[AG-TECH] Possible problems with the 3.2 Beta "all-in-one-installer"!
Andrew Ford
acf0659 at rit.edu
Fri Mar 6 15:56:18 CST 2009
Hi Tom,
Would that only occur on Windows? I checked out the vic 264 branch and
compiled it on Linux without any special options and it can receive the
261as stream.
A related question: when I run the vic that I just compiled, the 264 and
mpeg4 buttons aren't in the encoder menu. Are there special compile-time
options for those?
--Andrew
2009/3/6 Thomas D. Uram <turam at mcs.anl.gov>
> The problem is likely that the 264 vic was built without 'USE_H261AS'
> defined.
> Tom
> On 3/6/09 3:25 PM, Andrew Ford wrote:
> Correction: on Windows, 261as works with the normal version of vic
> associated with the regular VideoConsumerService and not with the h.264
> consumer service. The fact that it doesn't show up at all implies to me that
> it's a network issue of some kind and not, say, a decoder issue. I might try
> and take a look at the code next week.
> --Andrew
> 2009/3/6 Andrew Ford <acf0659 at rit.edu>
>> Hi Jason,
>> We've been seeing the same problems with not being able to receive h261as
>> streams, except that we have AG 3.1 on all of our Windows machines. Our Macs
>> can see 261as streams just fine. Has anyone else tried 261as on Windows?
>> --Andrew
>> 2009/3/3 Jason Bell <j.bell at cqu.edu.au>
>>> G'day All (Apologies for any cross posting)
>>> I was wondering if anyone has had any issues with the AG 3.2 Beta "all in
>>> one installer" lately?
>>> Upon recent testing, last couple of days, I have noticed 2 issues:
>>> · VenueVNC not working and users having to follow the instructions
>>> found at *http://www.accessgrid.org/node/1031*<http://www.accessgrid.org/node/1031>
>>> · Video* Services not displaying H261AS video Streams… When Using
>>> VPCScreen, sending a window using H261AS, others are able to see the
>>> video streams, but it is completely missing from an AG 3.2 Beta "all in
>>> one install". Note, if you use 3.1 "all in one install", it works fine.
>>> What is interesting is that it is completely missing, ie, not even a
>>> grey thumbnail or the likes can be seen.
>>> Has anyone else seen similar issues?
>>> Nathan, any chance of investigating these issues and repackaging the “all
>>> in one installer”???
>>> Thanks,
>>> Jason.
>>> Jason Bell, B.I.T. (Honours)
>>> Research Systems Support Officer
>>> Information Technology Division
>>> CQ University Australia
>>> Australian Research Collaboration Service
>>> http://www.arcs.org.au/
>>> E-mail : j.bell at cqu.edu.au
>>> jason.bell at arcs.org.au
>>> Work : +61 7 4930 9229
>>> Mobile : 0409 630897
>>> Postal : Building 19
>>> Central Queensland University
>>> Bruce Highway
>>> Rockhampton, Queensland, Australia, 4702
>>> Patience is a virtue.
>>> But if I wanted Patience,
>>> I would have become a Doctor.
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090306/f226fce5/attachment.htm>
