[AG-TECH] VenueClient crashes
Christoph Willing
c.willing at uq.edu.au
Tue Nov 4 05:45:20 CST 2008
On 04/11/2008, at 7:10 PM, muhammad akl wrote:
> Sorry for being late in response Christoph,
> Well About the tools that I used to measure the rates , they were
> the vic itself and system monitor which comes by default with Ubuntu
> and here is a screenshot belongs to the Receiving machine :
> http://muhammad.akl.googlepages.com/acc.png
> I tried to perform the steps you suggested but i got some errors ,
> So I will try again and will inform you about the results .
Muhammad,
When you run the tests, could you shut down any other applications
please? I noticed in your screenshot that Ekiga was also running at
the time - that may have had some some strange side effect.
chris
> On Wed, Oct 29, 2008 at 1:22 AM, Christoph Willing
> <c.willing at uq.edu.au> wrote:
> On 26/10/2008, at 6:16 PM, muhammad akl wrote:
> [snip]
> After All the words mentioned UP , now the video is working fine
> here and the sending and receiving machines are working so fine
> except minor problem like i should disable and enable the producer
> Service from time to time (I believe it's due to my network traffic) .
> But The New problem here which happend today (I was doing all these
> tests mentioned in the previous mail yesterday) when the second
> machine starts to receive video , the whole operating System
> (ubuntu) hangs ! I thought the problem was a hardware issue , so I
> changed the producer machine to be a Consumer and made the Consumer
> to be a producer , but got the same result , the Consumer machine
> hanged also after it received the Video , this problem didn't
> appear yesterday .
> So What do you think about this problem ? hardware issues ?
> Also noticed something strange : the producer machine sends the DV
> streams at 29 Mbps while the Consumer machine receives the DV
> streams at more than 100 Mbps !!
> Muhammed,
> I haven't been able to replicate this problem. The sending rate is
> about right but the receiving rate should be the same, not more
> than 3 times greater. How are you measuring the date rate - from
> vic itself or some other tool?
> Can you try running a stream point to point separate from AG? i.e.
> shutdown VenueClient on both machines, then cd to ~/.AccessGrid3/
> local_services/SimpleHDVideoService and on the sending machine run:
> ./runDVslow address/port
> where address/port means the IP address of the receiving machine
> and port is some highish number e.g. 45678
> On the receiving machine, cd to same directory (or
> SimpleHDVConsumerService) and run:
> ./vic address/port
> where address is the IP address of the sending machine and port is
> the same number you chose when running the sending stream.
> How are your send & receive data rates?
> If the data rates seem sane, then the next step is to try the same
> test but replacing the IP addresses of the test machines with some
> arbitrary multicast address e.g. on the sending machine:
> ./runDVslow 233.45.67.89/45678
> and on the receiving machine:
> ./vic 233.45.67.89/45678
> How are the data rates on both machines now?
> chris
> Christoph Willing +617 3365 8350
> QCIF Access Grid Manager
> University of Queensland
