[AG-TECH] H.264 video window aspect ratio incorrect - Windows XP Logitech Quickcam Pro 9000 - Toolkit V3.1 stable
Douglas Kosovic
douglask at itee.uq.edu.au
Wed Apr 1 04:16:32 CDT 2009
Hi Ben,
> When running VideoProducerH264 with the current stable release of
> Toolkit, I get some 'geometry error' messages when the video device
> initialises. I can click OK on these messages, and my video appears,
so
> I'm not too concerned about them.
It's been fixed in SVN.
> But the problem is that my video is quite small, and within a large
> grey box (see attachment h264-default.jpg).
> The latter also occurs if a remote Toolkit user (running
> VideoConsumerServerH264) changes the window size of my transmitted
> video using the S, M and L keys.
> Any ideas ?
With newer versions of VIC, you can use the right mouse button on a
video window and select half, original or double size, while preserving
the aspect ratio.
Could you try replacing the vic.exe you are using with the one from
(which uses newer code from SVN) :
http://www.vislab.uq.edu.au/ag3/windows/vic-20090127.zip
The older vic.exe would most likely be found in the VideoConsumerService
or VideoService folders found under something like:
C:\Documents and Settings\{username}\Application
Data\AccessGrid3\local_services\
I suspect you'll now get a (smaller) black box for small and medium
capture, but should disappear for large MPEG-4 or H.264 capture.
In the past, shift-S, shift-M and shift L would clip, but now it
resizes.
Cheers,
Doug
