[AG-TECH] VenueVNC working under Fedora 10
Jason Bell
j.bell at cqu.edu.au
Mon Feb 16 00:38:52 CST 2009
G'day All
If anyone is having trouble getting VenueVNC working under Fedora 10, I
have updated the install guide to show how to fix this issue. See
http://www.accessgrid.org/node/1768.
Basically, what is required is to ensure xterm installed (this will be
added as a dependency shortly [no longer install in fedora by default]).
To check that it has been installed, issue the command:
yum list xterm
If it says it is installed, then VenueVNC should work fine, otherwise
issue the following command to install xterm:
yum install xterm
Cheers,
Jason.
Jason Bell, B.I.T. (Honours)
Research Systems Support Officer
Information Technology Division
CQ University Australia
Australian Research Collaboration Service
http://www.arcs.org.au/
E-mail : j.bell at cqu.edu.au
jason.bell at arcs.org.au
Work : +61 7 4930 9229
Mobile : 0409 630897
Postal : Building 19
Central Queensland University
Bruce Highway
Rockhampton, Queensland, Australia, 4702
Patience is a virtue.
But if I wanted Patience,
I would have become a Doctor.
