[AG-TECH] Jabber Fixed (was: Re: Jabber Connection Failure?)
Lloyd Pearson
lloyd.pearson at otago.ac.nz
Wed Oct 7 22:58:41 CDT 2009
Hello Eric and others,
I was not particularly aware of the current problems, but over the last couple of months I have had several instances where jabber shows no incoming or sent text on the local PC from when AG was started. No advisory error message has ever shown. In most cases typed messages were sent correctly but nothing was received. Restarting AG usually cured, but on some occasions 3 or 4 AG restarts were necessary. Most times the problem occurred very soon after the PC had been powered, but 2 or 3 times it occurred when AG was started 3-4hrs after an earlier AG session without the PC being rebooted. I have seen it on another similar PC on a couple of occasions. A few other NZ universities have had the same problem but generally not concurrent with an occurrence here.
A restart of AG is very disruptive to a conference, and of course the node that most needs to read jabber is the presenting node.
Is there a way of starting jabber without restarting AG?
Running WinXP SP3.
Lloyd Pearson
AVCC Operator
University of Otago
Ph +64 3 479 8997
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Eric Olson
Sent: Thursday, 8 October 2009 10:29 a.m.
To: Todd Zimmerman
Cc: ag-tech at mcs.anl.gov
Subject: [AG-TECH] Jabber Fixed (was: Re: Jabber Connection Failure?)
Hi Todd,
Thanks for sending mail. One of the server disks was running low on
space. Sorry about that. I've fixed it and restarted the jabber service.
Let me know if anyone still has any problems with jabber.
Eric
Todd Zimmerman wrote:
> Just wondering if anyone else is having Jabber connection issues via the
> VenueClient today.
> I've attached the relevant log entries, but have had reports from
> multiple sources that this is an issue.
> Can't quite recall how the communication for the jabber client all works
> between the venueserver/venueclient and the jabber server at ANL -
> however, I've restarted my venueserver with no apparent change.
> Any thoughts?
> Todd
