[AG-TECH] sending dv/hdv via accessgrid all in one
Gurcharan S. Khanna
gurcharan.khanna at rit.edu
Sat Jul 18 17:15:17 CDT 2009
muhammad,
it's not a matter of horsepower at all i think.
1. what venue are you sending to? (let's see if anyone else in the world
can receive it).
2. on the receiver machine, does a window come up when you enable
ExtendedVideoConsumer
services? you should get a little window showing every DV stream visible
in that venue,
listed by IP address, Port, etc. it might be minimized and need to be
opened from the Task Bar
3. if you get that window, you need to click on each of those text lines
to bring up
the DVTS window.
4. open Task Manager and see how many bits are coming into the machine.
each DVTS stream
will show up as about 30 Mbits each.
-gurcharan
muhammad akl wrote:
> hi Gurcharan,
> well, the problem mainly is that i'm unable to receive my video signal
> at the receiver side , which actually i can see it via DVTS program at
> the sending side
> let's explain my setup in more details , i've two pcs their specs as
> follows :
> Sender PC
> OS : Windows XP SP3
> AccessGrid Ver : 3.2 Beta version ( All in one Installer made by
> http://www.hitlabnz.org/wiki/Access_Grid_-_Easy_Installer)
> Processor: Intel core 2 duo 2.3 GHZ
> Ram : 2 GB
> VGA Card : Nvidia 8400 GS ( Driver installed via nvidia website )
> Ethernet Type : Gigabit ethernet
> Firewire ports : External Pci card has two IEEE-1394 ports
> Input Camera : Sony DCR-TRV285E
> Receiver PC
> OS : Windows XP SP3
> Processor : intel pentium D 3.4 GHZ
> Ram : 512 MB
> Ethernet type : fast ethernet
> Now , The sender Pc is configured to Start sending Digital Video via
> ExtendedVideoServiceProducer Option which is found in the AccessGrid
> node management menu , that i've included during the installation of
> AccessGrid , And at this time i can see my video signal via DVTS program
> At the Receiver Side , I've started AccessGrid and configured It to
> use The ExtendedVideoConsumerService from AccessGrid node Management
> menu by adding a new service , and at this time i can not see anything
> , and no error messages appeared
> does my setup lacks something that's i've fogotten to do , or does i
> need much horse power for my PCS ?
> if though , what are the necessary steps to be done to be able to send
> and/or receive dv/hdv on windows xp ?
> Regards
> Muhammad
> On Sat, Jul 18, 2009 at 5:31 PM, Gurcharan S. Khanna
> <gurcharan.khanna at rit.edu <mailto:gurcharan.khanna at rit.edu>> wrote:
> hi,
> we use it constantly. can you give us more details about your problem?
> e.g., specific error messages?
> -gurcharan
> muhammad akl wrote:
> hello,
> I've just installed the recent all in one accessgrid package
> on windows xp , the installation process went fine ,
> and i've added the extended video services during the
> installation as I want to start sedning dv/hdv video via
> firewire cameras ,
> after i've joined the lobby , i've configured the
> ExtendedVideoProducerService , and I can see my video fine via
> the DVTS program ,
> but the problem that i'm unable to receive it via
> ExtendedVideoConsumerService ,I've tried several times to
> enable and disable the service with no luck
> Anyone had a previous experience on how to get dv/hdv video
> on windows xp using this all in one (which includes the DVTS ) ?
> also anyone tried the enhanced vic that was made by vislab
> team (chris willing ) on windows xp and successed to integrate
> it with accessgrid ?
> Gurcharan S. Khanna, Ph.D.
> Director of Research Computing
> Office of the Vice President for Research
> http://rc.rit.edu <http://rc.rit.edu/>
> Assistant Research Professor, Ph.D. Program
> Golisano College of Computing and Information Sciences
> http://people.rit.edu/gskpop
> Director, Interactive Collaboration Environments Laboratory,
> Center for the Advancing the Study of Cyberinfrastructure
> http://icelab.rit.edu <http://icelab.rit.edu/>
> Rochester Institute of Technology
> 1 Lomb Memorial Drive
> Rochester, New York 14623-5603
> Phone: 585-475-7504 ~ Cell: 585-451-8370
> Email: gurcharan.khanna at rit.edu <mailto:gurcharan.khanna at rit.edu>
http://rc.rit.edu
