[AG-TECH] VenueClient crashes
muhammad akl
muhammad.akl at gmail.com
Tue Nov 4 03:10:56 CST 2008
Sorry for being late in response Christoph,
Well About the tools that I used to measure the rates , they were the vic
itself and system monitor which comes by default with Ubuntu
and here is a screenshot belongs to the Receiving machine :
http://muhammad.akl.googlepages.com/acc.png
I tried to perform the steps you suggested but i got some errors , So I will
try again and will inform you about the results .
Thanks alot for your assistance.
Regards
Muhammad
On Wed, Oct 29, 2008 at 1:22 AM, Christoph Willing <c.willing at uq.edu.au>wrote:
> On 26/10/2008, at 6:16 PM, muhammad akl wrote:
> [snip]
>> After All the words mentioned UP , now the video is working fine here and
>> the sending and receiving machines are working so fine except minor problem
>> like i should disable and enable the producer Service from time to time (I
>> believe it's due to my network traffic) .
>> But The New problem here which happend today (I was doing all these tests
>> mentioned in the previous mail yesterday) when the second machine starts to
>> receive video , the whole operating System (ubuntu) hangs ! I thought the
>> problem was a hardware issue , so I changed the producer machine to be a
>> Consumer and made the Consumer to be a producer , but got the same result ,
>> the Consumer machine hanged also after it received the Video , this problem
>> didn't appear yesterday .
>> So What do you think about this problem ? hardware issues ?
>> Also noticed something strange : the producer machine sends the DV streams
>> at 29 Mbps while the Consumer machine receives the DV streams at more than
>> 100 Mbps !!
> Muhammed,
> I haven't been able to replicate this problem. The sending rate is about
> right but the receiving rate should be the same, not more than 3 times
> greater. How are you measuring the date rate - from vic itself or some other
> tool?
> Can you try running a stream point to point separate from AG? i.e. shutdown
> VenueClient on both machines, then cd to
> ~/.AccessGrid3/local_services/SimpleHDVideoService and on the sending
> machine run:
> ./runDVslow address/port
> where address/port means the IP address of the receiving machine and port
> is some highish number e.g. 45678
> On the receiving machine, cd to same directory (or
> SimpleHDVConsumerService) and run:
> ./vic address/port
> where address is the IP address of the sending machine and port is the same
> number you chose when running the sending stream.
> How are your send & receive data rates?
> If the data rates seem sane, then the next step is to try the same test but
> replacing the IP addresses of the test machines with some arbitrary
> multicast address e.g. on the sending machine:
> ./runDVslow 233.45.67.89/45678
> and on the receiving machine:
> ./vic 233.45.67.89/45678
> How are the data rates on both machines now?
> chris
> Christoph Willing +617 3365 8350
> QCIF Access Grid Manager
> University of Queensland
URL: <http://lists.mcs.anl.gov/pipermail/ag-tech/attachments/20081104/99474d3b/attachment.htm>
