[AG-TECH] AG in a virtual machine
Jon Johansson
jon.johansson at ualberta.ca
Thu May 28 15:09:16 CDT 2009
Thanks, Chris. I'll work on this a bit and see if I can get it
to work.
Jon.
~~ Jon I Johansson, Ph.D. * Tel.: (780) 492-9304 ~~
~~ jon.johansson at ualberta.ca * Fax.: (780) 492-1729 ~~
~~ * Office: G.S.B. 323C ~~
~~ Visualization Analyst http://sciviz.aict.ualberta.ca ~~
~~ Research Computing Group ~~
~~ Room 352, General Services Building ~~
~~ Academic Information and Communication Technologies (AICT) ~~
~~ University of Alberta ~~
~~ Edmonton, Alberta, CANADA, T6G 2H1 ~~
! "This communication is intended for the use of the recipient to !
! which it is addressed, and may contain confidential, personal, !
! and/or privileged information. Please contact us immediately !
! if you are not the intended recipient of this communication. !
! If you are not the intended recipient of this communication, !
! do not copy, distribute, or take action on it. Any !
! communication received in error, or subsequent reply, should !
! be deleted or destroyed." !
-----Original Message-----
[mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Christoph
Willing
Sent: Tuesday, May 26, 2009 6:01 PM
To: Jon Johansson
Cc: 'ag-tech'
Subject: Re: [AG-TECH] AG in a virtual machine
On 27/05/2009, at 8:10 AM, Jon Johansson wrote:
> Hi,
> We have a researcher who would like to have AG installed in
> a VMWare virtual machine for distribution.
> I've done a quick test with a fresh install of Kubuntu 9.04 (32-bit)
> and AG 3.2 beta on VMWare workstation 6.5.
> The venue client can connect to our venueserver but complains
> about bridges being disabled in preferences, but I don't see
> where to enable the bridges in any of the preference pages.
> Xawtv grabs the Logitech camera and shows video just fine, but
> vic chokes and dies with either v4l or v4l2 as a source.
> Before I get any further into this, are there any reasons why
> adding this extra layer of complexity will clearly not work?
> Or, would it be expected to work for some reason(s)?
Jon,
A while back we used Xen to run a "multi machine" AG node - with
display in dom0 and video capture (3x) in a guest. It worked fine and,
although a bit messy to initially set up, I think its actually a great
way to have the benefits of a multi machine node all in a single box.
We had that system running here for about a year so there's no reason,
in principle, why a VMWare shouldn't work too.
There's some info at:
http://www.vislab.uq.edu.au/research/accessgrid/software/xenag/
although its a bit old now (xen-2.0 and kernel 2.6.18)
chris
Christoph Willing +61 7 3365 8316
QCIF Access Grid Manager
University of Queensland
