[AG-TECH] Transmit as "Large" using Mpeg4 under windows?
Thomas D. Uram
turam at mcs.anl.gov
Tue Nov 11 16:41:05 CST 2008
Send along all related log files from
c:\documents and settings\USERNAME\Application Data\AccessGrid3\Logs
Tom
On 11/11/08 4:37 PM, Gurcharan S. Khanna wrote:
> Tom,
> ok, here's one specific scenario:
> WindowsXP, latest online updates.
> AG 3.2b1
> Add Service VideoProducerServiceH264
> Popup: Error Enabling Service
> Configure the service: popup shows no device recognized
> Devices are working for H.261 and worked under 3.1;
> they are analog inputs to Videum 4 channel capture card
> Can add VideoProducerService, configure it to accept Videum channel,
> and works fine.
> also worked fine under 3.1
> For ExtendedVideoConsumerService, no popup pops up to show incoming DV
> streams.
> Listed in Services as running.
> I can ADD this service but then cannot disable it (popup: Error
> Disabling Service)
> I can REMOVE this service
> what else can i tell you?
> thanks,
> -gurcharan
> Thomas D. Uram wrote:
>> Can we detail the failures? It has worked for me, and continues to
>> work, so I'm confident we can resolve the problems you're having.
>> What error messages are you getting? With which actions does it
>> occur? Any other useful related details?
>> The AG bugzilla front page used to point at this page, which I think
>> contains a lot of good info to use when reporting problems:
>> http://www.chiark.greenend.org.uk/~sgtatham/bugs.html
>> Tom
>> On 11/9/08 12:41 PM, Gurcharan S. Khanna wrote:
>>> jason,
>>> as i mentioned a few days ago, after installing AG 3.2b1 i can no
>>> longer transmit H.264 or
>>> receive AGDV streams.
>>> can anybody?
>>> -gurcharan
>>> Jason Bell wrote:
>>>> G'day all
>>>> Just a quick questions, but has anyone been able to transmit as
>>>> "Large"
>>>> The reason why I ask is that I have tried, but failed, but I
>>>> suspect it
>>>> is more to do with the usb camera I am using, rather than the actual
>>>> software?
>>>> Thanks,
>>>> Jason.
>>>> Jason Bell, B.I.T. (Honours)
>>>> Research Systems Support Officer
>>>> Information Technology Division CQ University Australia
>>>> Australian Research Collaboration Service
>>>> http://www.arcs.org.au/
>>>> E-mail : j.bell at cqu.edu.au
>>>> jason.bell at arcs.org.au
>>>> Work : +61 7 4930 9229
>>>> Mobile : 0409 630897
>>>> Postal : Building 19
>>>> Central Queensland University
>>>> Bruce Highway
>>>> Rockhampton, Queensland, Australia, 4702
>>>> Patience is a virtue.
>>>> But if I wanted Patience,
>>>> I would have become a Doctor.
