a lot longer
> to transfer.
> Based on redoing the tests (using the APAG veneu server), I cannot
> replicate the problem.
> Could you confirm whether you still have the problem when you use
> the APAG venue server?
> chris
> On Windows I try similar files (somes files are the same), only
> don't work once due to a very big file. As I saw that I can upload
> files without problems... I try all file types. So I upload a file
> about 100Mb and don't work xD.
> Thanks for your help :). Regards!
> El dia 23 abr 2010 02:35, Christoph Willing <c.willing at uq.edu.au>
> escribió:
> I wonder if this is related to the size of the data object. I just
> tried (with Ubuntu 9.10 64bit) and found that a small file (6K)
> there was no problem. With a larger file (12M) I saw exactly the
> same problem - upload appears not to complete but has actually
> succeeded. Re-entering the venue shows that the new data is there.
> In your Windows test, are you uploading the same file (or something
> of similar size) as in the Ubuntu case?
> I will now be away for a few days so I can't do any more
> investigation myself until I return. Maybe others can look into this
> in the meantime ...
> chris
> On 23/04/2010, at 5:28 AM, Jesus Cea Oliva wrote:
> Thanks Tom for your fast response :).
> Well, atach the VenueClient log in this email, I can't see any
> problems :S.
> 04/22/10 21:16:50 140471913264880 VenueClient VenueClientUI.py: 1308
> DEBUG VenueClientUI.AddDataCB: Trying to upload to 'ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007'
> 04/22/10 21:17:00 140471913264880 VenueClient VenueClientUI.py: 1395
> DEBUG AddDataCB: URI of parent is
> 04/22/10 21:17:00 140471913264880 VenueClientController
> VenueClientController.py:821 DEBUG In
> VenueClientController.UploadVenueFiles
> VenueClientController.py:822 DEBUG fileList = [u'/home/ercea/
> Descargas/DSD-Tutorial-3.pdf']
> VenueClientController.py:848 DEBUG Serverpath:
> VenueClientController.py:857 DEBUG Have args, creating thread, url: ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007
>  , files: [u'/home/ercea/Descargas/DSD-Tutorial-3.pdf']
> 04/22/10 21:17:00 140471479552272 VenueClientController
> VenueClientController.py:944 DEBUG Upload: getting identity
> VenueClientController.py:949 DEBUG Got identity <?xml
> version="1.0" ? ><Subject><Subject auth_data="" auth_type="x509"
> name="/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab
> Anonymous Authority/CN=Anonymous User
> 17130398eef9fd82cba8dc9d845a1768"/></ Subject>
> VenueClientController.py:950 DEBUG get_ident_and_upload: Upload URL ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007
> VenueClientController.py:953 DEBUG Get_ident_and_upload: Word is:
> ftps:
> localhost:8006
> 04/22/10 21:17:00 140471479552272 DataStore DataStore.py:1267 INFO
> UploadFiles: ftps://localhost:
> 8006/7f00010133381d7afaba1c148fcabe1007 [u'/home/ercea/Descargas/
> DSD- Tutorial-3.pdf']
> 04/22/10 21:17:00 140471479552272 DataStore DataStore.py:1271 DEBUG
> 8006/7f00010133381d7afaba1c148fcabe1007 /home/ercea/Descargas/DSD-
> Tutorial-3.pdf [u'/home/ercea/Descargas/ DSD-Tutorial-3.pdf']
> 04/22/10 21:17:00 140471479552272 FTPSClient FTPSClient.py:141 DEBUG
> Entered FTPSUploadFile: localfile=/home/ercea/Descargas/DSD-
> Tutorial-3.pdf url=ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007
> VenueClientController.py:862 DEBUG Started thread
> 04/22/10 21:17:20 140471517653264 VenueClient VenueClient.py:605
> DEBUG Calling Heartbeat, time now: 1271963840
> 04/22/10 21:17:20 140471517653264 VenueClient VenueClient.py:629
> DEBUG Next Heartbeat needed within 36s
> 04/22/10 21:17:20 140471517653264 VenueClient VenueClient.py:639
> DEBUG heartBeatCounter = 2
> 04/22/10 21:17:56 140471401707792 VenueClient VenueClient.py:605
> DEBUG Calling Heartbeat, time now: 1271963876
> 04/22/10 21:17:56 140471401707792 VenueClient VenueClient.py:629
> 04/22/10 21:17:56 140471401707792 VenueClient VenueClient.py:639
> DEBUG heartBeatCounter = 3
> Here increment heartBeatCounter +1.
> Ah, I have this problem, in the same network, on ubuntu system
> (Ubuntu 9.10 64 bits), but I've tested on Windows 7 and I can upload
> Regards!
> El dia 22 abr 2010 18:29, Thomas Uram <turam at mcs.anl.gov> escribió:
> Hi Jesus:
> There is probably some indication of the problem in the
> VenueClient.log file. If you submit a bug report from the Help menu
> after this happens, a recent portion of the VenueClient.log file
> will be included with the report, and we can review it. If you want
> to look yourself, the log file resides in the following locations
> based on platform:
> MacOS, Linux: ~/.AccessGrid3/Logs
> Windows: c:\documents and settings\username\application data
> \AccessGrid3\Logs (adjusted for your locale, of course)
> Tom
> On Apr 22, 2010, at 11:11 AM, Jesus Cea Oliva wrote:
> Hi list again, sorry for my constants problems xD.
> I'm trying upload files to our VenueServer and my problem is
> strange. Firstly, I've created a VenueServer locally, for testing.
> Well, when I try to upload a file, I can see the message on the
> VenueClient "Uploading file X" and a progressbar, but, when the
> progressbar is near to the end, stops and list of files (Data
> section) don't refresh. So I beleived that the file can't upload.
> But, really, the file has uploaded, because I can see the folder
> Data of my local VenueServer, and the file is copied in this folder.
> In this case, if I reset VenueServer and VenueClient, then, I can
> see the files in Data section.
> So I think that the file uploads fine but, the list of files don't
> refresh and the file uploaded don't appears.
> I must say that, sometimes, I can upload a file so I don't know
> whats really the problem (ports closed? firewall? path or name
> files? file size?) .
> Regards!
> <VenueClient.log>
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
