[AG-TECH] h.264 vic
gurcharan khanna
gskpop at cis.rit.edu
Fri May 2 15:13:21 CDT 2008
hi,
i guess i've been under a misunderstanding all these years!
i thought producer only sent and consumer only received, to
keep things lean and mean. if every vic receives,
then there's a lot of redundant bits coming in with unicast, isn't there?
i wanted the option to turn off receive if i was bandwidth limited, so
the "noMulticast" option is great. i wanted all the videos to show up
if i had plenty of bandwith. (the ISP in Kosovo is supposed to increase
the bandwidth tomorrow...). (if you tune in now you will see that there
are almost no lights on in Kosovo at night!)
so....if i am using the 264ConsumerService, i don't to run a "261"
ConsumerService, right? that would be redundant.
thanks
-gurcharan
Piers O'Hanlon wrote:
> Hi Gurchan,
>> i'm trying to set up the h.264 enabled vic in an AG node in Kosovo for a
>> large event tomorrow at RIT.
>> there are both audio and video problems but i will just try to fix the
>> video
>> for now. when i enable the h.264 service as the only video service at all,
>> i get a thumbnail of not only the 264 stream but all the received streams
>> from the venue, even though i'm not running any consumer service. and
>> the bandwidth that goes along with it, muted or not. i'm bandwidth
>> challenged
>> in Kosovo, and just want to run the 264 vic only.
>> why am i receiving video when i am not running a consumer service?
> VIC will display any video sent to - you need to make sur evic isn't
> being set any video - this is
> easier said than done most or the time as AG usually operates in that way.
> If you're running VIC with multicast you can get it no receive video
> by runnig it with the following option:
> vic -X "noMulticastBind=true" addr/port
> VIC sends and receives as default. If you're running it on unicast
> then you need to get the gateway to
> not send you the video. If you have access to the gateway machine you
> could hack it by adding a firewall
> rule block traffic coming back to you machine.
>> can i run the 264 vic standalone from the cmd line? where is it? or how
>> do i do that?
> On windows vic.exe is found:
> C:\Documents and Settings\ag_user_name\Application
> Data\AccessGrid3\local_servicesVideoProducerService\vic.exe
> you can change into the directory (or use the path above - enclosed in
> quotes) and run it:
> vic.exe address/port_num
>> btw, i am using bridging and can send video ok into the bridge but cannot
>> receive any video back from the bridge. tried various bridges.
> It seems that the bridge is doing what you want - You mentioned above that you
> didn't want to receive video?
> If you want to see the video then it may be some issue with the
> sending sites and their
> connection to the bridge.
>> finally, rat shows signal in the listen window but headphones don't pick
>> up any audio. the windows xp system has built in MS RDP audio driver
>> but sometimes switches to SoundMax HD, but neither seem to allow
>> the headphones to connect to the signal RAT is obviously seeing. not
>> an AG issue but maybe someone can give me a clue.
> You can select the appropriate audio device in RAT control menu -
> under 'audio'. If
> you select the audio device you want then you can chekc RAT has kept the setting
> by going back to that page to see if it is still selected.
> Once the device is selected - you may need to play with the audio
> mixer to get the
> right signals coming out the right outputs.
> Piers
>> mainly i need at least the 264 video w/o all the extra bandwidth of
>> received
>> videos.
>> thanks for any insights,
>> -gurcharan
>> Gurcharan S. Khanna, Ph.D.
>> Director of Research Computing
>> Office of the Vice President for Research
>> http://rc.rit.edu
>> Director, Interactive Collaboration Environments Laboratory
>> Center for the Advancing the Study of Cyberinfrastructure
>> http://icelab.rit.edu
>> Rochester Institute of Technology
>> 1 Lomb Memorial Drive
>> Rochester, New York 14623-5603
>> Phone: 585-475-7504 ~ Cell: 585-451-8370
>> Email: gurcharan.khanna at rit.edu
>> Http: people.rit.edu/gskpop
http://rc.rit.edu
