[AG-TECH] Random crashes
Natalia Costas Lago
natalia at cesga.es
Fri Oct 24 02:58:10 CDT 2008
Hi Chris,
Yes, it's on windows. Though I have a personal node on windows as well
and I havent had problems before and for a long time. Lately I
installed a personal node on my new PC and I experienced RAT crashing.
What I appreciated is that a perl proccess was consuming a lot of CPU
on the server that acts as Venue Server and Bridge Server. I think
that process affected the bridge and maybe RAT had lost some mbus
packets.
I eliminated the process that was causing the bridge/venue server
unstability and the system has been stable since then.
I think the problem other nodes have might be related to network
conditions that affect this mbus connection and that RAT doesnt like
very much.
I will try to check that.
Con fecha viernes, 24 de octubre de 2008, 2:24:59, escribió:
> Hello Natalia
> Are you using MS Windows?
> When we were using Windows on our main nodes, we had lots of problems
> with the RAT hanging. This was caused by a mbus issue - when the mouse
> was moved around quickly. I thought this was documented somewhere??
> Finally went to linux and haven't had any problems since.
> regards
> Chris Sheerman
> University of Western Sydney
> School of Computing and Mathematics
> Stanford P. wrote:
>> We had a few instances recently where we found that our RAT (in 3.0.2 running on Linux) would crash when one other AG site had
>> selected a strange audio codec. They seemed to be OK but other sites apart from us also found that their RAT would hang.
>> When they changed back to the same default codec as others (I think it was Linear 16 but can't remember) it seemed to stop the
>> crashes.
>> It might be worth checking that all sites in the meeting are set up the same in RAT.
>> Regards
>> Phil
>> On 22/10/2008 10:43, "Natalia Costas Lago" <natalia at cesga.es> wrote:
>> Hi everybody,
>> We are trying to debug some problems related to some random hangs of
>> RAT audio tool.
>> I suspect that unicast connectivity is some way linked to those random
>> crashes.
>> Does someone have similar problems?
>> I have found a parameter in .AccessGrid/Config/preferences that says
>> "multicast = 1", ¿what is this parameter for?
>> Thanking you in advance,
>> Kind regards,
>> Natalia Costas Lago
>> Técnico de Comunicaciones - Dpto. de Comunicaciones
>> Centro de Supercomputacion de Galicia (CESGA)
>> Avenida de Vigo, s/n (Campus Sur)
>> 15705 Santiago de Compostela - SPAIN
>> E-mail: natalia at cesga.es
>> Tel: +34 981 56 98 10 (ext. 237)
>> Fax: +34 981 59 46 16
>> Web: http://www.cesga.es/
Natalia Costas Lago
