[AG-TECH] Problems uploading files
    Jesus Cea Oliva
    jesus.cea at uca.es
    Sun Apr 25 09:51:25 CDT 2010
Hi Christoph, thanks for your indications :).
I tried local VenueServers on machine, I mean, if I run Ubuntu, I execute in the same machine a local VenueServer, then, I run VenueClient and I try upload a file, the same with Windows 7.
However, due to your mail, I've doing some tests:
- On my Ubuntu system, I've entered at https://vv3.ap-accessgrid.org:8000/Venues/default [ https://vv3.ap-accessgrid.org:8000/Venues/default ], the Test Room, and I download files: VenueThermoClient.agpkg3 and methanol.obj, and rename it adding X (metahnol.objX). Then I can upload the files without problems to the server.
I create a local network with 2 machines, with Windows 7 and Ubuntu.
- Firstly I've executed a VenueServer on Ubuntu machine, then I've run VenueClients in both machines. I can't upload files in the 2 machines (well you know, really, I can upload, but the Client appears stop, reentering in the Venue I can see the files uploaded). I've noticed other problem, when I try delete a file, VenueClient don't refresh this command, the system don't delete the file.
- I've executed a VenueServer on Windows 7 machine, then I've run VenueClients in both machines. Here, I can upload files without problems, on Windows and Ubuntu systems.
So, now, I know that I have problems with our VenueServer on Ubuntu systems, I don't know if I have to configure something or if there are problems about names, like ñ, spaces, etc (user name, path file, etc, although my home path is /home/ercea and, there, is the VenueServer's Data folder)
Now I'll try change the system language to US and I'll repeat the tests.
Thanks again and apologize for any inconveniences
Regards!
El dia 25 abr 2010 12:11, Christoph Willing <c.willing at uq.edu.au> escribió:
> On 23/04/2010, at 6:24 PM, Jesus Cea Oliva wrote:
>> Hi Crhistoph, thanks for your response :)
>> I try upload files since 1 o 2 K (source codes, txts, etc.) and files about 3-6 Mb (PDFs, ppts...) and, all cases I have the same problem. The strange of this problem is that ocurrs randomly, and sometimes, the same file that before appears not upload, now upload (although, the majority cases, don't upload)
> Are you using the same venue server in each test case (Ubuntu & Windows VenueClient)?
> Are you using your own server or a "well known" server?
> If these tests are with you own server, could you instead use the APAG venue server at https://vv3.ap-accessgrid.org:8000/Venues/default [ https://vv3.ap-accessgrid.org:8000/Venues/default ] and then enter the Test venue. There are several files in that venue; could you try to download the simple.py and methanol.obj files from that venue and rename them e.g. simple.py -> simple.pyX and methanol.obj -> methanol.objX. Now upload te renamed files back into the Test venue. Do they both upload as expected?
> FYI, although I thought I had replicated the problem, I now find that it actually works correctly. My first hurried tests only appeared to replicate your symptoms - because I didn't wait long enogh for the upload to complete. However I have now performed the tests again and all files upload correctly - and the venue client interface shows the new data correctly in all cases.
> I believe the previous test appeared not to update the venue client interface because I was performing the tests from home using an ADSL connection - therefore the initial download was quite fast. The upload was slower because of the much lower upstream bandwidth of my ADSL connection. My guess is that the first portion of upload _appears_ fast because the venue client is just filling up the local TCP system buffer. However that buffer then has to be transferred (via slow ADSL uplink) to the venue server - which manifests as a fast intitial movement of the progress bar that then appears to freeze. The "freeze" is really just a pause while contents of the TCP buffer is being transferred across the network.
> In my case the simple.py file, being small, transfers very quickly. The methanol.obj file is about 11M - I guess this is just a bit larger than my system network buffer size - and takes a lot longer to transfer.
> Based on redoing the tests (using the APAG veneu server), I cannot replicate the problem.
> Could you confirm whether you still have the problem when you use the APAG venue server?
> chris
>> On Windows I try similar files (somes files are the same), only don't work once due to a very big file. As I saw that I can upload files without problems... I try all file types. So I upload a file about 100Mb and don't work xD.
>> Thanks for your help :). Regards!
>> El dia 23 abr 2010 02:35, Christoph Willing <c.willing at uq.edu.au> escribió:
>> I wonder if this is related to the size of the data object. I just tried (with Ubuntu 9.10 64bit) and found that a small file (6K) there was no problem. With a larger file (12M) I saw exactly the same problem - upload appears not to complete but has actually succeeded. Re-entering the venue shows that the new data is there.
>> In your Windows test, are you uploading the same file (or something of similar size) as in the Ubuntu case?
>> I will now be away for a few days so I can't do any more investigation myself until I return. Maybe others can look into this in the meantime ...
>> chris
>> On 23/04/2010, at 5:28 AM, Jesus Cea Oliva wrote:
>> Thanks Tom for your fast response :).
>> Well, atach the VenueClient log in this email, I can't see any problems :S.
