[AG-TECH] Acess grid
Christoph Willing
c.willing at uq.edu.au
Thu Apr 30 17:39:18 CDT 2009
On 01/05/2009, at 8:18 AM, Gallegos, Joel T wrote:
> How can I create the setup under a different name.
Open the Node Management tool ("Tools->Configure node services" menu,
or use the toolbox button). It will show your current setup. Change it
as you want, then store it using the Node Management tool's "File-
>Store Configuration" menu - it will ask for a (new) name and you
will also have the option set the new configuration as the default.
chris
> -----Original Message-----
> From: Christoph Willing <c.willing at uq.edu.au>
> Sent: Thursday, April 30, 2009 5:10 PM
> To: Gallegos, Joel T <gallegosj3 at uthscsa.edu>
> Cc: AG-TECH list <ag-tech at mcs.anl.gov>
> Subject: Re: [AG-TECH] Acess grid
> On 01/05/2009, at 8:01 AM, Gallegos, Joel T wrote:
>> Is there any way to change the VPS to unmated, maybe in a settings
>> option. I hate to mess up the configuration by removing the services.
> Joel,
> Presumeably your current setup is stored already. You can change this
> as much as you like, storing any new setup under a different name i.e.
> you can always return to your current setup if you need to. If the new
> setup turns out better, you can make it your default (by storing it
> again an enabling the checkbox to make it the default).
> chris
>> From: Christoph Willing [mailto:c.willing at uq.edu.au]
>> Sent: Thursday, April 30, 2009 4:24 PM
>> On 01/05/2009, at 6:48 AM, Gallegos, Joel T wrote:
>>> I was wondering if the default setting in VIC can be changed.
>>> Default is
>>> mute, can it be changed to unmute.
>> Joel,
>> Are you using a VideoProducerService (perhaps together with
>> VideoConsumerService)? If so, try removing them and replace with a
>> plain VideoService, which starts up unmuted by default and also
>> receives incoming video.
>> chris
>> Christoph Willing +61 7 3365 8316
>> QCIF Access Grid Manager
>> University of Queensland
