[AG-TECH] Mac OS 10.5.5 - bridges, mouse clicks
Christoph Willing
c.willing at uq.edu.au
Sun Nov 9 23:30:39 CST 2008
On 10/11/2008, at 3:05 PM, Christoph Willing wrote:
> On 10/11/2008, at 11:48 AM, Richard Rodgers wrote:
> [snip]
>> On a separate note, though, when it first came up, it tested 31
>> bridges, then complained that
>> bridges were disabled and suggested that I look in Preferences to
>> remedy that. I opened
>> Preferences, and selected "Bridging," and indeed every bridge
>> appears as "Disabled." Above
>> the list of bridges the popup instructs one to "Right-click a
>> bridge below to enable or disable it."
>> I have no clue what they mean by "right-click" on a Mac. I tried
>> holding down the Control, Option, and Command keys while clicking
>> (suggested by tricks used by X Windows on the
>> Mac), to no avail. How do I turn on those bridges? :)
> Rick,
> The general right-click trick is to hold down the Control key alone
> and simultaneously click the mouse.
> Bridges initially become disabled in the bridge preferences dialog
> as a result of the testing phase you mentioned. Additionally you
> can disable them via the right-click menu. It is only this second
> category of bridges that you can enable i.e. bridges you previously
> manually disabled. I'm pretty sure you cannot enable bridges that
> were disabled automatically during the testing phase.
Hmmm...
I just tried it and it seems that you _can_ manually enable enable an
automatically disabled bridge. In the end, that doesn't really help
you because when you try to enter a venue using that bridge, a
warning message appears telling you that you can't connect to that
bridge.
chris
> You may find that testing the bridges again will bring some of them
> into the enabled category. You can force such a complete retesting
> of the bridges using the Purge button at the bottom right of the
> Preference's "Bridging" tab.
> chris
>> Todd Zimmerman wrote:
>>> On Fri, 2008-10-31 at 16:07 -0400, R. P. C. Rodgers wrote:
>>>> Dear AG Colleagues,
>>>> The very latest AG package, 3.2 beta 1, claims to work on the
>>>> Intel Mac under Mac OS X 10.5 --
>>>> but it refuses to start on my 10.5.5 machines. Can someone
>>>> remind me of where to look for the
>>>> appropriate log files to start trying to figure out the
>>>> problem? Alternatively, is there a known
>>>> problem using it under 10.5.5? Thanks in advance for any guidance.
>>> I'm currently running 3.2 beta (build 1) on a 10.5.5 intel laptop
>>> and
>>> all seems to be working fine (except the usual audio issues).
>>> I believe the logs can be found in ~/.AccessGrid3/Logs
>>> Cheers,
>>> Todd
> Christoph Willing +617 3365 8350
> QCIF Access Grid Manager
> University of Queensland
