[AG-TECH] Strange Windows XP RAT issue
Enrique Terrazas
Enrique.Terrazas at ucsf.edu
Mon Feb 16 11:44:57 CST 2009
Michael,
Thanks for your suggestion ... I'll try toggling the talk on/off
settings to see what effect that has.
Unfortunately, modifying the shortcut won't solve it as RAT is not
initialized until you enter a venue, and is also initialized when you
switch venues.
I think the 960 has two PCI slots (one is taken up by the video
board), so I may have to buy a sound card and bypass the onboard audio
if I have a spare PCI slot.
Enrique Terrazas
On Feb 16, 2009, at 9:32 AM, Michael Miller wrote:
> Enrique,
> Not sure how to fix it, perhaps the talk on/off settings in the
> AudioService config?
> As for the command line, you could add the command at the end of the
> target field of the AG shortcut properties dialog box. Just
> separate it from the AG command with a ; and the shortcut should run
> both commands.
> Let me know how it goes.
> myk
Enrique Terrazas, MD, MS
Director, Laboratory Medicine Residency Program
Director, NCPL Laboratories
Chief, Laboratory Information Systems
HS Associate Clinical Professor
University of California, San Francisco
Clinical Laboratories, Box 0100
4-8931, 415.514.8931(voice)
3-4826, 415.353.4826(fax)
415.443.0913(pager)
CONFIDENTIALITY NOTICE: The information contained in this
transmission, including any enclosed files, is confidential and
intended solely for the addressee. If you are not the intended
recipient, you are hereby notified that any distribution, copying,
disclosure and use of, the contents of this transmission is strictly
prohibited. If you have received this communication in error, please
notify the sender immediately by reply email and permanently delete
this message, enclosures and all copies.
