[AG-TECH] Assistance configuring 2.4 Venue/Bridge Server on RHEL5 x86_64.
Thomas D. Uram
turam at mcs.anl.gov
Wed May 21 10:11:41 CDT 2008
Hi Brad:
Does the new VenueServer use statically-assigned addresses? If it did,
then the BridgeServer would grab these and start QuickBridge instances
for them immediately. If not, which I suspect may be your case, then
addresses will be allocated as needed, and the BridgeServer will only
then start QuickBridge instances for them.
Static addressing is an option in VenueManagement, when configuring a Venue.
Tom
On 5/21/08 9:10 AM, Brad Viviano wrote:
> Hello,
> I apologize if this has been addressed else where. I searched the
> archive and didn't find the answer. My group is in the process of
> upgrading to 3.1 from 2.4. For various political reasons I've been
> asked to keep a 2.4 server running for the near future. I've had a
> 2.3/2.4 Venue/Bridge server operational under RHEL3 for over 3 years
> now and am quite comfortable with setting up and maintaining 2.X AG.
> We've acquired new hardware for the 3.1 Venue/Bridge setup running
> RHEL5 and I wanted to run both the 2.X and 3.X servers on the same box
> to make my administrative life easier. Using the docs from:
> http://www.vislab.uq.edu.au/research/accessgrid/software/rhel/
> I installed all the AG3.1 RPM's (and pre-requirements) as well as the
> 2.4 compatibility set. I have the new 2.4 Venue Server up and
> operational and working fine from 2.X clients, but I can not get the
> bridge server to connect to the new Venue Server correctly.
> Logs on the new bridge server when it connects to the new venue server
> show:
> 05/21/08 09:43:33 46912496258912 Toolkit Toolkit.py:709 INFO
> Service init: have profile None
> 05/21/08 09:43:33 46912496258912 Toolkit Config.py:214 DEBUG
> System hostname of bridge3.renci.org is valid
> 05/21/08 09:43:33 46912496258912 CertificateManager
> CertificateManager.py:269 DEBUG Opened repository
> /opt/ag/.AccessGrid/Config/certRepo
> 05/21/08 09:43:33 46912496258912 Toolkit Toolkit.py:738 INFO
> Initialized cert mgmt.
> 05/21/08 09:43:33 46912496258912 Toolkit Toolkit.py:753 INFO
> Loaded profile and configured with it.
> CertificateManager.py:759 DEBUG Configuring standard environment
> CertificateManager.py:827 DEBUG Using default identity /O=Access
> Grid/OU=agdev-ca.mcs.anl.gov/CN=VenueServer/venues.renci.org
> CertificateManager.py:1083 DEBUG Initializing environment with
> unencrypted cert /O=Access
> CertificateManager.py:1572 DEBUG done, success=1
> 05/21/08 09:43:33 46912496258912 Toolkit Toolkit.py:764 INFO
> Initialized Globus.
> 05/21/08 09:43:33 46912496258912 Toolkit Toolkit.py:782 INFO
> Service Initialization Complete.
> 05/21/08 09:43:33 46912496258912 Toolkit BridgeServer24:157 INFO
> BridgeFactory.SetPortMin 30000
> 05/21/08 09:43:33 46912496258912 Toolkit BridgeServer24:161 INFO
> BridgeFactory.SetPortMax 30999
> 05/21/08 09:43:33 46912496258912 Toolkit BridgeServer24:259 INFO
> AddVenueServer: url = https://venues.renci.org:9000/VenueServer
> 05/21/08 09:43:33 46912496258912 Toolkit BridgeServer24:274 INFO
> AddVenue: url =
> https://venues3.renci.org:9000/Venues/00000102403861290098001300a80081d1e
> 05/21/08 09:43:34 46912496258912 EventClient EventClient.py:158
> DEBUG Have callback handle _303002b4aa2a0000_p_callbackStruct
> 05/21/08 09:43:34 1115699520 Toolkit BridgeServer24:612 INFO
> Method Venue.RunQueueThread called
> 05/21/08 09:43:34 46912496258912 Toolkit BridgeServer24:274 INFO
> AddVenue: url =
> https://venues3.renci.org:9000/Venues/00000102403832e40098001300a8008150a
> 05/21/08 09:43:35 46912496258912 EventClient EventClient.py:158
> DEBUG Have callback handle _30c5be1900000000_p_callbackStruct
> 05/21/08 09:43:35 1147169088 Toolkit BridgeServer24:612 INFO
> 05/21/08 09:43:35 46912496258912 Toolkit BridgeServer24:274 INFO
> AddVenue: url =
> https://venues3.renci.org:9000/Venues/000001024035bd6c0098001300a80081bfc
> 05/21/08 09:43:36 46912496258912 EventClient EventClient.py:158
> DEBUG Have callback handle _d0c2c21900000000_p_callbackStruct
> 05/21/08 09:43:36 1178638656 Toolkit BridgeServer24:612 INFO
> 05/21/08 09:43:36 46912496258912 Toolkit BridgeServer24:274 INFO
> AddVenue: url =
> https://venues3.renci.org:9000/Venues/000001024037fb040098001300a80081610
> 05/21/08 09:43:37 46912496258912 EventClient EventClient.py:158
> DEBUG Have callback handle _50c101b4aa2a0000_p_callbackStruct
> 05/21/08 09:43:37 1210108224 Toolkit BridgeServer24:612 INFO
> 05/21/08 09:43:37 46912496258912 Toolkit BridgeServer24:274 INFO
> AddVenue: url =
> https://venues3.renci.org:9000/Venues/000001024a6692130098001300a80081582
> 05/21/08 09:43:38 46912496258912 EventClient EventClient.py:158
> DEBUG Have callback handle _20b800b4aa2a0000_p_callbackStruct
> 05/21/08 09:43:38 1241577792 Toolkit BridgeServer24:612 INFO
> The configuration file for the Bridge Server is:
> [BridgeServer]
> name = RENCI3
> location = EUROPA
> qbexec = /usr/bin/QuickBridge
> portMin = 30000
> portMax = 30999
> [https://venues3.renci.org:9000/VenueServer]
> type = VenueServer
> Everything looks correct, the bridge connects to the server, gets
> all the Venues, but QuickBridge never starts up. If I point this same
> bridge server at my old 2.4 server (under RHEL3), it establishes a
> connection, and will serve Unicast just fine, so I don't think its the
> bridge server. I already dropped the firewall on both the Venue and
> Bridge server just to be sure it wasn't a port issue.
> I have 2 things I think it could be:
> 1) conflict with certificate name. I am using the certificate from my
> old server (venues.renci.org) on this test server (venues3.renci.org).
> Thinking it might be a naming conflict, I renamed the new server
> "venues.renci.org" and that didn't solve the problem, and I see no
> complaints in the logs about certificate issues.
> 2) The newer wxPython (2.8.7.1) and associated pre-requirements for AG
> 3.1 (downloaded from EPEL) are too new to correctly work with the AG
> 2.4 setup. I ran into a couple of issues trying to start the 2.4
> Client, problems with wxPython compatability, but nothing on the
> server side, and everything else on the 2.4 Venue Server is working
> fine as far as Multicast (I can connect from a 2.4 clients and have
> sessions just fine), its just the Unicast bridge won't connect and
> start the QuickBridge for any of the Venues.
> Before I spend the time to rebuild the software stack myself using
> older code on RHEL5 (wxPython 2.5.x, etc), I thought I would ask if
> anyone has experienced this before, and knows of a quick solution or
> can offer a direction for me to look in.
> Thanks,
> -Brad Viviano
