[AG-TECH] Programmatic access to AG node database
Thomas D. Uram
turam at mcs.anl.gov
Wed Nov 26 13:58:16 CST 2008
Some time ago, I began to expose the AG Node Listings from
www.accessgrid.org via a programmatic interface, after this arose in
discussions I'd had with several people. I've now finished a first,
very simple version of such an interface. Using it, one can retrieve
node information from accessgrid.org as XML, for inclusion in websites
or other documentation, and as KML, for use with Google Maps, Google
Earth, or anything else that consumes KML.
I'll write up a document about this interface eventually, but would like
to include feedback on how the interface might be improved first, so
please do send feedback. If you use it, I'd be interested to know how.
Retrieving this information is done using URLs as follows:
http://www.accessgrid.org/nodeinfo.php?format=xml
http://www.accessgrid.org/nodeinfo.php?format=kml
One method of query is currently possible, using the country keyword:
http://www.accessgrid.org/nodeinfo.php?format=xml&country=es
http://www.accessgrid.org/nodeinfo.php?format=kml&country=es
The latter will return KML formatted data for all nodes in Spain. Note
that the value for 'country' is the abbreviation used for internet
domains (TLDs). Lists of these abound on the web.
One useful thing enabled by this interface is generation of
country-specific maps of AG nodes. To this end, one would go to
maps.google.com, select MyMaps, create a new map, and give the URL above
(with the appropriate country code). From the resulting map, choose the
Link option. An example image from GoogleMaps is below (clearly one of
the nodes has wandered outside of Spain and needs its lat/long
updated). Also, there's an image from GoogleEarth of all AG nodes.
Tom
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20081126/8394f701/attachment.htm>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20081126/8394f701/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20081126/8394f701/attachment-0001.png>