>> 04/22/10 21:16:50 140471913264880 VenueClient VenueClientUI.py: 1308 DEBUG VenueClientUI.AddDataCB: Trying to upload to 'ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007'
>> 04/22/10 21:17:00 140471913264880 VenueClient VenueClientUI.py: 1395 DEBUG AddDataCB: URI of parent is
>> 04/22/10 21:17:00 140471913264880 VenueClientController VenueClientController.py:821 DEBUG In VenueClientController.UploadVenueFiles
>> 04/22/10 21:17:00 140471913264880 VenueClientController VenueClientController.py:822 DEBUG fileList = [u'/home/ercea/ Descargas/DSD-Tutorial-3.pdf']
>> 04/22/10 21:17:00 140471913264880 VenueClientController VenueClientController.py:848 DEBUG Serverpath:
>> 04/22/10 21:17:00 140471913264880 VenueClientController VenueClientController.py:857 DEBUG Have args, creating thread, url: ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007 , files: [u'/home/ercea/Descargas/DSD-Tutorial-3.pdf']
>> 04/22/10 21:17:00 140471479552272 VenueClientController VenueClientController.py:944 DEBUG Upload: getting identity
>> 04/22/10 21:17:00 140471479552272 VenueClientController VenueClientController.py:949 DEBUG Got identity <?xml version="1.0" ? ><Subject><Subject auth_data="" auth_type="x509" name="/O=Access Grid/O=Argonne National Laboratory/OU=Futures Lab Anonymous Authority/CN=Anonymous User 17130398eef9fd82cba8dc9d845a1768"/></ Subject>
>> 04/22/10 21:17:00 140471479552272 VenueClientController VenueClientController.py:950 DEBUG get_ident_and_upload: Upload URL ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007
>> 04/22/10 21:17:00 140471479552272 VenueClientController VenueClientController.py:953 DEBUG Get_ident_and_upload: Word is: ftps:
>> 04/22/10 21:17:00 140471479552272 VenueClientController VenueClientController.py:953 DEBUG Get_ident_and_upload: Word is: localhost:8006
>> 04/22/10 21:17:00 140471479552272 VenueClientController VenueClientController.py:953 DEBUG Get_ident_and_upload: Word is: 7f00010133381d7afaba1c148fcabe1007
>> 04/22/10 21:17:00 140471479552272 DataStore DataStore.py:1267 INFO UploadFiles: ftps://localhost: 8006/7f00010133381d7afaba1c148fcabe1007 [u'/home/ercea/Descargas/DSD- Tutorial-3.pdf']
>> 04/22/10 21:17:00 140471479552272 DataStore DataStore.py:1271 DEBUG UploadFiles: ftps://localhost: 8006/7f00010133381d7afaba1c148fcabe1007 /home/ercea/Descargas/DSD- Tutorial-3.pdf [u'/home/ercea/Descargas/ DSD-Tutorial-3.pdf']
>> 04/22/10 21:17:00 140471479552272 FTPSClient FTPSClient.py:141 DEBUG Entered FTPSUploadFile: localfile=/home/ercea/Descargas/DSD- Tutorial-3.pdf url=ftps://localhost:8006/7f00010133381d7afaba1c148fcabe1007
>> 04/22/10 21:17:00 140471913264880 VenueClientController VenueClientController.py:862 DEBUG Started thread
>> 04/22/10 21:17:20 140471517653264 VenueClient VenueClient.py:605 DEBUG Calling Heartbeat, time now: 1271963840
>> 04/22/10 21:17:20 140471517653264 VenueClient VenueClient.py:629 DEBUG Next Heartbeat needed within 36s
>> 04/22/10 21:17:20 140471517653264 VenueClient VenueClient.py:639 DEBUG heartBeatCounter = 2
>> 04/22/10 21:17:56 140471401707792 VenueClient VenueClient.py:605 DEBUG Calling Heartbeat, time now: 1271963876
>> 04/22/10 21:17:56 140471401707792 VenueClient VenueClient.py:629 DEBUG Next Heartbeat needed within 36s
>> 04/22/10 21:17:56 140471401707792 VenueClient VenueClient.py:639 DEBUG heartBeatCounter = 3
>> Here increment heartBeatCounter +1.
>> Ah, I have this problem, in the same network, on ubuntu system (Ubuntu 9.10 64 bits), but I've tested on Windows 7 and I can upload files without problems.
>> Regards!
>> El dia 22 abr 2010 18:29, Thomas Uram <turam at mcs.anl.gov> escribió:
>> Hi Jesus:
>> There is probably some indication of the problem in the VenueClient.log file. If you submit a bug report from the Help menu after this happens, a recent portion of the VenueClient.log file will be included with the report, and we can review it. If you want to look yourself, the log file resides in the following locations based on platform:
>> MacOS, Linux: ~/.AccessGrid3/Logs
>> Windows: c:\documents and settings\username\application data \AccessGrid3\Logs (adjusted for your locale, of course)
>> Tom
>> On Apr 22, 2010, at 11:11 AM, Jesus Cea Oliva wrote:
>> Hi list again, sorry for my constants problems xD.
>> I'm trying upload files to our VenueServer and my problem is strange. Firstly, I've created a VenueServer locally, for testing.
>> Well, when I try to upload a file, I can see the message on the VenueClient "Uploading file X" and a progressbar, but, when the progressbar is near to the end, stops and list of files (Data section) don't refresh. So I beleived that the file can't upload.
>> But, really, the file has uploaded, because I can see the folder Data of my local VenueServer, and the file is copied in this folder. In this case, if I reset VenueServer and VenueClient, then, I can see the files in Data section.
>> So I think that the file uploads fine but, the list of files don't refresh and the file uploaded don't appears.
>> I must say that, sometimes, I can upload a file so I don't know whats really the problem (ports closed? firewall? path or name files? file size?) .
>> Regards!
>> <VenueClient.log>
>> Christoph Willing +61 7 3365 8316
>> QCIF Access Grid Manager
>> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100425/43ad7d33/attachment.htm>
