[AG-TECH] Assistance configuring 2.4 Venue/Bridge Server on RHEL5 x86_64.
Brad Viviano
viviano at renci.org
Wed May 21 10:25:40 CDT 2008
Tom,
Both the new bridge and venue server use staticly assigned IP's on the
same VLAN as the old bridge/venue server. The problem is a 2.4 client
doesn't show the option when connected to the 2.4 venue server for
Unicast (grayed out). Its like the Venue server isn't aware there is a
Unicast Bridge, but the Bride has registered itself to the Venue and got
a list of Venues to provide Unicast for. I even tried having it
register to a specific Venue (default one), the Bridge shows it
registered, but the clients still do not see a Unicast bridge in that Venue.
-Brad
Thomas D. Uram wrote:
> Hi Brad:
> Does the new VenueServer use statically-assigned addresses? If it did,
> then the BridgeServer would grab these and start QuickBridge instances
> for them immediately. If not, which I suspect may be your case, then
> addresses will be allocated as needed, and the BridgeServer will only
> then start QuickBridge instances for them.
> Static addressing is an option in VenueManagement, when configuring a
> Venue.
> Tom
> On 5/21/08 9:10 AM, Brad Viviano wrote:
>> Hello,
>> I apologize if this has been addressed else where. I searched the
>> archive and didn't find the answer. My group is in the process of
>> upgrading to 3.1 from 2.4. For various political reasons I've been
>> asked to keep a 2.4 server running for the near future. I've had a
>> 2.3/2.4 Venue/Bridge server operational under RHEL3 for over 3 years
>> now and am quite comfortable with setting up and maintaining 2.X AG.
>> We've acquired new hardware for the 3.1 Venue/Bridge setup running
>> RHEL5 and I wanted to run both the 2.X and 3.X servers on the same box
>> to make my administrative life easier. Using the docs from:
>> http://www.vislab.uq.edu.au/research/accessgrid/software/rhel/
>> I installed all the AG3.1 RPM's (and pre-requirements) as well as the
>> 2.4 compatibility set. I have the new 2.4 Venue Server up and
>> operational and working fine from 2.X clients, but I can not get the
>> bridge server to connect to the new Venue Server correctly.
>> Logs on the new bridge server when it connects to the new venue server
>> show:
>> 05/21/08 09:43:33 46912496258912 Toolkit Toolkit.py:709 INFO
>> Service init: have profile None
>> 05/21/08 09:43:33 46912496258912 Toolkit Config.py:214 DEBUG
>> System hostname of bridge3.renci.org is valid
>> 05/21/08 09:43:33 46912496258912 CertificateManager
>> CertificateManager.py:269 DEBUG Opened repository
>> /opt/ag/.AccessGrid/Config/certRepo
>> 05/21/08 09:43:33 46912496258912 Toolkit Toolkit.py:738 INFO
>> Initialized cert mgmt.
>> 05/21/08 09:43:33 46912496258912 Toolkit Toolkit.py:753 INFO
>> Loaded profile and configured with it.
>> CertificateManager.py:759 DEBUG Configuring standard environment
>> CertificateManager.py:827 DEBUG Using default identity /O=Access
>> Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/venues.renci.org
>> CertificateManager.py:1083 DEBUG Initializing environment with
>> unencrypted cert /O=Access
>> CertificateManager.py:1572 DEBUG done, success=1
>> 05/21/08 09:43:33 46912496258912 Toolkit Toolkit.py:764 INFO
>> Initialized Globus.
>> 05/21/08 09:43:33 46912496258912 Toolkit Toolkit.py:782 INFO
>> Service Initialization Complete.
