[AG-TECH] VenueClient crashes
muhammad akl
muhammad.akl at gmail.com
Thu Oct 23 10:07:14 CDT 2008
Christoph,
Well, Firstly thanks alot for those massive informations , really appreciate
your help.
For now , I'm using two computers their specifications as following :
The first One : Sun ultra-20 m2
CPU : amd 1.86 GHZ dual core
Ram : 1 GB
EThernet Connection : 1 Gbps
Video card : nvidia 8400 GT 512 MB
The second one with the following specifications :
CPU: Intel core 2 duo 2 GHZ
RAM : 2 GB
Video Card : nvidia 8400 GT 512 MB
Ethernet Connection: 1 Gbps
The two computers are running ubuntu hardy with aghdvic and accessgrid3.1 .
The first computer is prepared to produce DV using the DVideoService (using
SimpleHDVideoService, I was not able to get the video from camera) , and
everything is working seamlessly without troubles .
I prepared the second one to participate in my node but the problem as
mentioned before is that I'm not able to see any video from the first
computer , the question now : you mentioned in your previous mail that DV
uses different addresses for transmitting DV and HDV :
The DV/HDV services provided by the aghdvic package use a different
> multicast address to the standard H261 video which is why the other
> participants could not see your stream
How could i configure these addresses , in which config file i must edit
these addresses ?
P.s : I was trying to use DVideoConsumerService with the second computer but
usually i got a pop-up message contains the following :
"Add Service failed : DVideoConsumerService "
Regards
Muhammad
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20081023/2e422b8c/attachment.htm>
