[AG-TECH] Hardwire control of cameras
Mike Weaver
weaver at ascr.doe.gov
Wed Feb 4 13:12:14 CST 2009
Hi John,
Sony EVI-D70 cameras support the VISCA protocol (a Sony creation). There
are many ways in both software and hardware to control these cameras. I use
Canon VC-C4s so my experience is not directly applicable, but it should be
the same for the Sony cams.
VISC is a serial protocol (since it runs over RS-232) so you can daisy-chain
your cameras all to one serial port. You should be able to use any
VISCA-compliant software application. I use a hardware controller - a
Telemetrics CP-ITV-VC4. See
http://www.telemetricsinc.com/index.php?page=shop.product_details&flypage=fl
ypage-telem.tpl&product_id=186&category_id=52&option=com_virtuemart&Itemid=6
for it's replacement - the CP-ITV-D300. This states that it is EVI-D70
compatible.
You obviously need the proper cables. Look for VISCA, cable & EVI-D70 in
Google, you should find tons of hits.
Note, the cable from your controller (either PC or hardware device) is DB-9
at one end and an 8-pin mini-DIN at the other. The interconnect cables are
8-pin mini-DIN at both ends.
Hope this helps,
Mike
Mike Weaver
US Department of Energy
ASCR/SC-21.1
Germantown Building
Voice: 301-903-0072
Fax: 301-903-7774
Email: weaver at ascr.doe.gov
> -----Original Message-----
> From: ag-tech-bounces at lists.mcs.anl.gov
> [mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of John Maher
> Sent: Wednesday, February 04, 2009 13:52
> To: ag-tech at mcs.anl.gov
> Subject: [AG-TECH] Hardwire control of cameras
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Does anyone have experience controlling Sony EVI-D70 cameras
> using rs232
> connections? If so, I would very much like to know how to implement
> such a setup. I questions like:
> - - Do you use the Sony "demo" software or something else?
> - - Should the computer controlling the cameras have a
> multiport serial
> card (or multiple serial cards), or is there a better way.
> Any information would be welcome.
> Thanks.
> John
> John Maher
> Senior Systems and Network Administrator
> Department of Biochemistry & Molecular Biology and
> Department of Chemistry
> University of Massachusetts - Amherst
> voice: 413-577-3120 fax: 413-545-4490
> OpenPGP Key ID: 0x2970A144
> Want your email to be private? http://enigmail.mozdev.org
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.6 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFJiePfG+X1pClwoUQRAmObAJ9pmvogFxDgQ99G748RJYGjGWYPPQCfVQfr
> +ok7uhKfsMz5gnrs5nvRyao=
> =Vrr6
> -----END PGP SIGNATURE-----
