[AG-TECH] VenueManagement Problem changing Multicast Address
Christoph Willing
c.willing at uq.edu.au
Wed Apr 7 16:36:48 CDT 2010
On 07/04/2010, at 5:43 PM, Jesus Cea Oliva wrote:
> Hi Christoph, sorry:
> - I've used Ubuntu Karmic and Ubuntu Server and, on both systems, we
> have this problem. Now, I've tested on Windows and it's works
> without problems.
> - AG version: 3.2 beta.
I cannot replicate this problem here. I wonder if you are running
iptables (or some other security framework) that is causing problems
in the Linux environment?
Another possibility - I recall you previously had other issues related
to the language settings; could you temporarily revert to US keyboard
and test whether there is any difference in the VenueManagement
behaviour?
BTW, since your VenueManagement tool is able to connect to the server
at all, I assume you're using 64bit system. Is that correct? We have
recently found VenueManagement connection problems with 32bit systems
under Linux.
chris
> - I've run Venue Management on same machine that Venue Server, and
> later, I've run on different machine (previously, I gave me access
> control as Administrator for access Venue Server).
> Regards!
> El dia 07 abr 2010 02:03, Christoph Willing <c.willing at uq.edu.au>
> escribió:
> On 06/04/2010, at 9:08 PM, Jesus Cea Oliva wrote:
> Hi list.
> I would like to comment a problem that I have with VenueManagement
> on my system. When I access to de Venue Server and I try to change
> the Multicast Address of Venue Server, the new window that appears
> to introduce the values of IP and Mask, I can't write them, I can't
> write anything.
> However, if I copy the IP (for example, from a notepad) and Mask,
> then I can paste them. I supose that it could be a problem about
> the KeyPress event (or the respective name about this event), is
> it? I supose that it was trying to restrict introduce bad characters
> and introduce only numbers. Only its a idea :P.
> More information please:
> - what OS/distribution and AG version are you using (including
> 32/64bit)?
> - are you running management tool on separate, or same, machines as
> venue server?
> chris
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
