[AG-TECH] Acess grid
Christoph Willing
c.willing at uq.edu.au
Thu Apr 30 17:10:49 CDT 2009
On 01/05/2009, at 8:01 AM, Gallegos, Joel T wrote:
> Is there any way to change the VPS to unmated, maybe in a settings
> option. I hate to mess up the configuration by removing the services.
Joel,
Presumeably your current setup is stored already. You can change this
as much as you like, storing any new setup under a different name i.e.
you can always return to your current setup if you need to. If the new
setup turns out better, you can make it your default (by storing it
again an enabling the checkbox to make it the default).
chris
> -----Original Message-----
> From: Christoph Willing [mailto:c.willing at uq.edu.au]
> Sent: Thursday, April 30, 2009 4:24 PM
> To: Gallegos, Joel T
> Subject: Re: [AG-TECH] Acess grid
> On 01/05/2009, at 6:48 AM, Gallegos, Joel T wrote:
>> I was wondering if the default setting in VIC can be changed.
>> Default is
>> mute, can it be changed to unmute.
> Joel,
> Are you using a VideoProducerService (perhaps together with
> VideoConsumerService)? If so, try removing them and replace with a
> plain VideoService, which starts up unmuted by default and also
> receives incoming video.
> chris
> Christoph Willing +61 7 3365 8316
> QCIF Access Grid Manager
> University of Queensland