>> 05/21/08 09:43:33 46912496258912 Toolkit BridgeServer24:157 INFO
>> BridgeFactory.SetPortMin 30000
>> 05/21/08 09:43:33 46912496258912 Toolkit BridgeServer24:161 INFO
>> BridgeFactory.SetPortMax 30999
>> 05/21/08 09:43:33 46912496258912 Toolkit BridgeServer24:259 INFO
>> AddVenueServer: url = https://venues.renci.org:9000/VenueServer
>> 05/21/08 09:43:33 46912496258912 Toolkit BridgeServer24:274 INFO
>> AddVenue: url =
>> https://venues3.renci.org:9000/Venues/00000102403861290098001300a80081d1e
>> 05/21/08 09:43:34 46912496258912 EventClient EventClient.py:158
>> DEBUG Have callback handle _303002b4aa2a0000_p_callbackStruct
>> 05/21/08 09:43:34 1115699520 Toolkit BridgeServer24:612 INFO
>> Method Venue.RunQueueThread called
>> 05/21/08 09:43:34 46912496258912 Toolkit BridgeServer24:274 INFO
>> AddVenue: url =
>> https://venues3.renci.org:9000/Venues/00000102403832e40098001300a8008150a
>> 05/21/08 09:43:35 46912496258912 EventClient EventClient.py:158
>> DEBUG Have callback handle _30c5be1900000000_p_callbackStruct
>> 05/21/08 09:43:35 1147169088 Toolkit BridgeServer24:612 INFO
>> 05/21/08 09:43:35 46912496258912 Toolkit BridgeServer24:274 INFO
>> AddVenue: url =
>> https://venues3.renci.org:9000/Venues/000001024035bd6c0098001300a80081bfc
>> 05/21/08 09:43:36 46912496258912 EventClient EventClient.py:158
>> DEBUG Have callback handle _d0c2c21900000000_p_callbackStruct
>> 05/21/08 09:43:36 1178638656 Toolkit BridgeServer24:612 INFO
>> 05/21/08 09:43:36 46912496258912 Toolkit BridgeServer24:274 INFO
>> AddVenue: url =
>> https://venues3.renci.org:9000/Venues/000001024037fb040098001300a80081610
>> 05/21/08 09:43:37 46912496258912 EventClient EventClient.py:158
>> DEBUG Have callback handle _50c101b4aa2a0000_p_callbackStruct
>> 05/21/08 09:43:37 1210108224 Toolkit BridgeServer24:612 INFO
>> 05/21/08 09:43:37 46912496258912 Toolkit BridgeServer24:274 INFO
>> AddVenue: url =
>> https://venues3.renci.org:9000/Venues/000001024a6692130098001300a80081582
>> 05/21/08 09:43:38 46912496258912 EventClient EventClient.py:158
>> DEBUG Have callback handle _20b800b4aa2a0000_p_callbackStruct
>> 05/21/08 09:43:38 1241577792 Toolkit BridgeServer24:612 INFO
>> The configuration file for the Bridge Server is:
>> [BridgeServer]
>> name = RENCI3
>> location = EUROPA
>> qbexec = /usr/bin/QuickBridge
>> portMin = 30000
>> portMax = 30999
>> [https://venues3.renci.org:9000/VenueServer]
>> type = VenueServer
>> Everything looks correct, the bridge connects to the server, gets
>> all the Venues, but QuickBridge never starts up. If I point this same
>> bridge server at my old 2.4 server (under RHEL3), it establishes a
>> connection, and will serve Unicast just fine, so I don't think its the
>> bridge server. I already dropped the firewall on both the Venue and
>> Bridge server just to be sure it wasn't a port issue.
>> I have 2 things I think it could be:
>> 1) conflict with certificate name. I am using the certificate from my
>> old server (venues.renci.org) on this test server (venues3.renci.org).
>> Thinking it might be a naming conflict, I renamed the new server
>> "venues.renci.org" and that didn't solve the problem, and I see no
>> complaints in the logs about certificate issues.
>> 2) The newer wxPython (2.8.7.1) and associated pre-requirements for AG
>> 3.1 (downloaded from EPEL) are too new to correctly work with the AG
>> 2.4 setup. I ran into a couple of issues trying to start the 2.4
>> Client, problems with wxPython compatability, but nothing on the
>> server side, and everything else on the 2.4 Venue Server is working
>> fine as far as Multicast (I can connect from a 2.4 clients and have
>> sessions just fine), its just the Unicast bridge won't connect and
>> start the QuickBridge for any of the Venues.
>> Before I spend the time to rebuild the software stack myself using
>> older code on RHEL5 (wxPython 2.5.x, etc), I thought I would ask if
>> anyone has experienced this before, and knows of a quick solution or
>> can offer a direction for me to look in.
>> Thanks,
>> -Brad Viviano
