[AG-TECH] Using AGVCR with latest Video Producer
Douglas Kosovic
douglask at itee.uq.edu.au
Tue Apr 7 05:58:52 CDT 2009
Hi Ben,
>>From what I can tell, the current AGVCR will not play back recorded video streams from an H264 or Extended Video service.
> I'm guessing that it's because AGVCR uses an 'old' version of vic.exe
> Has anyone tried 'upgrading' the vic.exe that AGVCR uses ?
You didn't mention if you are using the AGVCR Launcher from the
VenueClient or manually setting the host and port details for the audio
and video streams within AGVCR.
The H264 and Extended Video services are configured to use different
ports than the standard H261 Video service, so I suspect that's the
reason you aren't recording them.
Doug
