[AG-TECH] Vista weirdness
Tran, Quang V.
qtran3 at lsuhsc.edu
Wed Feb 18 08:35:28 CST 2009
Don,
I got the same error yesterday with AG3.1 on Vista. Have you find a solution for it?
Quang
Quang Tran
LSUHSC
(504) 568-2877
-----Original Message-----
From: ag-tech-bounces at lists.mcs.anl.gov [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Don McLane
Sent: Saturday, January 03, 2009 4:41 PM
To: ag-tech at mcs.anl.gov
Subject: Re: [AG-TECH] Vista weirdness
Michael,
Interesting ... VideoService works for unicast, but not multicast!
Thanks, since I didn't know what VideoService was, I would never have
tried it, if not for your suggestion.
Yes, I didn't have VideoProducerService running when I captured that
log. I had eliminated it as the source of the problem. I get the error
whether VideoProducerService is running or not.
I'm running 3.2beta right now, although I get the same error with 3.1.
Of course Vista is not supported. I have an XP system running just
fine. But I want to set up a demo for some colleagues and it would be
convenient if this **** Vista system would work.
Don
Michael Miller wrote:
> Don,
> I recall seeing this when I chose "Microsoft WDM..." for the video device in the VideoProducerService configuration. I went back and picked my specific video camera rather than the "Microsoft WDM..." driver and that fixed it. But I don't see the VideoProducerService mentioned in the log you included. You might try the VideoService service which will both "consume" and "produce" video. What type of camera/capture card are you using?
> Michael Miller
> NCSA
> "If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
> From: "Don McLane" <dmclane at u.washington.edu>
> Sent: Friday, January 2, 2009 3:34:52 PM GMT -06:00 US/Canada Central
> Subject: [AG-TECH] Vista weirdness
> When I try to connect to a Venue, the jabber client appears to connect
> OK, but then I get:
> Error from vic.exe:
> bind: An invalid argument was supplied.
> I've included the entire log of an attempted session below. Can anyone
> suggest something?
> Thanks,
> Don
