[AG-TECH] System freezes sending video on Linux w/ IVC-200	capture	card
    Christoph Willing
    c.willing at uq.edu.au
    Sun Mar 29 18:00:33 CDT 2009
On 26/03/2009, at 4:58 PM, Christoph Willing wrote:
> On 26/03/2009, at 3:34 AM, Andrew Ford wrote:
>> Hi,
>> For a while now we've been seeing hard freezes (ie, trying to kill
>> the X server does nothing) on one of our Linux machines when it
>> tries to send video via an IVC-200 cap card. It tends to occur more
>> frequently when the load is heavier - attempting to send 2 or more
>> 720x480 mpeg4 or h.264 streams causes it to freeze within 5-10
>> minutes, 4 h.261 videos make it freeze in about half an hour, and 2
>> 261 videos makes it last about 2 days. dmesg and /var/log/messages
>> don't give any clues. Other types of load don't seem to cause
>> freezes, and I ran memtest86 overnight with no errors. Originally
>> the machine was Ubuntu 8.04 64-bit, then 8.10 64-bit, then 8.10 32-
>> bit, and the problem was seen in all 3. In all cases it was running
>> the UQ-provided AG 3.2beta with the stock VideoProducer services. I
>> know there was a bttv driver deadlock issue in kernels pre-2.6.24,
>> but this is running kernel 2.6.27 so that shouldn't be the problem.
>> Also when sending video on that machine occasionally the stream
>> would start to flicker, flashing an old frame alternating with the
>> current output of the camera. Has anyone seen either of these
>> issues before?
> Andrew,
> I just installed a 32bit Ubuntu 8.10 on the UQVislab node's video
> capture machine. I've been running 2x mpeg4 streams and an h261
> stream for over two hours. I just powered the machine down to
> confirm it is actually an IVC-200G card (it is). After the restart,
> I've now configured it to run with 3x mpeg4 streams. These are full
> PAL streams 704x576. Its been running for nearly 10 minutes now -
> will leave it running overnight (in the APAG lobby, if you want to
> check on them) and report back. Based on the previous successful 2
> hour test, I think this 3 large streams test will be OK too.
Andrew,
We've now had this setup (32bit Ubuntu 8.10 with IVC-200G streaming 3x
mpeg4 streams @ 704x576) running continuously for over three days now
without any discernible problem. That result suggests a hardware issue
with your capture card (or even the machine itself).
chris
> You could try reseating the card - maybe some dust or contact
> oxidation is creating some bad effect? Do you have any similar
> capture cards lying around you could temporarily replace the IVC
> with? That may indicate whether you have a card fault or machine/OS
> fault.
> chris
> Christoph Willing                       +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
