[AG-TECH] AG on Vista - Success Anyone??
Michael Miller
mimiller at ncsa.uiuc.edu
Wed Apr 15 16:06:26 CDT 2009
Jason,
Search for an AG-Tech thread "Vista Weirdness". I had posted about my experience with Vista and vic. Something to do with picking my specific video driver rather than WDM MS 32...
hope this helps
myk
"If you're clear in your vision and trust the people in your team with clear objectives, they will invariably do their best to achieve everything desired, and usually deliver everything you could have hoped for and even more." -Paul Debevec
----- Original Message -----
From: "Jon Johansson" <jon.johansson at ualberta.ca>
To: "Jason Bell" <j.bell at cqu.edu.au>, ag-tech at mcs.anl.gov
Sent: Tuesday, April 14, 2009 12:28:14 PM GMT -06:00 US/Canada Central
Subject: Re: [AG-TECH] AG on Vista - Success Anyone??
Hi Jason,
I've been running a personal node on a Vista x64 system for
months now. It started off working perfectly with AG 3.1
and when I tried the 3.2 beta I didn't have much success so
I went back to 3.1. It doesn't work as well as it used to
on one respect; when I enter a venue or change between
multicast and unicast I get a message from vic.exe saying
"bind: An invalid argument was supplied."
The producer vic starts but the consumer vic doesn't. I have to
unmute the producer vic windows to see video, but otherwise both
audio and video work fine. If I try to use a "VideoService"
instead of separate producer and consumers, the service addition
fails with a Message: "Add Service failed:VideoService",
I haven't had time to fiddle with the software, so a clean
reinstall might make it work again, although as I recall I was
trying the 3.2 beta around the time that Vista SP1 came out,
so the problem might have been introduced with that.
I didn't do anything special for the install, just downloaded
dependencies using the AG website links.
I'm using a Logitech Communicate STX camera and whatever the
onboard audio on a Thunder K8WE MB is, with Vista Enterprise x64.
Jon.
~~ Jon I Johansson, Ph.D. * Tel.: (780) 492-9304 ~~
~~ jon.johansson at ualberta.ca * Fax.: (780) 492-1729 ~~
~~ * Office: G.S.B. 323C ~~
~~ Visualization Analyst http://sciviz.aict.ualberta.ca ~~
~~ Research Computing Support ~~
~~ Room 352, General Services Building ~~
~~ Academic Information and Communication Technologies (AICT) ~~
~~ University of Alberta ~~
~~ Edmonton, Alberta, CANADA, T6G 2H1 ~~
! "This communication is intended for the use of the recipient to !
! which it is addressed, and may contain confidential, personal, !
! and/or privileged information. Please contact us immediately !
! if you are not the intended recipient of this communication. !
! If you are not the intended recipient of this communication, !
! do not copy, distribute, or take action on it. Any !
! communication received in error, or subsequent reply, should !
! be deleted or destroyed." !
[mailto:ag-tech-bounces at lists.mcs.anl.gov] On Behalf Of Jason Bell
Sent: Tuesday, April 14, 2009 4:23 AM
To: ag-tech at mcs.anl.gov
Subject: [AG-TECH] AG on Vista - Success Anyone??
G’day All
Just a quick one! I was wondering if anyone has had any success with
having the AG working on Vista ?
If you have, can you tell me the following info please?
• Which version were you using (3.1 or 3.2 beta?, the all in one
installer, or the separate packages);
• Does all of the following work:
o Vic
o Rat
o VPCScreen
o VenueVNC
• Was there anything special you had to do to get it working.
The reason for the question is I “quickly” tried installing the software
on Vista and had some pythonw errors. Before I investigate further
tomorrow, I am just wanting to hear if anyone has had any success and
was there anything special you had to do to get it working?
Many thanks in advance,
Jason.
Jason Bell, B.I.T. (Honours)
Research Systems Support Officer
Information Technology Division
CQ University Australia
Australian Research Collaboration Service
http://www.arcs.org.au/
E-mail : j.bell at cqu.edu.au
jason.bell at arcs.org.au
Work : +61 7 4930 9229
Mobile : 0409 630897
Postal : Building 19
Central Queensland University
Bruce Highway
Rockhampton, Queensland, Australia, 4702
Patience is a virtue.
But if I wanted Patience,
I would have become a Doctor.
