[AG-TECH] BlackMagic HDMI vic beta download
Andrew Ford
acf0659 at rit.edu
Wed Feb 18 10:28:59 CST 2009
Gurcharan,
The only difference between the Intensity and Decklink cards format-wise is
that the Decklink cards support 24PsF, which I don't think vic is using -
all Blackmagic capture cards support 1080i50, 1080i60, 720p50 and 720p60. As
Changhyeok said vic currently only supports 1920x1080 at 25fps, presumably
meaning 1080i50, which is a PAL format.
--Andrew
2009/2/18 Gurcharan S. Khanna <gurcharan.khanna at rit.edu>
> Mike,
> are you using the Intensity Pro or the Decklink ExtremeHD card? i am
> suspecting
> there are differences between the two. i've seen 30 fps v 60 fps as the
> specs for the
> Decklink v. the Intensity come up on its GUI and don't know why this is the
> case.
> thanks,
> -gurcharan
> Mike.W.Daley at cs.cardiff.ac.uk wrote:
>> Hi All
>> Just to clarify.
>> I'm using a SONY HDR-SR12E camera.
>> I've tested it both in PAL and NTSC formats at 1080i and its all fine.
>> In resting phase. (very little activity) I'm getting 1.8M/s transfer rate.
>> Mike
>> Quoting Nathan Gardiner <nathan.gardiner at canterbury.ac.nz>:
>> We have had problems trying to get an AVCHD camcorder to work with
>>> BlackMagic card and i think most AVCHD camcorders that I tested didn't
>>> seem to have true HDMI realtime output.
>>> I don't think that NTSC and PAL should make much difference as the
>>> BlackMagic card accepts input from either or.
>>> Also, we should have a new JVC camcorder arriving in the next day or
>>> so and will be testing that out.
>>> Regards,
>>> Nathan
>>> On 18/02/2009, at 11:56 AM, Jimmy Miklavcic wrote:
>>> I did check it a while back and it was fine. I had to install a
>>>> graphics card in order for Media Express to work. Right now I'm using the
>>>> on-board VGA for the display. I didn't think I needed a high-end display
>>>> card just to run the service manager. Anyway I think you and I are seeing
>>>> the same symptoms. I'm using 720 @ 30p.
>>>> Jimmy
>>>> Jimmy Miklavcic
>>>> Multimedia Specialist
>>>> Jimmy.Miklavcic at utah.edu
>>>> UNIVERSITY OF UTAH
>>>> CTR FOR HIGH PERFORM COMPUTING
>>>> 155 SOUTH 1452 EAST RM 405
>>>> SALT LAKE CITY, UT 84112-0190
>>>> Office: 801.585.9335
>>>> Fax: 801.585.5366
>>>> http://www.anotherlanguage.org
>>>> From: adhesionmusic at gmail.com [mailto:adhesionmusic at gmail.com] On
>>>> Behalf Of Andrew Ford
>>>> Sent: Tuesday, February 17, 2009 2:43 PM
>>>> To: Jimmy Miklavcic
>>>> Cc: Mike.W.Daley at cs.cardiff.ac.uk; Nathan Gardiner; ag-
>>>> tech at mcs.anl.gov
>>>> Subject: Re: [AG-TECH] BlackMagic HDMI vic beta download
>>>> Hi Jimmy,
>>>> Did you try checking the HDMI input directly, via either Blackmagic
>>>> Media Express or AMCap? If that works then we probably have the same
>>>> problem - I can see the video fine in Media Express but vic just shows a
>>>> black screen with any codec or size. Here we have the Blackmagic Intensity
>>>> Pro cards with Sony HDR-SR11 cameras, which are AVCHD. Side note: I don't
>>>> think the recording format makes much of a difference, just the specific
>>>> video format, as in 1080i at a certain framerate.
>>>> Nathan, is vic expecting a certain framerate? The format that worked
>>>> with Media Express was 1080i @ 59.97. If it's only been tested with PAL
>>>> so far, I would hazard a guess and say that the NTSC isn't using the right
>>>> format/framerate in some way.
>>>> --Andrew
>>>> 2009/2/17 Jimmy Miklavcic <jimmy.miklavcic at utah.edu>
>>>> Mike, it's great news that you have been able to get HIT Lab's vic to
>>>> work. I haven't been so lucky. I have AVCHD (Panasonic AG-HMC150) video
>>>> cameras. Mike I think that you have MPEG2 based HD cameras. Are yours
>>>> Sony? Nathan, I don't think you tested with an AVCHD camera.
>>>> All I get is black, which I think tells me that it sees the video card
>>>> but not, the video stream. Mike, did you use 1080i/p or 720p?
>>>> If anyone has any suggestions, I'm open.
>>>> Jimmy
>>>> Jimmy Miklavcic
>>>> UNIVERSITY OF UTAH
>>>> Fax: 801.585.5366
>>>> -----Original Message-----
>>>> From: ag-tech-bounces at lists.mcs.anl.gov
>>>> [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of
>>>> Sent: Tuesday, February 17, 2009 1:52 AM
>>>> To: Nathan Gardiner
>>>> Cc: ag-tech at mcs.anl.gov; Mike.W.Daley at cs.cardiff.ac.uk
>>>> Hi Nathan
>>>> Thanks otherwise all looking good.
>>>> Not bad on bandwidth usage either.
>>>> Mike
>> Michael Daley M.Phil MBCS GCFA
>> This message was sent using IMP, the Internet Messaging Program.
> Gurcharan S. Khanna, Ph.D.
> Director of Research Computing
> Office of the Vice President for Research
> http://rc.rit.edu
> Assistant Research Professor, Ph.D. Program
> Golisano College of Computing and Information Sciences
> http://people.rit.edu/gskpop
> Director, Interactive Collaboration Environments Laboratory,
> Center for the Advancing the Study of Cyberinfrastructure
> http://icelab.rit.edu
> Rochester Institute of Technology
> 1 Lomb Memorial Drive
> Rochester, New York 14623-5603
> Phone: 585-475-7504 ~ Cell: 585-451-8370
> Email: gurcharan.khanna at rit.edu
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20090218/edf28b66/attachment.htm>
