[AG-TECH] Possible problems with the 3.2 Beta "all-in-one-installer"!
Thomas D. Uram
turam at mcs.anl.gov
Fri Mar 6 16:04:25 CST 2009
On Linux, I'm sure USE_H261AS is defined in the Makefile. On Windows,
it is or was missing from the Visual Studio project files.
There's an --enable-gpl configure option and then some related
dependencies (ffmpeg, etc.). On Windows, there are different build
configurations, including some GPL options. If you have trouble building
on any platform, say so because ideally that would be trivial out of the
box and I think that, at least in some cases, that is currently not true.
And with these words, I may be conjuring up Piers to talk about vic,
VS2008, and ffmpeg.
Tom
On 3/6/09 3:56 PM, Andrew Ford wrote:
> Hi Tom,
> Would that only occur on Windows? I checked out the vic 264 branch and
> compiled it on Linux without any special options and it can receive
> the 261as stream.
> A related question: when I run the vic that I just compiled, the 264
> and mpeg4 buttons aren't in the encoder menu. Are there special
> compile-time options for those?
> --Andrew
> 2009/3/6 Thomas D. Uram <turam at mcs.anl.gov <mailto:turam at mcs.anl.gov>>
> The problem is likely that the 264 vic was built without
> 'USE_H261AS' defined.
> Tom
> On 3/6/09 3:25 PM, Andrew Ford wrote:
>> Correction: on Windows, 261as works with the normal version of
>> vic associated with the regular VideoConsumerService and not with
>> the h.264 consumer service. The fact that it doesn't show up at
>> all implies to me that it's a network issue of some kind and not,
>> say, a decoder issue. I might try and take a look at the code
>> next week.
>> --Andrew
>> 2009/3/6 Andrew Ford <acf0659 at rit.edu <mailto:acf0659 at rit.edu>>
>> Hi Jason,
>> We've been seeing the same problems with not being able to
>> receive h261as streams, except that we have AG 3.1 on all of
>> our Windows machines. Our Macs can see 261as streams just
>> fine. Has anyone else tried 261as on Windows?
>> --Andrew
>> 2009/3/3 Jason Bell <j.bell at cqu.edu.au
>> <mailto:j.bell at cqu.edu.au>>
>> G'day All (Apologies for any cross posting)
>> I was wondering if anyone has had any issues with the AG
>> 3.2 Beta "all in one installer" lately?
>> Upon recent testing, last couple of days, I have noticed
>> 2 issues:
>> · VenueVNC not working and users having to follow
>> the instructions found at
>> _http://www.accessgrid.org/node/1031_
>> · Video* Services not displaying H261AS video
>> Streams… When Using VPCScreen, sending a window using
>> H261AS, others are able to see the video streams, but it
>> is completely missing from an AG 3.2 Beta "all in one
>> install". Note, if you use 3.1 "all in one install", it
>> works fine. What is interesting is that it is completely
>> missing, ie, not even a grey thumbnail or the likes can
>> be seen.
>> Has anyone else seen similar issues?
>> Nathan, any chance of investigating these issues and
>> repackaging the “all in one installer”???
>> Thanks,
>> Jason.
>> Jason Bell, B.I.T. (Honours)
>> Research Systems Support Officer
>> Information Technology Division
>> CQ University Australia
>> Australian Research Collaboration Service
>> http://www.arcs.org.au/
>> E-mail : j.bell at cqu.edu.au <mailto:j.bell at cqu.edu.au>
>> jason.bell at arcs.org.au
>> <mailto:jason.bell at arcs.org.au>
>> Work : +61 7 4930 9229
>> Mobile : 0409 630897
>> Postal : Building 19
>> Central Queensland University
>> Bruce Highway
>> Rockhampton, Queensland, Australia, 4702
>> Patience is a virtue.
>> But if I wanted Patience,
>> I would have become a Doctor.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090306/7934af9c/attachment-0001.htm>
