[AG-TECH] VenueManagement Problem changing Multicast Address
    Jesus Cea Oliva
    jesus.cea at uca.es
    Thu Apr  8 16:05:22 CDT 2010
Thanks Tom, it works for me and now I can write Ip and Mask without problems and it's limited to write only numbers, so this fix the problem.
Thank you for your time. I apologize for the inconvenience.
Greetings!
El dia 08 abr 2010 19:09, Thomas Uram <turam at mcs.anl.gov> escribió:
> I think this is a bug. I've fixed it and committed it. If you want to fix it in your copy, you can make the following change:
> Change this line in VenueManagement3.py, in the OnChar method:
>      key = event.KeyCode()
> to this:
>      key = event.GetKeyCode()
> Thanks for reporting the problem.
> Tom
> On Apr 8, 2010, at 2:38 AM, Jesus Cea Oliva wrote:
>> Hi again Christoph:
>> About security framework, I'm running all system defaults programs, so, I haven't installed any security framework yet.
>> I've tested the next machines where I have the problem:
>> - Ubuntu Server 32 bits
>> - Ubuntu Karmic 32 bits
>> - My Personal Laptop with Ubuntu Karmic 64 bits installed
>> All systems are the Spanish version.
>> However, on Windows Systems, Venue Management works without problems :S.
>> Then, I changed temporarily to US keyboard and reboot the system, but I have the same problems.
>> Ah, and I can connect to Venue Server with VenueManagement localy and remotely (configuring on Security Tab, I've set my DN as Administrator) on 32/64 bits Linux systems without problems :S.
>> Regards.
>> El dia 07 abr 2010 23:36, Christoph Willing <c.willing at uq.edu.au [ mailto:c.willing at uq.edu.au ]> escribió:
>>> On 07/04/2010, at 5:43 PM, Jesus Cea Oliva wrote:
>>>> Hi Christoph, sorry:
>>>> - I've used Ubuntu Karmic and Ubuntu Server and, on both systems, we have this problem. Now, I've tested on Windows and it's works without problems.
>>>> - AG version: 3.2 beta.
>>> I cannot replicate this problem here. I wonder if you are running iptables (or some other security framework) that is causing problems in the Linux environment?
>>> Another possibility - I recall you previously had other issues related to the language settings; could you temporarily revert to US keyboard and test whether there is any difference in the VenueManagement behaviour?
>>> BTW, since your VenueManagement tool is able to connect to the server at all, I assume you're using 64bit system. Is that correct? We have recently found VenueManagement connection problems with 32bit systems under Linux.
>>> chris
>>>> - I've run Venue Management on same machine that Venue Server, and later, I've run on different machine (previously, I gave me access control as Administrator for access Venue Server).
>>>> Regards!
>>>> El dia 07 abr 2010 02:03, Christoph Willing <c.willing at uq.edu.au [ mailto:c.willing at uq.edu.au ]> escribió:
>>>> On 06/04/2010, at 9:08 PM, Jesus Cea Oliva wrote:
>>>> Hi list.
>>>> I would like to comment a problem that I have with VenueManagement on my system. When I access to de Venue Server and I try to change the Multicast Address of Venue Server, the new window that appears to introduce the values of IP and Mask, I can't write them, I can't write anything.
>>>> However, if I copy the IP (for example, from a notepad) and Mask, then I can paste them. I supose that it could be a problem about the KeyPress event (or the respective name about this event), is it? I supose that it was trying to restrict introduce bad characters and introduce only numbers. Only its a idea :P.
>>>> More information please:
>>>> - what OS/distribution and AG version are you using (including 32/64bit)?
>>>> - are you running management tool on separate, or same, machines as venue server?
>>>> chris
>>>> Christoph Willing +61 7 3365 8316
>>>> QCIF Access Grid Manager
>>>> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100408/3e46e7c1/attachment.htm>
