[AG-TECH] Bridge Registry Problem?
Michael Braitmaier
braitmaier at hlrs.de
Thu Jun 25 06:44:16 CDT 2009
In fact I had problems with our AG3.1 bridge server being able to get
its RegistryClient connected to the peers repository. However this
seemed to be a temporary probelm has gone away now, which makes it even
harder to track down. I just realised that at the same time while I had
the problem, after doing a bridge cache update, around 80% of the
bridges were unreachable, which seemed for me not to be a coincidence.
Cheers,
Michael
Adam Carter schrieb:
> Hi Chris (cc list),
> Thanks for your reply. I can see now the difference between the web
> service that returns the bridge list and the list of bridges itself,
> so the fact that the list only has one entry no longer worries me.
> However, is it possible that bridges are trying to add their entry to
> the Argonne server, failing for some reason (possibly due to the way
> that the server at Argonne has been configured?), and then not
> launching properly themselves because of this? This would explain the
> behaviour that I've had reported to me that bridges will not go back
> up when they've gone down... If others who are using a bridge have not
> noticed the problem, then I guess it's some other problem with the
> bridge, but I thought I'd check first. I see that Michael M has
> restarted his bridge, apparently with no problems, so I assume that
> it's something at the other end...
> Cheers,
> Adam
> Christoph Willing wrote:
>> On 16/06/2009, at 11:07 PM, Adam Carter wrote:
>>> Hi,
>>> Recently I've noticed that a couple of unicast bridges I've tried to
>>> contact have been unavailable. When I spoke to Michael Braitmaier in
>>> Stuttgart he said that his bridge server was not restarting because
>>> it couldn't access the peers.txt list on the Argonne Server.
>>> Checking in the Venue Client in my list of bridge servers, nearly
>>> all of them show up as unreachable. I can still connect to those
>>> which are still up and running at their original addresses, but I
>>> suspect this is also related to the peers file. When I put the peers
>>> file url into a browser it shows only one entry, namely that of
>>> Argonne. Is this deliberate, or an oversight?
>> Adam,
>> The peers.txt will normally contain just a single entry consisting of
>> the name of a machine and the port at which a particular web service
>> is running. Bridges register with that web service when they start up
>> and, when queried the right way, that web service returns the list of
>> bridges that have registered.
>> In short, the minimal content of peers.txt is not the reason why some
>> bridges end up being unreachable.
>> chris
>> Christoph Willing +61 7 3365 8316
>> QCIF Access Grid Manager
>> University of Queensland
