[AG-TECH] VenueManagement Problem changing Multicast Address
    Thomas Uram
    turam at mcs.anl.gov
    Thu Apr  8 12:09:46 CDT 2010
I think this is a bug. I've fixed it and committed it. If you want to fix it in your copy, you can make the following change:
Change this line in VenueManagement3.py, in the OnChar method:
        key = event.KeyCode()
to this:
        key = event.GetKeyCode()
Thanks for reporting the problem.
Tom
On Apr 8, 2010, at 2:38 AM, Jesus Cea Oliva wrote:
> Hi again Christoph:
> About security framework, I'm running all system defaults programs, so, I haven't installed any security framework yet.
> I've tested the next machines where I have the problem:
> - Ubuntu Server 32 bits
> - Ubuntu Karmic 32 bits
> - My Personal Laptop with Ubuntu Karmic 64 bits installed
> All systems are the Spanish version.
> However, on Windows Systems, Venue Management works without problems :S.
> Then, I changed temporarily to US keyboard and reboot the system, but I have the same problems.
> Ah, and I can connect to Venue Server with VenueManagement localy and remotely (configuring on Security Tab, I've set my DN as Administrator) on 32/64 bits Linux systems without problems :S.
> Regards.
> El dia 07 abr 2010 23:36, Christoph Willing <c.willing at uq.edu.au> escribió:
> On 07/04/2010, at 5:43 PM, Jesus Cea Oliva wrote:
> Hi Christoph, sorry:
> - I've used Ubuntu Karmic and Ubuntu Server and, on both systems, we have this problem. Now, I've tested on Windows and it's works without problems.
> - AG version: 3.2 beta.
> I cannot replicate this problem here. I wonder if you are running iptables (or some other security framework) that is causing problems in the Linux environment?
> Another possibility - I recall you previously had other issues related to the language settings; could you temporarily revert to US keyboard and test whether there is any difference in the VenueManagement behaviour?
> BTW, since your VenueManagement tool is able to connect to the server at all, I assume you're using 64bit system. Is that correct? We have recently found VenueManagement connection problems with 32bit systems under Linux.
> chris
> - I've run Venue Management on same machine that Venue Server, and later, I've run on different machine (previously, I gave me access control as Administrator for access Venue Server).
> Regards!
> El dia 07 abr 2010 02:03, Christoph Willing <c.willing at uq.edu.au> escribió:
> On 06/04/2010, at 9:08 PM, Jesus Cea Oliva wrote:
> Hi list.
> I would like to comment a problem that I have with VenueManagement on my system. When I access to de Venue Server and I try to change the Multicast Address of Venue Server, the new window that appears to introduce the values of IP and Mask, I can't write them, I can't write anything.
> However, if I copy the IP (for example, from a notepad) and Mask, then I can paste them. I supose that it could be a problem about the KeyPress event (or the respective name about this event), is it? I supose that it was trying to restrict introduce bad characters and introduce only numbers. Only its a idea :P.
> More information please:
> - what OS/distribution and AG version are you using (including 32/64bit)?
> - are you running management tool on separate, or same, machines as venue server?
> chris
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20100408/ccbd35f8/attachment.htm>
